    Read local txt file from node_helper.js
    12 Posts 2 Posters 3.5k Views 2 Watching
      sdetweil @Aphamguin
      @Aphamguin yes elem.innerText.
      not sure what you mean by breaks mm…
      if u email me the three files I will find what the problem is.
      same user ID on gmail. rename the .js as .txt
        sdetweil @Aphamguin
        @Aphamguin you did set a position for your module in config, right? else the output doesn’t get used
          sdetweil @Aphamguin
          @Aphamguin the sample mm provides (hello world), uses the nunjuks template approach
            Aphamguin @sdetweil
            @sdetweil I have emailed you the main js file, the helper, and the txt file, all as txt files. I hope you got it.
            I did set a position, yes.
            Where can I get the sample mm? What is the nunjuks template approach?
              sdetweil @Aphamguin
              @Aphamguin my sample module
              https://github.com/sdetweil/SampleModule
              I don’t have any links to nunjuks.
              but basically you create a layout template with locations for variables, and then supply the data, and the template engine does that formatting
              see the helloworld module in the defaults folder
              I am working on your module. the initial problem is the data filename has to have a path, else it will be in the MagicMirror folder.
              but there is also an easier way to process your data.
              in a couple hours I will get it back to you the same way
                Aphamguin @sdetweil
                @sdetweil Ok I’ll play around with it then.
                Wow great. Thanks a lot. I really appreciate it.
                  sdetweil @Aphamguin
                  @Aphamguin sent back
                    Aphamguin
                    To conclude this issue, when reading from a local txt file with node_helper.js, you have to make sure the file name has a path. And then when parsing it, you can parse it easily by checking for carriage returns (\r) to see if if its a windows file. Here is a snippet of the solution:
                    this.rawText = fs.readFileSync(__dirname + '/localTxtFile.txt').toString()
                    this.isWindows = (this.rawText.indexOf('\r') == -1) ? false:true
                    this.variable= this.rawText.split(this.isWindows ? '\r\n\r\n' : '\n\n')
                      sdetweil @Aphamguin
                      @Aphamguin well, you think about what you are trying to accomplish,
                      I changed the file to Linux line ends. then realized u might get it from somewhere as windows line end. so added to make it work either way.
