    MMM-NewPIR v3
    67 Posts 18 Posters 41.1k Views 20 Watching
      DeathForce @Guest
      @Bugsounet
      Yes I have stopped MagicMirror and installed the module.
      pi@PiSmartMirror:~/MagicMirror/modules/MMM-NewPIR $ npm install
      > MMM-NewPIR@3.0.1 install /home/pi/MagicMirror/modules/MMM-NewPIR
      > scripts/installer.sh
      npm notice created a lockfile as package-lock.json. You should commit this file.
      audited 176 packages in 5.506s
      4 packages are looking for funding
        run `npm fund` for details
      found 0 vulnerabilities
        A Former User
        can you try this:
        bugs@debian:~/MagicMirror/modules/MMM-NewPIR$ rm -rf node_modules/
        bugs@debian:~/MagicMirror/modules/MMM-NewPIR$ rm package-lock.json
        bugs@debian:~/MagicMirror/modules/MMM-NewPIR$ npm install
         epoll@4.0.0 install /home/bugs/MagicMirror/modules/MMM-NewPIR/node_modules/epoll
         node-gyp rebuild
        make : on entre dans le répertoire « /home/bugs/MagicMirror/modules/MMM-NewPIR/node_modules/epoll/build »
          CXX(target) Release/obj.target/epoll/src/epoll.o
          SOLINK_MODULE(target) Release/obj.target/epoll.node
          COPY Release/epoll.node
        make : on quitte le répertoire « /home/bugs/MagicMirror/modules/MMM-NewPIR/node_modules/epoll/build »
         @bugsounet/pir@1.0.4 postinstall /home/bugs/MagicMirror/modules/MMM-NewPIR/node_modules/@bugsounet/pir
        > electron-rebuild
        ✔ Rebuild Complete
         MMM-NewPIR@3.0.1 install /home/bugs/MagicMirror/modules/MMM-NewPIR
        added 176 packages from 127 contributors and audited 176 packages in 26.073s
        bugs@debian:~/MagicMirror/modules/MMM-NewPIR$ cd ~/MagicMirror
        bugs@debian:~/MagicMirror$ npm start
        D 1 Reply Last reply
          DeathForce @Guest
          @Bugsounet
          That’s it. Seems to work now… Thank You :)
            A Former User
            perfect so :)
            when it want to works, it's magical
              bdream
              Hi @Bugsounet just going to install your module with deep hope in it’s functionality.
              I’m going to use it on an Pi0 and get (now two times) an Network error: Software caused connection aborton Putty while npm install
              Here all I get in console:
              pi@RasPiZeroW:~/MagicMirror/modules/MMM-NewPIR $ npm install
              > epoll@4.0.0 install /home/pi/MagicMirror/modules/MMM-NewPIR/node_modules/epoll
              > node-gyp rebuild
              make: Verzeichnis „/home/pi/MagicMirror/modules/MMM-NewPIR/node_modules/epoll/build“ wird betreten
              Any idea, or is it caused on the hardware of RPi0?
              I tried to start again and deleted all MMM-NewPIR stuff and rebootet RPi.
              New attempt git clone and npm install
              Getting this in coonsole:
              > node-gyp rebuild
              make: Verzeichnis „/home/pi/MagicMirror/modules/MMM-NewPIR/node_modules/epoll/build“ wird verlassen
              > @bugsounet/pir@1.0.4 postinstall /home/pi/MagicMirror/modules/MMM-NewPIR/node_modules/@bugsounet/pir
              > electron-rebuild
              ⠸ Building module: epoll, Completed: 0
              and status ⠸ Building module: epoll, Completed: 0 is not changing colpetition even it run and run.
              So I assume it’s really related to RPi0 installation and electron. But that is to deep for my small knowledge selfsolving if possible anyway.
              cheers, bdream
              ? 1 Reply Last reply
              • FoziF
                Fozi Project Sponsor
                Thanks for this new PIR module! I replaced last night the MMM-PIR-sensor module with yours and it works perfectly, also with my microwave sensor.
                Especially the behaviour after the first start is now as expected, as the display is switches off after the countdown, without initializing the sensor first. With MMM-PIR-sensor the display would have stayed on after the first start until the sensor catches once a motion and the start the coutdown. I tweaked the node_helper.js to correct that, but after each module update I had to reapply that tweek. That belongs now to the past. Great job!:clapping_hands_light_skin_tone:
                I have a feature request:
                I would like to have two configuration options available to adjust the colours of “displayStyle”, as currently it is hardcoded in green:
                • One option to adjust the colour of the remaining time (wich is currently green).
                • Another option to adjust the colour of the past time (currently dark grey or white).
                something like this:
                displayStyleRemaining: 'e2e2e2', //RGB value of the remaining time
                displayStylePast: '454545', //RGB value of the past time
                I’m using the “Bar” style on “bottom_bar” position, which shows a decent thin line over the hole width of the mirror, which slowly creeps down to the left. But it is hard to distinguish the remaining time (green) and the past time (white) of that bar. I would prefer to adjust the remaining time to white, and the past time to black, as an example.
                What do you think?
                Oh BTW: I might help other users, if you enhance a little bit the README on GitHub on how to make the display styles visible. It took me some trials until I found out to configure an empty string for the “text” option to make the other styles show up.
                  A Former User @bdream
                  @bdream :
                  > electron-rebuild
                  it’s a very very long processing for a pi0 but needed …
                  I never try with it, i don’t know how time it can take (and if it’s works !)
                  @Fozi : thanks for you feedback !
                  NP v3 is result of a lot of works ;)
                  First it’s part of code from another module (Assistant2Display).
                  NP v3 is make for user who don’t want (don’t use or don’t know) to use GoogleAssistant/Assistant2Display
                  I port it to NP v3 with my own npm library (less code and sync all code for all my modules)
                  I have to code the new feature from Assistant2Display (Last Presence display) to NV v3
                  If you want you can do a Pull request do add your wanted feature ;)
                  if you want to do it, you can make it in dev branch (for temp code and developping) and not in master (only for releasing)
                  So Pull request is welcome :)
                  FoziF 1 Reply Last reply
                  • FoziF
                    Fozi Project Sponsor @Guest
                    Well, that means I‘ll have get much much deeper into coding and learn js. But hey, why not? Cold and dark autumn is coming and that’ll be a nice project 🤗
                      A Former User
                      the hardest part is to anticipate the slightest possible error so as not to crash everything (and even crash MM)
                      If you can’t do it, i will do it soon :)
                      I finish other new module before ;)
                      so planned to this module:
                      • Last presence
                      • color feature
                      • HDMI CEC support
                        bdream
                        @Bugsounet don’t know how time it can take (and if it’s works !)
                        After a couple of trys it run to end but in time including MMM-NewPIR into config (smallest example or within many configurations…) mirror give error as config not available.
                        I hang it up an the RPi0
                        Will try it soon on an RPi3B as I feel this is a great module. - thanks for providing!
                        cheers, bdream
                          A Former User
                          memory less in pi0, so it’s difficult to do complex think with it
                          • H
                            hweigel
                            Hi Cedric,
                            I’ve received an update notification for this module, but something must have happened on Github:
                            pi@MagicMirror:~/MagicMirror/modules/MMM-NewPIR $ git pull
                            Username for 'https://github.com': XXX.YYY@gmail.com
                            Password for 'https://helmut.weigel@gmail.com@github.com':
                            remote: Repository not found.
                            fatal: repository 'https://github.com/bugsounet/MMM-NewPIR.git/' not found
                            Please advise.
                              dvbit
                              currently all modules developed by bougsounet are offline due to some issue with MM project founder.
                              If you want them to go back online please invite the MM project owner, michmich, to have a dialogue.
                                dvbit
                                that is go here and ask for open dialogue https://github.com/MichMich/MagicMirror/issues/2130
                                • rejasR
                                  rejas Module Developer
                                  I do not think that this issue in github is the correct place to have a dialogue about this topic. Either have it here in the forum or create a new issue there, but dont put non-issue related discussions into tickets.
                                    dvbit
                                    Yes you are right. I would just like dialogue to start.
                                      A Former User @rejas
                                      @rejas : LOL ! :clapping_hands: :clapping_hands: :clapping_hands:
                                      No dialogue possible, so I decide to BAN all my module when using original MagicMirror app
                                      I will recode another MagicMirror (with change !)
                                      After … it will be the user’s choice … follow me or not !
                                      See : There
                                      @rejas : make as you want … you can BAN me if you want :)
                                      it’s not a problem for me !
                                      I do ANY of my module for me in first ! so it’s not a problem ;)
                                      as long as it works for me, I don’t care!
                                      I just share my work
                                      so :zipper-mouth_face: !!!
                                      • rejasR
                                        @dvbit as you can see there isn’t a dialogue possible with bugsounet. Even though @michmich made a step forward to him and had his PR merged he still wants to make his own version of MM with some secure stuff to not allow other users to run his modules on the original code. Not to mention his signature.
                                        Tell me @dvbit, is that a person you want to work with or where you want to trust your your personal data that you put into the Google-Assistant module of his? I sure don’t and thats my choice in the OpenSource world. As is his choice to behave like that.
                                        Don’t forget, it was @MichMich that did all the work before that, starting Magic@Miror, doing the forums, maintaining the code. He is still around and is open for discussion and ideas. That’s the kind of person I want to work with and where I want to put my efforts into that.
                                        • FoziF
                                          I’ve been a few days of and ran through my timelines and found this dispute here and on GitHub and must say I feel kind of sad and disappointed. Since the day I joint this community nearly a year ago it always felt like home. Everybody was helpful and patient, I always felt mutual respect and appreciation. Not to mention all those fantastic contributors with their modules and programming skills and those with various other knowledge they happily share. While I can understand @Bugsounet for waiting for @MichMich response quite some time and his engagement, I also see MichMich point which he laid out on GitHub. I don’t know what both have exchanged on other, private, channels but I can’t understand why such a dispute leads to such a extreme reaction. In the end it is the community that gets punished, when great modules are withdrawn and support is ceased. That’s sad!
                                          As @Bugsounet is insistently not willing to contribute any more and to support, I have no other choice than to drop this module here and return to the old one. It is really a pitty and I do this very heavy hearted but travelers shouldn’t be halted.
                                          I wish you all the best and great success with your own fork -I say this absolutely honestly- but still hope to see you here around again one day.
                                            A Former User @Fozi
                                            @Fozi No one know my problem with mich. (hein rejas, so stop tell bad things)
                                            So, I will recode another MagicMirror system… After it will be user choice… Fallow me in the new adventure with all @bugsounet module or… Mich Migic mirror without Any of my modules
                                            Actually I do a mix of npm library and my magic mirror app (personal… I have to replace all patch of MagicMirror corrected…)
                                            • 1 / 4
