    MMM-NewPIR v3
    67 Posts 18 Posters 39.3k Views 20 Watching
      A Former User
      MMM-NewPIR (v3)
      It uses a PIR sensor attached to your raspberry pi’s GPIO pins to check for users. After a configurated time without any user interaction the display will turn off and hide all module for economy mode.
      If you don’t have PIR sensor, it can also be used for automatic turn on / turn off screen.
      What’s new on V3 ?
      • Rewrite entire main code
      • New configuration
      • Use my own shared npm library
      • Add new display style
      • More tools: incomming notification for developers
      Screenshot
      Developer Notes
      • This module broadcasts:
        • USER_PRESENCE notification with the payload beeing true or false you can use it to pause or disable another module.
      • This module receive:
        • USER_PRESENCE notification with the payload true to force user presence or false to force delay to time out.
        • SCREEN_END notification to force the end of the count down
        • SCREEN_WAKEUP notification to wake up the screen and reset count down
        • SCREEN_LOCK notification keep the screen on and lock it (freeze counter and stop pir detection)
        • SCREEN_UNLOCK notification unlock the screen and restart counter and pir detection
        DeathForce
        Hello, unfortunately I need some help.
        I have installed the module but as soon as I edit the config magicmirror does not start anymore.
          A Former User
          what’s your config ?
            DeathForce @Guest
            @Bugsounet
            /* Magic Mirror Config Sample
             * By Michael Teeuw https://michaelteeuw.nl
             * MIT Licensed.
            var config = {
            	address: "localhost", 	// Address to listen on, can be:
            	port: 8080,
            	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
            	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
            	language: "de",
            	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
            	timeFormat: 24,
            	units: "metric",
                        module: 'MMM-Carousel',
                            transitionInterval: 10000,
                            ignoreModules: ['clock', 'alert', 'calendar', 'MMM-Fuel', 'MMM-Sonos', 'MMM-OpenmapWeather', 'weatherforecast', 'MMM-DWD-Pollen', 'MMM-DWD-WarnWeather', 'newsfeed'],
                            mode: 'positional',
                            top_left: {enabled: true, ignoreModules: ['clock', 'MMM-Fuel', 'calendar']},
            				top_right: {enabled: false, ignoreModules: ['MMM-OpenmapWeather', 'MMM-DWD-WarnWeather', 'weatherforecast', ], overrideTransitionInterval: 20000}
            			module: "alert",
            			module: "updatenotification",
            			position: "top_bar"
            			module: "clock",
            				showSunTimes: "true",
            				lat: "52.4262603",
            				lon: "9.4697593",
              module: 'MMM-NewPIR',
              position: 'top_left',
                  debug: false,
                  screen: {
                    delay: 2 * 60 * 1000,
                    turnOffDisplay: true,
                    ecoMode: true,
                    displayCounter: true,
                    text: "Auto Turn Off Screen:",
                    displayBar: true,
                    displayStyle: "Text",
                    governorSleeping: false,
                    rpi4: false
                  pir: {
                    usePir: true,
                    gpio: 21,
                    reverseValue: false
                  governor: {
                    useGovernor: false,
                    sleeping: "powersave",
                    working: "ondemand"
            			header: "Termine",
            				maximumEntries: "12",
            						symbol: "calendar-check",
            						url: "https://calendar.google.com/calendar/ical/pubtgv6fpslkvd2s4tmd8b4164%40group.calendar.google.com/private-6290764b7af7d5aa6ea139fb4826c33c/basic.ics"					}
                		module: "MMM-Fuel",
                    	api_key: "654340ee-5805-e1c4-279f-13e7afbc6683",
                    	lat: 52.4262603,
                    	lng: 9.4697593,
            		radius: 5,
            		max: 5,
                    	types: ["e5"],
            		sortBy: "e5",
            		rotate: "false",
                    				// all your config options, which are different than their default values
            			module: "compliments",
            			position: "top_center",
            					compliments: {
            					morning: [
            			"Guten Morgen Sonnenschein!",
            			"Hab einen schönen Tag!",
            			"Hast du gut geschlafen?"
            		afternoon: [
            			"Wie war dein Tag?",
            			"Du siehst gut aus heute!",
            			"Schön, dass du wieder da bist!"
            		evening: [
            			"Einen schönen Abend!",
            			"Schlaf gut!",
            		day_sunny: [
            			"Heute ist ein Sonniger Tag",
            			"Es ist ein schöner Tag!"
            		snow: [
            			"Schnee!!!",
            			"Schneeballschlacht!",
            			"Lass uns einen Schneemann bauen!"
            		cloudy: [
            			"Es ist wolkig, hoffentlich regnet es nicht"
            		showers: [
            			"Es schüttet draußen, bleibt lieber Zuhause!"
            		cloudy_windy: [
            			"Windig draußen!",
            			"Halt bloß deine Hose fest"
            		thunderstorm: [
            			"GEWITTER??? WOOOOO? ÜBERALL?!",
            			"Es gewittert draußen!"
            		fog: [
            			"Nebel des Todes of Doom!",
            			"Ganz schön nebelig draußen..."
            		rain: [
            			"Nicht den Regenschirm vergessen!",
            			"Ihh es regnet :("
                        module: 'MMM-Sonos',
                        header: 'Now playing',
                        position: 'bottom_center',
                            animationSpeed: "1000",
                            showFullGroupName: "true",
                            showArtist: "true",
                            showAlbum: "true",
                            showMetadata: "true"
                module: 'MMM-COVID19-SPARKLINE',
            	header: "COVID-19 Fälle",
                  position: "bottom_center",
                  config : {
                    worldStats: true,
                    sparklines: true,
                    sparklineWidth: 100,
                    sparklineHeight: 55,
                    sparklineDays: 50,
                    sparklineDeltavsDaily: false,
                    sortby: "confirmed",
                    columns: ["confirmed", "deaths", "recovered"],
                    countries: ["Germany", "Spain", "Italy", "US"],
                    updateInterval: 1000 * 60 * 60 * 3,  //3 hours
                    infoRowClass: "small",
                    headerRowClass: "small",
                    fadeSpeed: 1000,
                    showDelta: true,
                    showDeltaPlotNDays: 14,
                    showDelimiter: true
            			module: "MMM-OpenmapWeather",
            			header: "Wetter für",
            				units: "metric",
            				degreeLabel: "true",
            				showFeelsLike: "false",
            				showHumidity: "true",
            				useKMPHwind: "true",
            				useBeaufort: "false",
            				colorIcon: "true",
            				lang: "de",
            				locationID: "2805761", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
            				appid: "60328ec38ba3b4f61059f193dff92f13"
            	module: 'MMM-DWD-WarnWeather',
            	position: 'top_right',
            //	header: 'Wetterwarnungen',
            		warnCellID: "803241021",
            		changeColor: true,
            		minutes: false,
            		displayRegionName: true,
            		displayInnerHeader: true,
            		interval: 10 * 60 * 1000, // every 10 minutes
            		loadingText: 'Warnungen werden geladen...',
            		noWarningText: 'Keine Warnungen',
            		severityThreshold: 1
            			module: "weatherforecast",
            			header: "Wettervorhersage für",
            				units: "metric",
            				showRainAmount: "true",
            				lang: "de",
            				scale: "true",
            				colored: "true",
            				appid: "60328ec38ba3b4f61059f193dff92f13",
            				maxNumberOfDays: "7"
            			module: "MMM-DWD-Pollen",
                			header: "Pollenwarnung",
                    			updateInterval: 1 * 60 * 60 * 1000, // every 1 hour1
                    			DWD_region: 32, // Östliches Niedersachsen
            				icon: false // Show icons or not
            	module: "MMM-RAIN-MAP",
            	header: "Regenradar",
            		animationSpeed: 600,
            		displayClockSymbol: true,
            		displayTime: true,
            		extraDelayLastFrame: 500,
            		height: "300px",
            		lat: 52.42580,
            		lng: 9.42944,
            		map: "OSM",
            		markers: [
            		    { lat: 52.42755, lng: 9.47309, color: "blue" }
            		onlyOnRain: false,
            		opacity: 0.65,
            		timeFormat: 24,
            		updateIntervalInSeconds: 300,
            		width: "300px",
            		zoom: 8,
            		zoomOutEach: 3,
            		zoomOutLevel: 3,
            			module: "newsfeed",
            			position: "bottom_bar",
            				feeds: [
            						title: "Tagesschau",
            						url: "http://www.tagesschau.de/xml/rss2"
            						title: "Heise",
            						url: "https://www.heise.de/rss/heise-atom.xml"
            				showSourceTitle: true,
            				showPublishDate: true,
            				broadcastNewsFeeds: true,
            				broadcastNewsUpdates: true
                        module: "MMM-SpaceX",
                            records: 3,
                            modus: "upcoming",
                            showExtraInfo: false,
            		showColumnHeader: true,
                module: 'MMM-WiFiPassword',
                    //See 'Configuration options' for more information.
                    network: "FRITZ!Box 7590 M&K",
                    password: "***",
            		showPassword: true,
              A Former User
              configuration seems good
              do you have any error on start ?
              If you use pm2 -> stop the process and start it manually with npm start command
              give me log or error ?
                DeathForce @Guest
                @Bugsounet
                  A Former User
                  some library missing … do you use npm install command for installing ?
                    DeathForce @Guest
                    @Bugsounet
                    Yes I have stopped MagicMirror and installed the module.
                    pi@PiSmartMirror:~/MagicMirror/modules/MMM-NewPIR $ npm install
                    > MMM-NewPIR@3.0.1 install /home/pi/MagicMirror/modules/MMM-NewPIR
                    > scripts/installer.sh
                    npm notice created a lockfile as package-lock.json. You should commit this file.
                    audited 176 packages in 5.506s
                    4 packages are looking for funding
                      run `npm fund` for details
                    found 0 vulnerabilities
                      A Former User
                      can you try this:
                      bugs@debian:~/MagicMirror/modules/MMM-NewPIR$ rm -rf node_modules/
                      bugs@debian:~/MagicMirror/modules/MMM-NewPIR$ rm package-lock.json
                      bugs@debian:~/MagicMirror/modules/MMM-NewPIR$ npm install
                       epoll@4.0.0 install /home/bugs/MagicMirror/modules/MMM-NewPIR/node_modules/epoll
                       node-gyp rebuild
                      make : on entre dans le répertoire « /home/bugs/MagicMirror/modules/MMM-NewPIR/node_modules/epoll/build »
                        CXX(target) Release/obj.target/epoll/src/epoll.o
                        SOLINK_MODULE(target) Release/obj.target/epoll.node
                        COPY Release/epoll.node
                      make : on quitte le répertoire « /home/bugs/MagicMirror/modules/MMM-NewPIR/node_modules/epoll/build »
                       @bugsounet/pir@1.0.4 postinstall /home/bugs/MagicMirror/modules/MMM-NewPIR/node_modules/@bugsounet/pir
                      > electron-rebuild
                      ✔ Rebuild Complete
                       MMM-NewPIR@3.0.1 install /home/bugs/MagicMirror/modules/MMM-NewPIR
                      added 176 packages from 127 contributors and audited 176 packages in 26.073s
                      bugs@debian:~/MagicMirror/modules/MMM-NewPIR$ cd ~/MagicMirror
                      bugs@debian:~/MagicMirror$ npm start
                        DeathForce @Guest
                        @Bugsounet
                        That’s it. Seems to work now… Thank You :)
                          A Former User
                          perfect so :)
                          when it want to works, it's magical
                            bdream
                            Hi @Bugsounet just going to install your module with deep hope in it’s functionality.
                            I’m going to use it on an Pi0 and get (now two times) an Network error: Software caused connection aborton Putty while npm install
                            Here all I get in console:
                            pi@RasPiZeroW:~/MagicMirror/modules/MMM-NewPIR $ npm install
                            > epoll@4.0.0 install /home/pi/MagicMirror/modules/MMM-NewPIR/node_modules/epoll
                            > node-gyp rebuild
                            make: Verzeichnis „/home/pi/MagicMirror/modules/MMM-NewPIR/node_modules/epoll/build“ wird betreten
                            Any idea, or is it caused on the hardware of RPi0?
                            I tried to start again and deleted all MMM-NewPIR stuff and rebootet RPi.
                            New attempt git clone and npm install
                            Getting this in coonsole:
                            > node-gyp rebuild
                            make: Verzeichnis „/home/pi/MagicMirror/modules/MMM-NewPIR/node_modules/epoll/build“ wird verlassen
                            > @bugsounet/pir@1.0.4 postinstall /home/pi/MagicMirror/modules/MMM-NewPIR/node_modules/@bugsounet/pir
                            > electron-rebuild
                            ⠸ Building module: epoll, Completed: 0
                            and status ⠸ Building module: epoll, Completed: 0 is not changing colpetition even it run and run.
                            So I assume it’s really related to RPi0 installation and electron. But that is to deep for my small knowledge selfsolving if possible anyway.
                            cheers, bdream
                            • FoziF Offline
                              Fozi Project Sponsor
                              Thanks for this new PIR module! I replaced last night the MMM-PIR-sensor module with yours and it works perfectly, also with my microwave sensor.
                              Especially the behaviour after the first start is now as expected, as the display is switches off after the countdown, without initializing the sensor first. With MMM-PIR-sensor the display would have stayed on after the first start until the sensor catches once a motion and the start the coutdown. I tweaked the node_helper.js to correct that, but after each module update I had to reapply that tweek. That belongs now to the past. Great job!:clapping_hands_light_skin_tone:
                              I have a feature request:
                              I would like to have two configuration options available to adjust the colours of “displayStyle”, as currently it is hardcoded in green:
                              • One option to adjust the colour of the remaining time (wich is currently green).
                              • Another option to adjust the colour of the past time (currently dark grey or white).
                              something like this:
                              displayStyleRemaining: 'e2e2e2', //RGB value of the remaining time
                              displayStylePast: '454545', //RGB value of the past time
                              I’m using the “Bar” style on “bottom_bar” position, which shows a decent thin line over the hole width of the mirror, which slowly creeps down to the left. But it is hard to distinguish the remaining time (green) and the past time (white) of that bar. I would prefer to adjust the remaining time to white, and the past time to black, as an example.
                              What do you think?
                              Oh BTW: I might help other users, if you enhance a little bit the README on GitHub on how to make the display styles visible. It took me some trials until I found out to configure an empty string for the “text” option to make the other styles show up.
                                A Former User @bdream
                                @bdream :
                                > electron-rebuild
                                it’s a very very long processing for a pi0 but needed …
                                I never try with it, i don’t know how time it can take (and if it’s works !)
                                @Fozi : thanks for you feedback !
                                NP v3 is result of a lot of works ;)
                                First it’s part of code from another module (Assistant2Display).
                                NP v3 is make for user who don’t want (don’t use or don’t know) to use GoogleAssistant/Assistant2Display
                                I port it to NP v3 with my own npm library (less code and sync all code for all my modules)
                                I have to code the new feature from Assistant2Display (Last Presence display) to NV v3
                                If you want you can do a Pull request do add your wanted feature ;)
                                if you want to do it, you can make it in dev branch (for temp code and developping) and not in master (only for releasing)
                                So Pull request is welcome :)
                                • FoziF Offline
                                  Fozi Project Sponsor @Guest
                                  Well, that means I‘ll have get much much deeper into coding and learn js. But hey, why not? Cold and dark autumn is coming and that’ll be a nice project 🤗
                                    A Former User
                                    the hardest part is to anticipate the slightest possible error so as not to crash everything (and even crash MM)
                                    If you can’t do it, i will do it soon :)
                                    I finish other new module before ;)
                                    so planned to this module:
                                    • Last presence
                                    • color feature
                                    • HDMI CEC support
                                    ? 1 Reply Last reply Reply Quote 1
                                      bdream
                                      @Bugsounet don’t know how time it can take (and if it’s works !)
                                      After a couple of trys it run to end but in time including MMM-NewPIR into config (smallest example or within many configurations…) mirror give error as config not available.
                                      I hang it up an the RPi0
                                      Will try it soon on an RPi3B as I feel this is a great module. - thanks for providing!
                                      cheers, bdream
                                        A Former User
                                        memory less in pi0, so it’s difficult to do complex think with it
                                        • H Offline
                                          hweigel
                                          Hi Cedric,
                                          I’ve received an update notification for this module, but something must have happened on Github:
                                          pi@MagicMirror:~/MagicMirror/modules/MMM-NewPIR $ git pull
                                          Username for 'https://github.com': XXX.YYY@gmail.com
                                          Password for 'https://helmut.weigel@gmail.com@github.com':
                                          remote: Repository not found.
                                          fatal: repository 'https://github.com/bugsounet/MMM-NewPIR.git/' not found
                                          Please advise.
                                            dvbit
                                            currently all modules developed by bougsounet are offline due to some issue with MM project founder.
                                            If you want them to go back online please invite the MM project owner, michmich, to have a dialogue.
                                            • 1 / 4
