    MM-Remote Android App
    21 Posts 7 Posters 12.4k Views 10 Watching
    • Cr4z33C Offline
      Cr4z33 @Klettner
      @Klettner said in MM-Remote Android App:
      • toggle the monitor on/off
      Did you add CEC compatibility with TVs too? :)
      If yes I am gonna give it a try.
      • K Offline
        Klettner
        To be honest, I don’t know what CEC is, but I can explain you how turning the monitor on/off is implemented and how you can test if it will work for you.
        If you press a button to send a command to the mirror, the app sends a REST requests to MMM-Remote-Controle, which handles the execution.
        I looked up for you how they have implemented tuning the monitor on/off there.
        To turn the monitor off they use the shell command:
        tvservice -o
        To turn on the monitor they use:
        tvservice --preferred && sudo chvt 6 && sudo chvt 7
        You can test these commands in the terminal of your Raspberry pi. If it works there, this should work with the app as well.
        It is also possible to overwrite these shell commands with you own ones, if you are interested in this, have a look at the custom commands section in the MMM-Remote-Control github repository
        • thgmirrorT Offline
          thgmirror
          Hi @Klettner,
          I like your App very much!
          It also runs if I enter the hostname instead of the IP-address. This helps me a lot because I don’t use a static IP.
          Btw. I took the first apk in the list and it works on my Huawei P8Lite (Android 6.0.1).
          Thank you for the App
          Thomas
          • Cr4z33C Offline
            Cr4z33 @Klettner
            @Klettner I asked because I’ve got a TV and those commands do not apply to turn on and off the screen. 😉
            Can you please add also support to package cec-utils (https://packages.debian.org/buster/cec-utils)?
            • K Offline
              Klettner @thgmirror
              @thgmirror thanks for your feedback, I’am pleased to hear that :slightly_smiling_face:
                sdetweil @Klettner
                @Klettner you should make the command strings options so people don’t have to edit your code.
                set the default as it is now.
                my tvs don’t turn off , so I have hide/show for all modules
                • K Offline
                  Klettner @Cr4z33
                  @Cr4z33 I think I found a solution that might work for your.
                  1. download the cec-utils package to your raspberry pi (you have probably already done that).
                    For Ubuntu or Debian use:
                  sudo apt install cec-utils
                  1. scan for available devices to get the device number/address of your TV
                  echo 'scan' | cec-client -s -d 1
                  1. Now you should be able to power on the TV via the Raspi command terminal (replace Device# with the number or address form step 2):
                  echo 'on Device#' | cec-client -s -d 1
                  and off
                  echo 'standby Device#' | cec-client -s -d 1
                  1. If these commands work, overwrite the commands of MMM-Remote-Control.
                    To do this, open you config.js file and add the customCommand section to the module MMM-Remote-Contorl:
                  I’m wasn’t able to test the commands as my pi is currently not connected to a CEC-device. Let me know if this works for you.
                    @Klettner never mind, you are using remotecontrol on the pi side…
                    • Cr4z33C Offline
                      Cr4z33 @Klettner
                      @Klettner oh it’s easy then to fix it. :)
                      Thanks for the solution.
                      • K Offline
                        Klettner @sdetweil
                        @sdetweil yes exactly, all the default commands can be changed in the config.js file. Therefore you need to edit the customCommands section of MMM-Remote-Control. So if your TV does not turn off with the default command and you know one that works for you, you can change it there.
