    Read local txt file from node_helper.js
    12 Posts 2 Posters 3.5k Views 2 Watching
      Aphamguin @sdetweil
      @sdetweil it seems to break the module and MM. Nothing shows up on the screen when I run it.
      Thanks for the sample module. It’s a really helpful template that I thought MM would have given us.
      It’s a simple module, but I’m just implementing its functionality in phases. At the moment I just want it to read from a local txt file, parse it into an array, and then display a chunk of text by accessing that array. So yes I’m just showing text. What is innerText? Do I just do elem.innerText(“text”)
      instead of elem.innerHTML(“text”)?
      S 3 Replies Last reply Reply Quote 0
        sdetweil @Aphamguin
        @Aphamguin yes elem.innerText.
        not sure what you mean by breaks mm…
        if u email me the three files I will find what the problem is.
        same user ID on gmail. rename the .js as .txt
          sdetweil @Aphamguin
          @Aphamguin you did set a position for your module in config, right? else the output doesn’t get used
            sdetweil @Aphamguin
            @Aphamguin the sample mm provides (hello world), uses the nunjuks template approach
              Aphamguin @sdetweil
              @sdetweil I have emailed you the main js file, the helper, and the txt file, all as txt files. I hope you got it.
              I did set a position, yes.
              Where can I get the sample mm? What is the nunjuks template approach?
                sdetweil @Aphamguin
                @Aphamguin my sample module
                https://github.com/sdetweil/SampleModule
                I don’t have any links to nunjuks.
                but basically you create a layout template with locations for variables, and then supply the data, and the template engine does that formatting
                see the helloworld module in the defaults folder
                I am working on your module. the initial problem is the data filename has to have a path, else it will be in the MagicMirror folder.
                but there is also an easier way to process your data.
                in a couple hours I will get it back to you the same way
                  Aphamguin @sdetweil
                  @sdetweil Ok I’ll play around with it then.
                  Wow great. Thanks a lot. I really appreciate it.
                    sdetweil @Aphamguin
                    @Aphamguin sent back
                      Aphamguin
                      To conclude this issue, when reading from a local txt file with node_helper.js, you have to make sure the file name has a path. And then when parsing it, you can parse it easily by checking for carriage returns (\r) to see if if its a windows file. Here is a snippet of the solution:
                      this.rawText = fs.readFileSync(__dirname + '/localTxtFile.txt').toString()
                      this.isWindows = (this.rawText.indexOf('\r') == -1) ? false:true
                      this.variable= this.rawText.split(this.isWindows ? '\r\n\r\n' : '\n\n')
                        sdetweil @Aphamguin
                        @Aphamguin well, you think about what you are trying to accomplish,
                        I changed the file to Linux line ends. then realized u might get it from somewhere as windows line end. so added to make it work either way.
