    readFileSync
    17 Posts 3 Posters 12.4k Views 1 Watching
      mattlugar @MichMich
      That’s where my lack of knowledge on how to debug in this new environment was hurting me. Was able to figure out a better way to debug and now have something to work with.
      Uncaught ReferenceError: require is not defined
      Off to roll up my sleeves and do some mad google-fu.
      Thank you! :)
      • KirAsh4K Offline
        KirAsh4 Moderator
        That’s because require isn’t part of JavaScript. It’s part of node.js to load modules. There are potentially other ways of doing what you’re trying to do. You may want to check out this post on Stack Overflow.
          mattlugar
          Yeah, I went about it differently than I wanted to. I ended up porting everything to an apache directory so it serves itself as a webapp. Had a few bugs to work out (it was locking up if the json was in the middle of writing when it was retrieved) but I have it working and bug free now best I can tell :)
          • KirAsh4K Offline
            KirAsh4 Moderator
            I suppose that’s one way to do that … doesn’t make it very portable or sharable to others. It’s no longer contained within only MM and Node.js … But, if it’s working for you and does what you want, that’s the only thing that matters.
            • MichMichM Offline
              MichMich
              Just so you know, the node_helper can serve files as well: https://github.com/MichMich/MagicMirror/tree/master/modules#thisexpressapp
              • KirAsh4K Offline
                KirAsh4 Moderator
                I saw that when I was fiddling with some other stuff, but never actually tested it. Is that path relative to the actual module location? Or MM’s installation? Or the user that’s running MM? So if '/foo/bar/baz' is defined, where does it start?
                /foo/bar/baz? (OH PLEASE SAY NO, for the love of all that is sacred, tell me Node.js does NOT allow system reads like that!)
                $HOME/foo/bar/baz ?
                $HOME/MagicMirror/foo/bar/baz?
                $HOME/MagicMirror/modules/foo/bar/baz?
                $HOME/MagicMirror/modules/<MODULE>/foo/bar/baz?
                • MichMichM Offline
                  MichMich
                  If you are referring to this snippet:
                  start: function() {
                      this.expressApp.get('/foobar', function (req, res) {
                          res.send('GET request to /foobar');
                  The /foobar is referring to the url: http://localhost:8080/foobar
                  • KirAsh4K Offline
                    KirAsh4 Moderator
                    Ah, so it’s still an HTTP call then, not a simple fileread from disk.
                    • MichMichM Offline
                      MichMich
                      Exactly.
                      • KirAsh4K Offline
                        KirAsh4 Moderator
                        So then the question is still, where is that '/foobar' ? What’s that in relation to? The MM install? The module’s folder?
                        MichMichM 1 Reply Last reply Reply Quote 0
