    MMM-NewPIR v3
    67 Posts 18 Posters 40.4k Views 20 Watching
      A Former User @bdream
      @bdream :
      > @bugsounet/pir@1.0.4 postinstall /home/pi/MagicMirror/modules/MMM-NewPIR/node_modules/@bugsounet/pir
      > electron-rebuild
      ⠸ Building module: epoll, Completed: 0
      it’s a very very long processing for a pi0 but needed …
      I never try with it, i don’t know how time it can take (and if it’s works !)
      @Fozi : thanks for you feedback !
      NP v3 is result of a lot of works ;)
      First it’s part of code from another module (Assistant2Display).
      NP v3 is make for user who don’t want (don’t use or don’t know) to use GoogleAssistant/Assistant2Display
      I port it to NP v3 with my own npm library (less code and sync all code for all my modules)
      I have to code the new feature from Assistant2Display (Last Presence display) to NV v3
      If you want you can do a Pull request do add your wanted feature ;)
      if you want to do it, you can make it in dev branch (for temp code and developping) and not in master (only for releasing)
      So Pull request is welcome :)
      • FoziF
        Fozi Project Sponsor @Guest
        Well, that means I‘ll have get much much deeper into coding and learn js. But hey, why not? Cold and dark autumn is coming and that’ll be a nice project 🤗
          A Former User
          the hardest part is to anticipate the slightest possible error so as not to crash everything (and even crash MM)
          If you can’t do it, i will do it soon :)
          I finish other new module before ;)
          so planned to this module:
          • Last presence
          • color feature
          • HDMI CEC support
          ? 1 Reply Last reply Reply Quote 1
            bdream
            @Bugsounet don’t know how time it can take (and if it’s works !)
            After a couple of trys it run to end but in time including MMM-NewPIR into config (smallest example or within many configurations…) mirror give error as config not available.
            I hang it up an the RPi0
            Will try it soon on an RPi3B as I feel this is a great module. - thanks for providing!
            cheers, bdream
              A Former User
              memory less in pi0, so it’s difficult to do complex think with it
              • H
                hweigel
                Hi Cedric,
                I’ve received an update notification for this module, but something must have happened on Github:
                pi@MagicMirror:~/MagicMirror/modules/MMM-NewPIR $ git pull
                Username for 'https://github.com': XXX.YYY@gmail.com
                Password for 'https://helmut.weigel@gmail.com@github.com':
                remote: Repository not found.
                fatal: repository 'https://github.com/bugsounet/MMM-NewPIR.git/' not found
                Please advise.
                  dvbit
                  currently all modules developed by bougsounet are offline due to some issue with MM project founder.
                  If you want them to go back online please invite the MM project owner, michmich, to have a dialogue.
                    dvbit
                    that is go here and ask for open dialogue https://github.com/MichMich/MagicMirror/issues/2130
                    • rejasR
                      rejas Module Developer
                      I do not think that this issue in github is the correct place to have a dialogue about this topic. Either have it here in the forum or create a new issue there, but dont put non-issue related discussions into tickets.
                        dvbit
                        Yes you are right. I would just like dialogue to start.
                          A Former User @rejas
                          @rejas : LOL ! :clapping_hands: :clapping_hands: :clapping_hands:
                          No dialogue possible, so I decide to BAN all my module when using original MagicMirror app
                          I will recode another MagicMirror (with change !)
                          After … it will be the user’s choice … follow me or not !
                          See : There
                          @rejas : make as you want … you can BAN me if you want :)
                          it’s not a problem for me !
                          I do ANY of my module for me in first ! so it’s not a problem ;)
                          as long as it works for me, I don’t care!
                          I just share my work
                          so :zipper-mouth_face: !!!
                          • rejasR
                            @dvbit as you can see there isn’t a dialogue possible with bugsounet. Even though @michmich made a step forward to him and had his PR merged he still wants to make his own version of MM with some secure stuff to not allow other users to run his modules on the original code. Not to mention his signature.
                            Tell me @dvbit, is that a person you want to work with or where you want to trust your your personal data that you put into the Google-Assistant module of his? I sure don’t and thats my choice in the OpenSource world. As is his choice to behave like that.
                            Don’t forget, it was @MichMich that did all the work before that, starting Magic@Miror, doing the forums, maintaining the code. He is still around and is open for discussion and ideas. That’s the kind of person I want to work with and where I want to put my efforts into that.
                            • FoziF
                              I’ve been a few days of and ran through my timelines and found this dispute here and on GitHub and must say I feel kind of sad and disappointed. Since the day I joint this community nearly a year ago it always felt like home. Everybody was helpful and patient, I always felt mutual respect and appreciation. Not to mention all those fantastic contributors with their modules and programming skills and those with various other knowledge they happily share. While I can understand @Bugsounet for waiting for @MichMich response quite some time and his engagement, I also see MichMich point which he laid out on GitHub. I don’t know what both have exchanged on other, private, channels but I can’t understand why such a dispute leads to such a extreme reaction. In the end it is the community that gets punished, when great modules are withdrawn and support is ceased. That’s sad!
                              As @Bugsounet is insistently not willing to contribute any more and to support, I have no other choice than to drop this module here and return to the old one. It is really a pitty and I do this very heavy hearted but travelers shouldn’t be halted.
                              I wish you all the best and great success with your own fork -I say this absolutely honestly- but still hope to see you here around again one day.
                                A Former User @Fozi
                                @Fozi No one know my problem with mich. (hein rejas, so stop tell bad things)
                                So, I will recode another MagicMirror system… After it will be user choice… Fallow me in the new adventure with all @bugsounet module or… Mich Migic mirror without Any of my modules
                                Actually I do a mix of npm library and my magic mirror app (personal… I have to replace all patch of MagicMirror corrected…)
                                  A Former User @Guest
                                  @Bugsounet said in MMM-NewPIR v3:
                                  • Last presence
                                  • color feature
                                  • HDMI CEC support
                                  under coding :)
                                    A Former User
                                    V3.1.0 is out !
                                    • added : HDMI CEC support and other mode for turn on/off your screen
                                    mode: 1 - use vgencmd (RPI only)
                                    mode: 2 - use dpms (version RPI)
                                    mode: 3 - use tvservice (RPI only)
                                    mode: 4 - use HDMI CEC
                                    mode: 5 - use dpms (linux version for debian, ubuntu, …)
                                    mode: 0 - disabled and turnOffDisplay too
                                    see new configuration of the screen field
                                    • added: display last presence time
                                    • added: auto updater script (npm run update)
                                    • added: notify if update of npm library is available
                                    • added: compatibility with MMM-UpdateNotification for automatic update
                                    • deleted: configMerge script and use MM version integred (configDeepMerge: true,)
                                      A Former User
                                      v3.1.2 is out !
                                      I have coded TouchScreen feature
                                      TouchScreen Feature
                                      You can use this feature with a mouse or your touch screen
                                      • One Click on the screen: Will wake up the screen or restart your shutdown timer
                                      • Double Click on the screen: Will turn off your screen
                                      Edit: see next release
                                        A Former User
                                        v3.1.3 is out !
                                        Touch Screen feature change
                                        TouchScreen Feature
                                        • One Click on the NewPIR Area: will restart your shutdown timer
                                        • Long Click on the screen: Will turn off your screen or Will turn on if needed (Toogle)
                                        if you want to use it:
                                        enable useTouch feature in screen: {} field
                                        CSS value correct
                                        Correct a bug if no other module in the same position is set (module not displayed)
                                        Update of @bugsounet/screen npm library
                                        Counter will send bad value on start (lost one sec.)
                                        • kusselinK
                                          kusselin
                                          Hi, can i use this module without a sensor? As yes is everyone here who can explain me how i must go on to start the module without a sensor…
                                          And…what sensor must i have that i can realize this module. Have anyone a link where i can buy it?
                                          Best regards
                                            pakal41
                                            takes PIR sensor HC-SR501 it works on , perso
                                            I ordered to see a Doppler Microwave Sensor RCWL-0516 to replace HC SR501
                                            see topic
                                            https://forum.magicmirror.builders/topic/11704/update-replaced-my-pir-sensor-with-a-doppler-microwave-sensor
                                            ( more aesthetic )
                                            • 2 / 4
