    MMM-NewPIR v3
    67 Posts 18 Posters 32.0k Views 20 Watching
      A Former User
      MMM-NewPIR (v3)
      It uses a PIR sensor attached to your raspberry pi’s GPIO pins to check for users. After a configurated time without any user interaction the display will turn off and hide all module for economy mode.
      If you don’t have PIR sensor, it can also be used for automatic turn on / turn off screen.
      What’s new on V3 ?
      • Rewrite entire main code
      • New configuration
      • Use my own shared npm library
      • Add new display style
      • More tools: incomming notification for developers
      Screenshot
      Developer Notes
      • This module broadcasts:
        • USER_PRESENCE notification with the payload beeing true or false you can use it to pause or disable another module.
      • This module receive:
        • USER_PRESENCE notification with the payload true to force user presence or false to force delay to time out.
        • SCREEN_END notification to force the end of the count down
        • SCREEN_WAKEUP notification to wake up the screen and reset count down
        • SCREEN_LOCK notification keep the screen on and lock it (freeze counter and stop pir detection)
        • SCREEN_UNLOCK notification unlock the screen and restart counter and pir detection
        DeathForce
        Hello, unfortunately I need some help.
        I have installed the module but as soon as I edit the config magicmirror does not start anymore.
          A Former User
          what’s your config ?
            DeathForce @Guest
            @Bugsounet
            /* Magic Mirror Config Sample
             * By Michael Teeuw https://michaelteeuw.nl
             * MIT Licensed.
            var config = {
            	address: "localhost", 	// Address to listen on, can be:
            	port: 8080,
            	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
            	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
            	language: "de",
            	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
            	timeFormat: 24,
            	units: "metric",
                        module: 'MMM-Carousel',
                            transitionInterval: 10000,
                            ignoreModules: ['clock', 'alert', 'calendar', 'MMM-Fuel', 'MMM-Sonos', 'MMM-OpenmapWeather', 'weatherforecast', 'MMM-DWD-Pollen', 'MMM-DWD-WarnWeather', 'newsfeed'],
                            mode: 'positional',
                            top_left: {enabled: true, ignoreModules: ['clock', 'MMM-Fuel', 'calendar']},
            				top_right: {enabled: false, ignoreModules: ['MMM-OpenmapWeather', 'MMM-DWD-WarnWeather', 'weatherforecast', ], overrideTransitionInterval: 20000}
            			module: "alert",
            			module: "updatenotification",
            			position: "top_bar"
            			module: "clock",
            				showSunTimes: "true",
            				lat: "52.4262603",
            				lon: "9.4697593",
              module: 'MMM-NewPIR',
              position: 'top_left',
                  debug: false,
                  screen: {
                    delay: 2 * 60 * 1000,
                    turnOffDisplay: true,
                    ecoMode: true,
                    displayCounter: true,
                    text: "Auto Turn Off Screen:",
                    displayBar: true,
                    displayStyle: "Text",
                    governorSleeping: false,
                    rpi4: false
                  pir: {
                    usePir: true,
                    gpio: 21,
                    reverseValue: false
                  governor: {
                    useGovernor: false,
                    sleeping: "powersave",
                    working: "ondemand"
            			header: "Termine",
            				maximumEntries: "12",
            						symbol: "calendar-check",
            						url: "https://calendar.google.com/calendar/ical/pubtgv6fpslkvd2s4tmd8b4164%40group.calendar.google.com/private-6290764b7af7d5aa6ea139fb4826c33c/basic.ics"					}
                		module: "MMM-Fuel",
                    	api_key: "654340ee-5805-e1c4-279f-13e7afbc6683",
                    	lat: 52.4262603,
                    	lng: 9.4697593,
            		radius: 5,
            		max: 5,
                    	types: ["e5"],
            		sortBy: "e5",
            		rotate: "false",
                    				// all your config options, which are different than their default values
            			module: "compliments",
            			position: "top_center",
            					compliments: {
            					morning: [
            			"Guten Morgen Sonnenschein!",
            			"Hab einen schönen Tag!",
            			"Hast du gut geschlafen?"
            		afternoon: [
            			"Wie war dein Tag?",
            			"Du siehst gut aus heute!",
            			"Schön, dass du wieder da bist!"
            		evening: [
            			"Einen schönen Abend!",
            			"Schlaf gut!",
            		day_sunny: [
            			"Heute ist ein Sonniger Tag",
            			"Es ist ein schöner Tag!"
            		snow: [
            			"Schnee!!!",
            			"Schneeballschlacht!",
            			"Lass uns einen Schneemann bauen!"
            		cloudy: [
            			"Es ist wolkig, hoffentlich regnet es nicht"
            		showers: [
            			"Es schüttet draußen, bleibt lieber Zuhause!"
            		cloudy_windy: [
            			"Windig draußen!",
            			"Halt bloß deine Hose fest"
            		thunderstorm: [
            			"GEWITTER??? WOOOOO? ÜBERALL?!",
            			"Es gewittert draußen!"
            		fog: [
            			"Nebel des Todes of Doom!",
            			"Ganz schön nebelig draußen..."
            		rain: [
            			"Nicht den Regenschirm vergessen!",
            			"Ihh es regnet :("
                        module: 'MMM-Sonos',
                        header: 'Now playing',
                        position: 'bottom_center',
                            animationSpeed: "1000",
                            showFullGroupName: "true",
                            showArtist: "true",
                            showAlbum: "true",
                            showMetadata: "true"
                module: 'MMM-COVID19-SPARKLINE',
            	header: "COVID-19 Fälle",
                  position: "bottom_center",
                  config : {
                    worldStats: true,
                    sparklines: true,
                    sparklineWidth: 100,
                    sparklineHeight: 55,
                    sparklineDays: 50,
                    sparklineDeltavsDaily: false,
                    sortby: "confirmed",
                    columns: ["confirmed", "deaths", "recovered"],
                    countries: ["Germany", "Spain", "Italy", "US"],
                    updateInterval: 1000 * 60 * 60 * 3,  //3 hours
                    infoRowClass: "small",
                    headerRowClass: "small",
                    fadeSpeed: 1000,
                    showDelta: true,
                    showDeltaPlotNDays: 14,
                    showDelimiter: true
            			module: "MMM-OpenmapWeather",
            			header: "Wetter für",
            				units: "metric",
            				degreeLabel: "true",
            				showFeelsLike: "false",
            				showHumidity: "true",
            				useKMPHwind: "true",
            				useBeaufort: "false",
            				colorIcon: "true",
            				lang: "de",
            				locationID: "2805761", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
            				appid: "60328ec38ba3b4f61059f193dff92f13"
            	module: 'MMM-DWD-WarnWeather',
            	position: 'top_right',
            //	header: 'Wetterwarnungen',
            		warnCellID: "803241021",
            		changeColor: true,
            		minutes: false,
            		displayRegionName: true,
            		displayInnerHeader: true,
            		interval: 10 * 60 * 1000, // every 10 minutes
            		loadingText: 'Warnungen werden geladen...',
            		noWarningText: 'Keine Warnungen',
            		severityThreshold: 1
            			module: "weatherforecast",
            			header: "Wettervorhersage für",
            				units: "metric",
            				showRainAmount: "true",
            				lang: "de",
            				scale: "true",
            				colored: "true",
            				appid: "60328ec38ba3b4f61059f193dff92f13",
            				maxNumberOfDays: "7"
            			module: "MMM-DWD-Pollen",
                			header: "Pollenwarnung",
                    			updateInterval: 1 * 60 * 60 * 1000, // every 1 hour1
                    			DWD_region: 32, // Östliches Niedersachsen
            				icon: false // Show icons or not
            	module: "MMM-RAIN-MAP",
            	header: "Regenradar",
            		animationSpeed: 600,
            		displayClockSymbol: true,
            		displayTime: true,
            		extraDelayLastFrame: 500,
            		height: "300px",
            		lat: 52.42580,
            		lng: 9.42944,
            		map: "OSM",
            		markers: [
            		    { lat: 52.42755, lng: 9.47309, color: "blue" }
            		onlyOnRain: false,
            		opacity: 0.65,
            		timeFormat: 24,
            		updateIntervalInSeconds: 300,
            		width: "300px",
            		zoom: 8,
            		zoomOutEach: 3,
            		zoomOutLevel: 3,
            			module: "newsfeed",
            			position: "bottom_bar",
            				feeds: [
            						title: "Tagesschau",
            						url: "http://www.tagesschau.de/xml/rss2"
            						title: "Heise",
            						url: "https://www.heise.de/rss/heise-atom.xml"
            				showSourceTitle: true,
            				showPublishDate: true,
            				broadcastNewsFeeds: true,
            				broadcastNewsUpdates: true
                        module: "MMM-SpaceX",
                            records: 3,
                            modus: "upcoming",
                            showExtraInfo: false,
            		showColumnHeader: true,
                module: 'MMM-WiFiPassword',
                    //See 'Configuration options' for more information.
                    network: "FRITZ!Box 7590 M&K",
                    password: "***",
            		showPassword: true,
              A Former User
              configuration seems good
              do you have any error on start ?
              If you use pm2 -> stop the process and start it manually with npm start command
              give me log or error ?
                DeathForce @Guest
                @Bugsounet
                  A Former User
                  some library missing … do you use npm install command for installing ?
                    DeathForce @Guest
                    @Bugsounet
                    Yes I have stopped MagicMirror and installed the module.
                    pi@PiSmartMirror:~/MagicMirror/modules/MMM-NewPIR $ npm install
                    > MMM-NewPIR@3.0.1 install /home/pi/MagicMirror/modules/MMM-NewPIR
                    > scripts/installer.sh
                    npm notice created a lockfile as package-lock.json. You should commit this file.
                    audited 176 packages in 5.506s
                    4 packages are looking for funding
                      run `npm fund` for details
                    found 0 vulnerabilities
                      A Former User
                      can you try this:
                      bugs@debian:~/MagicMirror/modules/MMM-NewPIR$ rm -rf node_modules/
                      bugs@debian:~/MagicMirror/modules/MMM-NewPIR$ rm package-lock.json
                      bugs@debian:~/MagicMirror/modules/MMM-NewPIR$ npm install
                       epoll@4.0.0 install /home/bugs/MagicMirror/modules/MMM-NewPIR/node_modules/epoll
                       node-gyp rebuild
                      make : on entre dans le répertoire « /home/bugs/MagicMirror/modules/MMM-NewPIR/node_modules/epoll/build »
                        CXX(target) Release/obj.target/epoll/src/epoll.o
                        SOLINK_MODULE(target) Release/obj.target/epoll.node
                        COPY Release/epoll.node
                      make : on quitte le répertoire « /home/bugs/MagicMirror/modules/MMM-NewPIR/node_modules/epoll/build »
                       @bugsounet/pir@1.0.4 postinstall /home/bugs/MagicMirror/modules/MMM-NewPIR/node_modules/@bugsounet/pir
                      > electron-rebuild
                      ✔ Rebuild Complete
                       MMM-NewPIR@3.0.1 install /home/bugs/MagicMirror/modules/MMM-NewPIR
                      added 176 packages from 127 contributors and audited 176 packages in 26.073s
                      bugs@debian:~/MagicMirror/modules/MMM-NewPIR$ cd ~/MagicMirror
                      bugs@debian:~/MagicMirror$ npm start
                        DeathForce @Guest
                        @Bugsounet
                        That’s it. Seems to work now… Thank You :)
                        • 1 / 7
