    MMM-NewPIR v3
    67 Posts 18 Posters 38.7k Views 20 Watching
      [[global:former-user]] @rejas
      @rejas : LOL ! :clapping_hands: :clapping_hands: :clapping_hands:
      No dialogue possible, so I decide to BAN all my module when using original MagicMirror app
      I will recode another MagicMirror (with change !)
      After … it will be the user’s choice … follow me or not !
      See : There
      @rejas : make as you want … you can BAN me if you want :)
      it’s not a problem for me !
      I do ANY of my module for me in first ! so it’s not a problem ;)
      as long as it works for me, I don’t care!
      I just share my work
      so :zipper-mouth_face: !!!
      • rejasR Offline
        rejas Module Developer
        @dvbit as you can see there isn’t a dialogue possible with bugsounet. Even though @michmich made a step forward to him and had his PR merged he still wants to make his own version of MM with some secure stuff to not allow other users to run his modules on the original code. Not to mention his signature.
        Tell me @dvbit, is that a person you want to work with or where you want to trust your your personal data that you put into the Google-Assistant module of his? I sure don’t and thats my choice in the OpenSource world. As is his choice to behave like that.
        Don’t forget, it was @MichMich that did all the work before that, starting Magic@Miror, doing the forums, maintaining the code. He is still around and is open for discussion and ideas. That’s the kind of person I want to work with and where I want to put my efforts into that.
        • FoziF Offline
          Fozi Project Sponsor
          I’ve been a few days of and ran through my timelines and found this dispute here and on GitHub and must say I feel kind of sad and disappointed. Since the day I joint this community nearly a year ago it always felt like home. Everybody was helpful and patient, I always felt mutual respect and appreciation. Not to mention all those fantastic contributors with their modules and programming skills and those with various other knowledge they happily share. While I can understand @Bugsounet for waiting for @MichMich response quite some time and his engagement, I also see MichMich point which he laid out on GitHub. I don’t know what both have exchanged on other, private, channels but I can’t understand why such a dispute leads to such a extreme reaction. In the end it is the community that gets punished, when great modules are withdrawn and support is ceased. That’s sad!
          As @Bugsounet is insistently not willing to contribute any more and to support, I have no other choice than to drop this module here and return to the old one. It is really a pitty and I do this very heavy hearted but travelers shouldn’t be halted.
          I wish you all the best and great success with your own fork -I say this absolutely honestly- but still hope to see you here around again one day.
          ? 1 Reply Last reply Reply Quote 1
            [[global:former-user]] @Fozi
            @Fozi No one know my problem with mich. (hein rejas, so stop tell bad things)
            So, I will recode another MagicMirror system… After it will be user choice… Fallow me in the new adventure with all @bugsounet module or… Mich Migic mirror without Any of my modules
            Actually I do a mix of npm library and my magic mirror app (personal… I have to replace all patch of MagicMirror corrected…)
              [[global:former-user]] @Guest
              @Bugsounet said in MMM-NewPIR v3:
              the hardest part is to anticipate the slightest possible error so as not to crash everything (and even crash MM)
              If you can’t do it, i will do it soon :)
              I finish other new module before ;)
              so planned to this module:
              • Last presence
              • color feature
              • HDMI CEC support
              under coding :)
                V3.1.0 is out !
                • added : HDMI CEC support and other mode for turn on/off your screen
                mode: 1 - use vgencmd (RPI only)
                mode: 2 - use dpms (version RPI)
                mode: 3 - use tvservice (RPI only)
                mode: 4 - use HDMI CEC
                mode: 5 - use dpms (linux version for debian, ubuntu, …)
                mode: 0 - disabled and turnOffDisplay too
                see new configuration of the screen field
                • added: display last presence time
                • added: auto updater script (npm run update)
                • added: notify if update of npm library is available
                • added: compatibility with MMM-UpdateNotification for automatic update
                • deleted: configMerge script and use MM version integred (configDeepMerge: true,)
                  v3.1.2 is out !
                  I have coded TouchScreen feature
                  TouchScreen Feature
                  You can use this feature with a mouse or your touch screen
                  • One Click on the screen: Will wake up the screen or restart your shutdown timer
                  • Double Click on the screen: Will turn off your screen
                  Edit: see next release
                    v3.1.3 is out !
                    Touch Screen feature change
                    TouchScreen Feature
                    • One Click on the NewPIR Area: will restart your shutdown timer
                    • Long Click on the screen: Will turn off your screen or Will turn on if needed (Toogle)
                    if you want to use it:
                    enable useTouch feature in screen: {} field
                    CSS value correct
                    Correct a bug if no other module in the same position is set (module not displayed)
                    Update of @bugsounet/screen npm library
                    Counter will send bad value on start (lost one sec.)
                    • kusselinK Offline
                      kusselin
                      Hi, can i use this module without a sensor? As yes is everyone here who can explain me how i must go on to start the module without a sensor…
                      And…what sensor must i have that i can realize this module. Have anyone a link where i can buy it?
                      Best regards
                        pakal41
                        takes PIR sensor HC-SR501 it works on , perso
                        I ordered to see a Doppler Microwave Sensor RCWL-0516 to replace HC SR501
                        see topic
                        https://forum.magicmirror.builders/topic/11704/update-replaced-my-pir-sensor-with-a-doppler-microwave-sensor
                        ( more aesthetic )
                          v3.1.5 is out!
                          added: many mode for touch screen use
                          added: delayed activating screen
                          see ReadMe File for more informations
                          • FoziF Offline
                            Fozi Project Sponsor @pakal41
                            @pakal41 I can assure you that the Doppler sensor will work 😃
                            • L Offline
                              lolo @Guest
                              @Bugsounet With new version of MagicMirror I decides to try this module.
                              Running rpi4 with HC-SR501 sensor.
                              Can you please explain me how exactly ecoMode working. I have some problems with that enabled true. I’m still trying to figure out exactly problem but no luck. I’m using MMM-Globe by Eunanibus and its not reloading (not showing ) after monitor is turn on and sometime even monitor doesn’t wont to turn on. Should I just keep this option false? With ecoMode false at the moment everything is working fine.
                              Anyway, great work and thank you for your contribution.
                                [[global:former-user]] @lolo
                                @lolo ecoMode Feature hide all modules (disable modules), after maybe your globe module have a bug on disable/resume (this fonction is a function coded in the core of MM)
                                • L Offline
                                  lolo
                                  Thx. Even one my module have problem with that. For now I will keep it as false.
                                    bdream
                                    It’s working :smiling_face_with_open_mouth:
                                    After a couple of tries with all available PIR Modules it’s working with MMM-NewPIR perfect!
                                    Many thanks!
                                    cheers, bdream
                                      bdream
                                      …Ohh no.
                                      Getting update notification for MMM-NewPIR.
                                      I’m trying in MagicMirror/modules/MMM-NewPIR
                                      git pull
                                      but get the message “it’s actual already”
                                      Notification message still there.
                                      Any idea please?
                                      cheers, bdream
                                      • FoziF Offline
                                        I had the same. After
                                        git pull
                                        Enter
                                        mom run update
                                        and reboot.
                                          bdream
                                          where to run mom run update?
                                          I tried in home, MagicMirror, modules and MMM-NewPIR
                                          got th message
                                          -bash: mom: Kommando nicht gefunden.
                                          -bash: mom: Command not found.
                                          cheers, bdream
                                            bdream @bdream
                                            Hast noone an Idea how to get rid of thus Update Message?
                                            cheers, bdream
                                            • 2 / 4
