    MMM-NewPIR v3
    67 Posts 18 Posters 40.4k Views 20 Watching
      A Former User
      configuration seems good
      do you have any error on start ?
      If you use pm2 -> stop the process and start it manually with npm start command
      give me log or error ?
        DeathForce @Guest
        @Bugsounet
          A Former User
          some library missing … do you use npm install command for installing ?
            DeathForce @Guest
            @Bugsounet
            Yes I have stopped MagicMirror and installed the module.
            pi@PiSmartMirror:~/MagicMirror/modules/MMM-NewPIR $ npm install
            > MMM-NewPIR@3.0.1 install /home/pi/MagicMirror/modules/MMM-NewPIR
            > scripts/installer.sh
            npm notice created a lockfile as package-lock.json. You should commit this file.
            audited 176 packages in 5.506s
            4 packages are looking for funding
              run `npm fund` for details
            found 0 vulnerabilities
              A Former User
              can you try this:
              bugs@debian:~/MagicMirror/modules/MMM-NewPIR$ rm -rf node_modules/
              bugs@debian:~/MagicMirror/modules/MMM-NewPIR$ rm package-lock.json
              bugs@debian:~/MagicMirror/modules/MMM-NewPIR$ npm install
               epoll@4.0.0 install /home/bugs/MagicMirror/modules/MMM-NewPIR/node_modules/epoll
               node-gyp rebuild
              make : on entre dans le répertoire « /home/bugs/MagicMirror/modules/MMM-NewPIR/node_modules/epoll/build »
                CXX(target) Release/obj.target/epoll/src/epoll.o
                SOLINK_MODULE(target) Release/obj.target/epoll.node
                COPY Release/epoll.node
              make : on quitte le répertoire « /home/bugs/MagicMirror/modules/MMM-NewPIR/node_modules/epoll/build »
               @bugsounet/pir@1.0.4 postinstall /home/bugs/MagicMirror/modules/MMM-NewPIR/node_modules/@bugsounet/pir
              > electron-rebuild
              ✔ Rebuild Complete
               MMM-NewPIR@3.0.1 install /home/bugs/MagicMirror/modules/MMM-NewPIR
              added 176 packages from 127 contributors and audited 176 packages in 26.073s
              bugs@debian:~/MagicMirror/modules/MMM-NewPIR$ cd ~/MagicMirror
              bugs@debian:~/MagicMirror$ npm start
                DeathForce @Guest
                @Bugsounet
                That’s it. Seems to work now… Thank You :)
                  A Former User
                  perfect so :)
                  when it want to works, it's magical
                    bdream
                    Hi @Bugsounet just going to install your module with deep hope in it’s functionality.
                    I’m going to use it on an Pi0 and get (now two times) an Network error: Software caused connection aborton Putty while npm install
                    Here all I get in console:
                    pi@RasPiZeroW:~/MagicMirror/modules/MMM-NewPIR $ npm install
                    > epoll@4.0.0 install /home/pi/MagicMirror/modules/MMM-NewPIR/node_modules/epoll
                    > node-gyp rebuild
                    make: Verzeichnis „/home/pi/MagicMirror/modules/MMM-NewPIR/node_modules/epoll/build“ wird betreten
                    Any idea, or is it caused on the hardware of RPi0?
                    I tried to start again and deleted all MMM-NewPIR stuff and rebootet RPi.
                    New attempt git clone and npm install
                    Getting this in coonsole:
                    > node-gyp rebuild
                    make: Verzeichnis „/home/pi/MagicMirror/modules/MMM-NewPIR/node_modules/epoll/build“ wird verlassen
                    > @bugsounet/pir@1.0.4 postinstall /home/pi/MagicMirror/modules/MMM-NewPIR/node_modules/@bugsounet/pir
                    > electron-rebuild
                    ⠸ Building module: epoll, Completed: 0
                    and status ⠸ Building module: epoll, Completed: 0 is not changing colpetition even it run and run.
                    So I assume it’s really related to RPi0 installation and electron. But that is to deep for my small knowledge selfsolving if possible anyway.
                    cheers, bdream
                    • FoziF
                      Fozi Project Sponsor
                      Thanks for this new PIR module! I replaced last night the MMM-PIR-sensor module with yours and it works perfectly, also with my microwave sensor.
                      Especially the behaviour after the first start is now as expected, as the display is switches off after the countdown, without initializing the sensor first. With MMM-PIR-sensor the display would have stayed on after the first start until the sensor catches once a motion and the start the coutdown. I tweaked the node_helper.js to correct that, but after each module update I had to reapply that tweek. That belongs now to the past. Great job!:clapping_hands_light_skin_tone:
                      I have a feature request:
                      I would like to have two configuration options available to adjust the colours of “displayStyle”, as currently it is hardcoded in green:
                      • One option to adjust the colour of the remaining time (wich is currently green).
                      • Another option to adjust the colour of the past time (currently dark grey or white).
                      something like this:
                      displayStyleRemaining: 'e2e2e2', //RGB value of the remaining time
                      displayStylePast: '454545', //RGB value of the past time
                      I’m using the “Bar” style on “bottom_bar” position, which shows a decent thin line over the hole width of the mirror, which slowly creeps down to the left. But it is hard to distinguish the remaining time (green) and the past time (white) of that bar. I would prefer to adjust the remaining time to white, and the past time to black, as an example.
                      What do you think?
                      Oh BTW: I might help other users, if you enhance a little bit the README on GitHub on how to make the display styles visible. It took me some trials until I found out to configure an empty string for the “text” option to make the other styles show up.
                        A Former User @bdream
                        @bdream :
                        > electron-rebuild
                        it’s a very very long processing for a pi0 but needed …
                        I never try with it, i don’t know how time it can take (and if it’s works !)
                        @Fozi : thanks for you feedback !
                        NP v3 is result of a lot of works ;)
                        First it’s part of code from another module (Assistant2Display).
                        NP v3 is make for user who don’t want (don’t use or don’t know) to use GoogleAssistant/Assistant2Display
                        I port it to NP v3 with my own npm library (less code and sync all code for all my modules)
                        I have to code the new feature from Assistant2Display (Last Presence display) to NV v3
                        If you want you can do a Pull request do add your wanted feature ;)
                        if you want to do it, you can make it in dev branch (for temp code and developping) and not in master (only for releasing)
                        So Pull request is welcome :)
                        • FoziF
                          Fozi Project Sponsor @Guest
                          Well, that means I‘ll have get much much deeper into coding and learn js. But hey, why not? Cold and dark autumn is coming and that’ll be a nice project 🤗
                            A Former User
                            the hardest part is to anticipate the slightest possible error so as not to crash everything (and even crash MM)
                            If you can’t do it, i will do it soon :)
                            I finish other new module before ;)
                            so planned to this module:
                            • Last presence
                            • color feature
                            • HDMI CEC support
                            ? 1 Reply Last reply Reply Quote 1
                              bdream
                              @Bugsounet don’t know how time it can take (and if it’s works !)
                              After a couple of trys it run to end but in time including MMM-NewPIR into config (smallest example or within many configurations…) mirror give error as config not available.
                              I hang it up an the RPi0
                              Will try it soon on an RPi3B as I feel this is a great module. - thanks for providing!
                              cheers, bdream
                                A Former User
                                memory less in pi0, so it’s difficult to do complex think with it
                                • H
                                  hweigel
                                  Hi Cedric,
                                  I’ve received an update notification for this module, but something must have happened on Github:
                                  pi@MagicMirror:~/MagicMirror/modules/MMM-NewPIR $ git pull
                                  Username for 'https://github.com': XXX.YYY@gmail.com
                                  Password for 'https://helmut.weigel@gmail.com@github.com':
                                  remote: Repository not found.
                                  fatal: repository 'https://github.com/bugsounet/MMM-NewPIR.git/' not found
                                  Please advise.
                                    dvbit
                                    currently all modules developed by bougsounet are offline due to some issue with MM project founder.
                                    If you want them to go back online please invite the MM project owner, michmich, to have a dialogue.
                                      dvbit
                                      that is go here and ask for open dialogue https://github.com/MichMich/MagicMirror/issues/2130
                                      • rejasR
                                        rejas Module Developer
                                        I do not think that this issue in github is the correct place to have a dialogue about this topic. Either have it here in the forum or create a new issue there, but dont put non-issue related discussions into tickets.
                                          dvbit
                                          Yes you are right. I would just like dialogue to start.
                                            A Former User @rejas
                                            @rejas : LOL ! :clapping_hands: :clapping_hands: :clapping_hands:
                                            No dialogue possible, so I decide to BAN all my module when using original MagicMirror app
                                            I will recode another MagicMirror (with change !)
                                            After … it will be the user’s choice … follow me or not !
                                            See : There
                                            @rejas : make as you want … you can BAN me if you want :)
                                            it’s not a problem for me !
                                            I do ANY of my module for me in first ! so it’s not a problem ;)
                                            as long as it works for me, I don’t care!
                                            I just share my work
                                            so :zipper-mouth_face: !!!
                                            • 1 / 4
