    MM-Remote Android App
    22 Posts 8 Posters 19.4k Views 11 Watching
    • Cr4z33C Offline
      Cr4z33 @Klettner
      @Klettner I asked because I’ve got a TV and those commands do not apply to turn on and off the screen. 😉
      Can you please add also support to package cec-utils (https://packages.debian.org/buster/cec-utils)?
      • K Offline
        Klettner @thgmirror
        @thgmirror thanks for your feedback, I’am pleased to hear that :slightly_smiling_face:
          sdetweil @Klettner
          @Klettner you should make the command strings options so people don’t have to edit your code.
          set the default as it is now.
          my tvs don’t turn off , so I have hide/show for all modules
          • K Offline
            Klettner @Cr4z33
            @Cr4z33 I think I found a solution that might work for your.
            1. download the cec-utils package to your raspberry pi (you have probably already done that).
              For Ubuntu or Debian use:
            sudo apt install cec-utils
            1. scan for available devices to get the device number/address of your TV
            echo 'scan' | cec-client -s -d 1
            1. Now you should be able to power on the TV via the Raspi command terminal (replace Device# with the number or address form step 2):
            echo 'on Device#' | cec-client -s -d 1
            and off
            echo 'standby Device#' | cec-client -s -d 1
            1. If these commands work, overwrite the commands of MMM-Remote-Control.
              To do this, open you config.js file and add the customCommand section to the module MMM-Remote-Contorl:
            I’m wasn’t able to test the commands as my pi is currently not connected to a CEC-device. Let me know if this works for you.
              @Klettner never mind, you are using remotecontrol on the pi side…
              • Cr4z33C Offline
                Cr4z33 @Klettner
                @Klettner oh it’s easy then to fix it. :)
                Thanks for the solution.
                • K Offline
                  Klettner @sdetweil
                  @sdetweil yes exactly, all the default commands can be changed in the config.js file. Therefore you need to edit the customCommands section of MMM-Remote-Control. So if your TV does not turn off with the default command and you know one that works for you, you can change it there.
                  • K Offline
                    Klettner
                    New version of the MM-Remote android app is now available (v1.0.3).
                    New functionalities:
                    • Start/Stop/Pause a timer on the mirror
                    • Start /Stop/Pause a stop-watch on the mirror
                    • Hide and reorder the default commands of the Home-tab
                    • Simplified set-up of the app
                      A Former User
                      • My alpha user: Yeah good, i can control my MM with my phone !
                      • My developer user : Yes… But well done… Main code of remote control have open the port mirror to everyone ! without user and pass… so every one can see your mirror !
                        99% of user don’t change port (lazy to read ReadMe) so th default port is 8080 ! yeah
                      • My security point of view…: try to recode MMM-Remote-control with more security…
                      Sorry, it’s not for blame for program, but it’s the reality ;)
                        sdetweil @Guest
                        @Bugsounet well you would have to be on their network, so not likely exposure for most users
                          A Former User
                          @sdetweil said in MM-Remote Android App:
                          sam, look any firewall scan by external source hacking … 80 8080 25 etc…
                            sdetweil @Guest
                            @Bugsounet yeh, most routers come with all ports closed. all mine in the last 10 years.
                            I only open ports when I need to
                              A Former User
                              I agree sam but you know most user (like me) … MM listen 8080 on internet expose …
                              if ip found … it’s the open for Remote control :)
                              browser command or androidapp -> no user /pass required
                              what 's why i warn :)
                              • V Offline
                                videogame95
                                I have not setup your app yet , every time I add the remote file to my config in stop what am I doing wrong
                                module: ‘MMM-Remote-Control’
                                // , position: ‘bottom_left’
                                customCommand: {}, // Optional, See “Using Custom Commands” below
                                customMenu: “custom_menu.json”, // Optional, See “Custom Menu Items” below
                                showModuleApiMenu: true, // Optional, Enable the Module Controls menu
                                apiKey: “”, // Optional, See API/README.md for details
                                I set this up on my old mirror and it worked please change the code so it will work.
                                or am I just pasting it in wrong?
                                S K 2 Replies Last reply Reply Quote 0
                                  sdetweil @videogame95
                                  @videogame95 said in MM-Remote Android App:
                                  rules…
                                  the thing to the left of : does NOT need to be quoted
                                  if the next line starts with a word (config, foo, address), then THIS line needs a trailing , at the end ( comments // on a line mean the , has to be IN FRONT of the //
                                  the thing AFTER the : if a number or true, does NOT need to be quoted
                                  otherwise if it is a word, or contains letters, it MUST be quoted ‘fred’, ‘0912drb’ single or double doesn’t matter as long as they are the same
                                  so, given that, you should be able to fix this module definition…
                                  • K Offline
                                    Klettner @videogame95
                                    @videogame95 in addition to the explanations of @sdetweil you can also start your MagicMirror in the console to get hints at problems in your config.js.
                                    First to go to the MagicMirror folder type cd ~/MagicMirror in your terminal.
                                    Then npm start to start the mirror.
                                    Now you should see some log messages in the terminal. If there is an error in your config.js there should also be an error message in between the logs. This message will tell you, around which line in the config.js the error occurs.
                                    Something like:
                                    WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:361
                                    In the config you posted, you are missing for example a , after ‘MMM-Remote-Control’
                                      johnsmith332 @Klettner
                                      @Klettner I will give a try hope so 🤞🤞
                                        AhmirArnold
                                        Thanks for sharing.
