    MM-Remote Android App
    21 Posts 7 Posters 12.5k Views 10 Watching
    • Cr4z33C Offline
      Cr4z33 @Klettner
      @Klettner I asked because I’ve got a TV and those commands do not apply to turn on and off the screen. 😉
      Can you please add also support to package cec-utils (https://packages.debian.org/buster/cec-utils)?
      • K Offline
        Klettner @thgmirror
        @thgmirror thanks for your feedback, I’am pleased to hear that :slightly_smiling_face:
          sdetweil @Klettner
          @Klettner you should make the command strings options so people don’t have to edit your code.
          set the default as it is now.
          my tvs don’t turn off , so I have hide/show for all modules
          • K Offline
            Klettner @Cr4z33
            @Cr4z33 I think I found a solution that might work for your.
            1. download the cec-utils package to your raspberry pi (you have probably already done that).
              For Ubuntu or Debian use:
            sudo apt install cec-utils
            1. scan for available devices to get the device number/address of your TV
            echo 'scan' | cec-client -s -d 1
            1. Now you should be able to power on the TV via the Raspi command terminal (replace Device# with the number or address form step 2):
            echo 'on Device#' | cec-client -s -d 1
            and off
            echo 'standby Device#' | cec-client -s -d 1
            1. If these commands work, overwrite the commands of MMM-Remote-Control.
              To do this, open you config.js file and add the customCommand section to the module MMM-Remote-Contorl:
            I’m wasn’t able to test the commands as my pi is currently not connected to a CEC-device. Let me know if this works for you.
              @Klettner never mind, you are using remotecontrol on the pi side…
              • Cr4z33C Offline
                Cr4z33 @Klettner
                @Klettner oh it’s easy then to fix it. :)
                Thanks for the solution.
                • K Offline
                  Klettner @sdetweil
                  @sdetweil yes exactly, all the default commands can be changed in the config.js file. Therefore you need to edit the customCommands section of MMM-Remote-Control. So if your TV does not turn off with the default command and you know one that works for you, you can change it there.
                  • K Offline
                    Klettner
                    New version of the MM-Remote android app is now available (v1.0.3).
                    New functionalities:
                    • Start/Stop/Pause a timer on the mirror
                    • Start /Stop/Pause a stop-watch on the mirror
                    • Hide and reorder the default commands of the Home-tab
                    • Simplified set-up of the app
                      A Former User
                      • My alpha user: Yeah good, i can control my MM with my phone !
                      • My developer user : Yes… But well done… Main code of remote control have open the port mirror to everyone ! without user and pass… so every one can see your mirror !
                        99% of user don’t change port (lazy to read ReadMe) so th default port is 8080 ! yeah
                      • My security point of view…: try to recode MMM-Remote-control with more security…
                      Sorry, it’s not for blame for program, but it’s the reality ;)
                        sdetweil @Guest
                        @Bugsounet well you would have to be on their network, so not likely exposure for most users
