This forum was moved to another machine and updated to a recent version. If you are unable to login please delete your browser cookies and cache and restart your browser.A New Chapter for MagicMirror: The Community Takes the Lead
MMM-NewPIR v3
Hello, unfortunately I need some help.
I have installed the module but as soon as I edit the config magicmirror does not start anymore. -
what’s your config ?
/* Magic Mirror Config Sample * * By Michael Teeuw https://michaelteeuw.nl * MIT Licensed. * * For more information on how you can configure this file * See https://github.com/MichMich/MagicMirror#configuration * */ var config = { address: "localhost", // Address to listen on, can be: // - "localhost", "127.0.0.1", "::1" to listen on loopback interface // - another specific IPv4/6 to listen on a specific interface // - "0.0.0.0", "::" to listen on any interface // Default, when address config is left out or empty, is "localhost" port: 8080, basePath: "/", // The URL path where MagicMirror is hosted. If you are using a Reverse proxy // you must set the sub path here. basePath must end with a / ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses // or add a specific IPv4 of 192.168.1.5 : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"], // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"], useHttps: false, // Support HTTPS or not, default "false" will use HTTP httpsPrivateKey: "", // HTTPS private key path, only require when useHttps is true httpsCertificate: "", // HTTPS Certificate path, only require when useHttps is true language: "de", logLevel: ["INFO", "LOG", "WARN", "ERROR"], timeFormat: 24, units: "metric", // serverOnly: true/false/"local" , // local for armv6l processors, default // starts serveronly and then starts chrome browser // false, default for all NON-armv6l devices // true, force serveronly mode, because you want to.. no UI on this device modules: [ { module: 'MMM-Carousel', config: { transitionInterval: 10000, ignoreModules: ['clock', 'alert', 'calendar', 'MMM-Fuel', 'MMM-Sonos', 'MMM-OpenmapWeather', 'weatherforecast', 'MMM-DWD-Pollen', 'MMM-DWD-WarnWeather', 'newsfeed'], mode: 'positional', top_left: {enabled: true, ignoreModules: ['clock', 'MMM-Fuel', 'calendar']}, top_right: {enabled: false, ignoreModules: ['MMM-OpenmapWeather', 'MMM-DWD-WarnWeather', 'weatherforecast', ], overrideTransitionInterval: 20000} } }, { module: "alert", }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_left", config: { showSunTimes: "true", lat: "52.4262603", lon: "9.4697593", // See 'Configuration options' for more information. } }, { module: 'MMM-NewPIR', position: 'top_left', config: { debug: false, screen: { delay: 2 * 60 * 1000, turnOffDisplay: true, ecoMode: true, displayCounter: true, text: "Auto Turn Off Screen:", displayBar: true, displayStyle: "Text", governorSleeping: false, rpi4: false }, pir: { usePir: true, gpio: 21, reverseValue: false }, governor: { useGovernor: false, sleeping: "powersave", working: "ondemand" } } }, { module: "calendar", header: "Termine", position: "top_left", config: { maximumEntries: "12", calendars: [ { symbol: "calendar-check", url: "https://calendar.google.com/calendar/ical/pubtgv6fpslkvd2s4tmd8b4164%40group.calendar.google.com/private-6290764b7af7d5aa6ea139fb4826c33c/basic.ics" } ] } }, { module: "MMM-Fuel", position: "top_left", config: { api_key: "654340ee-5805-e1c4-279f-13e7afbc6683", lat: 52.4262603, lng: 9.4697593, radius: 5, max: 5, types: ["e5"], sortBy: "e5", rotate: "false", // all your config options, which are different than their default values } }, { module: "compliments", position: "top_center", config: { compliments: { morning: [ "Guten Morgen Sonnenschein!", "Hab einen schönen Tag!", "Hast du gut geschlafen?" ], afternoon: [ "Wie war dein Tag?", "Du siehst gut aus heute!", "Schön, dass du wieder da bist!" ], evening: [ "Einen schönen Abend!", "Schlaf gut!", ], day_sunny: [ "Heute ist ein Sonniger Tag", "Es ist ein schöner Tag!" ], snow: [ "Schnee!!!", "Schneeballschlacht!", "Lass uns einen Schneemann bauen!" ], cloudy: [ "Es ist wolkig, hoffentlich regnet es nicht" ], showers: [ "Es schüttet draußen, bleibt lieber Zuhause!" ], cloudy_windy: [ "Windig draußen!", "Halt bloß deine Hose fest" ], thunderstorm: [ "GEWITTER??? WOOOOO? ÜBERALL?!", "Es gewittert draußen!" ], fog: [ "Nebel des Todes of Doom!", "Ganz schön nebelig draußen..." ], rain: [ "Nicht den Regenschirm vergessen!", "Ihh es regnet :(" ] } } }, { module: 'MMM-Sonos', header: 'Now playing', position: 'bottom_center', config: { animationSpeed: "1000", showFullGroupName: "true", showArtist: "true", showAlbum: "true", showMetadata: "true" } }, { module: 'MMM-COVID19-SPARKLINE', header: "COVID-19 Fälle", position: "bottom_center", config : { worldStats: true, sparklines: true, sparklineWidth: 100, sparklineHeight: 55, sparklineDays: 50, sparklineDeltavsDaily: false, sortby: "confirmed", columns: ["confirmed", "deaths", "recovered"], countries: ["Germany", "Spain", "Italy", "US"], updateInterval: 1000 * 60 * 60 * 3, //3 hours infoRowClass: "small", headerRowClass: "small", fadeSpeed: 1000, showDelta: true, showDeltaPlotNDays: 14, showDelimiter: true } }, { module: "MMM-OpenmapWeather", header: "Wetter für", position: "top_right", config: { units: "metric", degreeLabel: "true", showFeelsLike: "false", showHumidity: "true", useKMPHwind: "true", useBeaufort: "false", colorIcon: "true", lang: "de", location: "Wunstorf", locationID: "2805761", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city appid: "60328ec38ba3b4f61059f193dff92f13" } }, { module: 'MMM-DWD-WarnWeather', position: 'top_right', // header: 'Wetterwarnungen', config: { warnCellID: "803241021", changeColor: true, minutes: false, displayRegionName: true, displayInnerHeader: true, interval: 10 * 60 * 1000, // every 10 minutes loadingText: 'Warnungen werden geladen...', noWarningText: 'Keine Warnungen', severityThreshold: 1 } }, { module: "weatherforecast", position: "top_right", header: "Wettervorhersage für", config: { units: "metric", showRainAmount: "true", lang: "de", scale: "true", colored: "true", location: "Wunstorf", locationID: "2805761", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city appid: "60328ec38ba3b4f61059f193dff92f13", maxNumberOfDays: "7" } }, { module: "MMM-DWD-Pollen", position: "top_right", header: "Pollenwarnung", config: { updateInterval: 1 * 60 * 60 * 1000, // every 1 hour1 DWD_region: 32, // Östliches Niedersachsen icon: false // Show icons or not } }, { module: "MMM-RAIN-MAP", position: "top_right", header: "Regenradar", config: { animationSpeed: 600, displayClockSymbol: true, displayTime: true, extraDelayLastFrame: 500, height: "300px", lat: 52.42580, lng: 9.42944, map: "OSM", markers: [ { lat: 52.42755, lng: 9.47309, color: "blue" } ], onlyOnRain: false, opacity: 0.65, timeFormat: 24, updateIntervalInSeconds: 300, width: "300px", zoom: 8, zoomOutEach: 3, zoomOutLevel: 3, } }, { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "Tagesschau", url: "http://www.tagesschau.de/xml/rss2" }, { title: "Heise", url: "https://www.heise.de/rss/heise-atom.xml" }, ], showSourceTitle: true, showPublishDate: true, broadcastNewsFeeds: true, broadcastNewsUpdates: true } }, { module: "MMM-SpaceX", position: "top_left", config: { records: 3, modus: "upcoming", showExtraInfo: false, showColumnHeader: true, } }, { module: 'MMM-WiFiPassword', position: "top_left", config: { //See 'Configuration options' for more information. network: "FRITZ!Box 7590 M&K", password: "***", showPassword: true, } }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== "undefined") {module.exports = config;}
configuration seems good
do you have any error on start ?
If you use pm2 -> stop the process and start it manually with
npm start
commandgive me log or error ?
some library missing … do you use npm install command for installing ?
Yes I have stopped MagicMirror and installed the module.
pi@PiSmartMirror:~/MagicMirror/modules/MMM-NewPIR $ npm install > MMM-NewPIR@3.0.1 install /home/pi/MagicMirror/modules/MMM-NewPIR > scripts/installer.sh npm notice created a lockfile as package-lock.json. You should commit this file. audited 176 packages in 5.506s 4 packages are looking for funding run `npm fund` for details found 0 vulnerabilities
can you try this:
bugs@debian:~/MagicMirror/modules/MMM-NewPIR$ rm -rf node_modules/ bugs@debian:~/MagicMirror/modules/MMM-NewPIR$ rm package-lock.json bugs@debian:~/MagicMirror/modules/MMM-NewPIR$ npm install npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142 npm WARN deprecated har-validator@5.1.5: this library is no longer supported epoll@4.0.0 install /home/bugs/MagicMirror/modules/MMM-NewPIR/node_modules/epoll node-gyp rebuild make : on entre dans le répertoire « /home/bugs/MagicMirror/modules/MMM-NewPIR/node_modules/epoll/build » CXX(target) Release/obj.target/epoll/src/epoll.o SOLINK_MODULE(target) Release/obj.target/epoll.node COPY Release/epoll.node make : on quitte le répertoire « /home/bugs/MagicMirror/modules/MMM-NewPIR/node_modules/epoll/build » @bugsounet/pir@1.0.4 postinstall /home/bugs/MagicMirror/modules/MMM-NewPIR/node_modules/@bugsounet/pir > electron-rebuild ✔ Rebuild Complete MMM-NewPIR@3.0.1 install /home/bugs/MagicMirror/modules/MMM-NewPIR scripts/installer.sh npm notice created a lockfile as package-lock.json. You should commit this file. added 176 packages from 127 contributors and audited 176 packages in 26.073s 4 packages are looking for funding run `npm fund` for details found 0 vulnerabilities bugs@debian:~/MagicMirror/modules/MMM-NewPIR$ cd ~/MagicMirror bugs@debian:~/MagicMirror$ npm start
That’s it. Seems to work now… Thank You :)
perfect so :)
when it want to works, it's magical
