    readFileSync
    17 Posts 3 Posters 13.7k Views 1 Watching
    • MichMichM
      MichMich
      What does it lockup? The fronted? Or the backend?
      If it’s just the frontend, check your webinspector/console to see what’s going on.
        mattlugar @MichMich
        That’s where my lack of knowledge on how to debug in this new environment was hurting me. Was able to figure out a better way to debug and now have something to work with.
        Uncaught ReferenceError: require is not defined
        Off to roll up my sleeves and do some mad google-fu.
        Thank you! :)
        • K
          KirAsh4 Moderator
          That’s because require isn’t part of JavaScript. It’s part of node.js to load modules. There are potentially other ways of doing what you’re trying to do. You may want to check out this post on Stack Overflow.
            mattlugar
            Yeah, I went about it differently than I wanted to. I ended up porting everything to an apache directory so it serves itself as a webapp. Had a few bugs to work out (it was locking up if the json was in the middle of writing when it was retrieved) but I have it working and bug free now best I can tell :)
            • K
              KirAsh4 Moderator
              I suppose that’s one way to do that … doesn’t make it very portable or sharable to others. It’s no longer contained within only MM and Node.js … But, if it’s working for you and does what you want, that’s the only thing that matters.
              • MichMichM
                MichMich
                Just so you know, the node_helper can serve files as well: https://github.com/MichMich/MagicMirror/tree/master/modules#thisexpressapp
                • K
                  KirAsh4 Moderator
                  I saw that when I was fiddling with some other stuff, but never actually tested it. Is that path relative to the actual module location? Or MM’s installation? Or the user that’s running MM? So if '/foo/bar/baz' is defined, where does it start?
                  /foo/bar/baz? (OH PLEASE SAY NO, for the love of all that is sacred, tell me Node.js does NOT allow system reads like that!)
                  $HOME/foo/bar/baz ?
                  $HOME/MagicMirror/foo/bar/baz?
                  $HOME/MagicMirror/modules/foo/bar/baz?
                  $HOME/MagicMirror/modules/<MODULE>/foo/bar/baz?
                  • MichMichM
                    MichMich
                    If you are referring to this snippet:
                    start: function() {
                        this.expressApp.get('/foobar', function (req, res) {
                            res.send('GET request to /foobar');
                    The /foobar is referring to the url: http://localhost:8080/foobar
                    • K
                      KirAsh4 Moderator
                      Ah, so it’s still an HTTP call then, not a simple fileread from disk.
                      • MichMichM
                        MichMich
                        Exactly.
                        • K
                          KirAsh4 Moderator
                          So then the question is still, where is that '/foobar' ? What’s that in relation to? The MM install? The module’s folder?
                          MichMichM 1 Reply Last reply Reply Quote 0
                          • MichMichM
                            MichMich @KirAsh4
                            @KirAsh4 it hasnt got anything to do with a file. It’s just a request, if you want to respond with the contents of a file, you need to do that yourself or use the following method if you want to feed a full folder:
                            this.expressApp.use("/foobar" + this.name, this.expressApp.static(this.path + "/foobar"));
                            • K
                              KirAsh4 Moderator
                              No, it doesn’t have anything to do with the contents. It has to do with where that file resides on the physical system. For example, a request to a default Apache installation will look for a file in '/var/www/html/' or '$USER/public_html' or whatever the system admin has configured it as. In this case, this is a specific request through the Node.js system, being called by MM, so where does it look for that file? Within the user’s folder? Within MM’s installation folder? Within the actual module’s folder? Or does Node.js allow access to the entire file system? So that if I do a call such as:
                              this.expressAp.use("/etc/passwd")
                              will I actually get the contents of the system’s '/etc/passwd' file, or is going to try to read '/path/to/MM-install/etc/passwd' or some other path?
                              • MichMichM
                                MichMich
                                I’ve got the feeling we’re talking about something different.
                                The example:
                                does not serve any file. So talking about file location doesn’t make any sense in this case. In this example It just serves the text string GET request to /foobar
                                In the second example:
                                only the express.static(root, [options]) part refers to a file or folder. The root argument refers to the root directory from which the static assets are to be served.
                                More info about express.static can be found here: http://expressjs.com/en/api.html#express.static
                                • K
                                  KirAsh4 Moderator @MichMich
                                  @MichMich said in readFileSync:
                                  That’s part of the answer I was looking for. Specifically, 'from which the static assets are to be served'. Now to figure out where those are, or where they are allowed to be rather. Basically I’m looking at it from a security stand point. Where is this thing going to allow a user to get to, to fetch a file.
                                    mattlugar @KirAsh4
                                    @KirAsh4 Yeah, it is working for me as I want it. I figured it wouldn’t be overly useful to others anyhow since there was a lot of back-end work to do (namely setting up json streams that match the module code from the weather station, uploading to an appropriate location).
                                    Screenshot of my current display is below. It updates every 5 seconds using data from my local Davis weather station running Cumulus software. The rain information (total daily rain on top left, current rain rate at bottom left) only display if there has been rain today or it is currently raining respectively. It will also display winds like “12 G23” if the winds hit gust criteria (over 18MPH gusts and more than 10MPH over the wind speed). It is pretty trivial to put any information you can get into the json file to display.
                                    I’d be happy to try to properly modularize this if there is some interest, there’s just so many options and variations of stations/json exports/etc that I’m not sure I’d know where to start.
                                    alt text
