    PIR-Sensor - put your mirror to sleep if not used
    126 Posts 37 Posters 251.2k Views 20 Watching
    • W Offline
      witschi87
      I’m getting the following error:
      start-magic-0 (err): WARNING! Could not find config. Please create one.
      start-magic-0 (err): App threw an error when running [Error: Module version mismatch. Expected 47, got 48.]
      start-magic-0 (err): [Error: Module version mismatch. Expected 47, got 48.]
      I’ve just cloned the git repository and installed the dependencies.
      And that is my config:
      	module: 'MMM-PIR-Sensor',
      		sensorPIN: 22,
      		powerSaving: true
        paviro
        Please use Node v5 not v6 one of the dependencies is not yet ready for v6.
        – The Doctor
        • W Offline
          witschi87
          Can you tell me how to do that, please?!
            paviro
            First Google result when searching for downgrade node to v5 :)
            Also do not forget to execute npm installand if that does not work reinstall the module from GitHub after you downgraded.
            – The Doctor
            J D 2 Replies Last reply Reply Quote 0
            • K Offline
              KirAsh4 Moderator @paviro
              @paviro, but but but … @MichMich said … he said … he said node 6.1.0 is now supported. Dependencies be damned, they need to catch up.
              MichMichM 1 Reply Last reply Reply Quote 0
              • MichMichM Offline
                MichMich @KirAsh4
                @KirAsh4 Yeah, MM supports Node 6.1.0 @paviro apparently still live in the stone age with his modules … 😈
                • K Offline
                  KirAsh4 Moderator @MichMich
                  @MichMich, I have a laser … let’s tie him up and put his hand under the beam. That’ll teach him!
                  • MichMichM Offline
                    MichMich
                    He is from the stone age. He doesn’t know what a laser is. 😱
                    • K Offline
                      KirAsh4 Moderator
                        paviro
                        Ha, ha :laughing:
                        Will change my dependencies when I have some spare time.
                        – The Doctor
                          Patrick
                          At first: Thank you very much.
                          This module is great and works fine for me.
                          When it’s allowed to make some suggestion…
                          you maybe could add a possibility to switch wireless sockets.
                          The effort for this shouldn’t be much, when you can use xkonni’s remote control.
                          https://github.com/xkonni/raspberry-remote
                          This would be a great possibity for those, who don’t feel comfortable to use a 230V relais… (I studied Mechatronics, so i don’t care :P)
                            paviro
                            Feel free to send a pull request! :)
                            – The Doctor
                              MechMatt @paviro
                              @paviro any suggestions on what relay to get for use with this? There are lots of choices on amazon
                                Patrick
                                Ok. When I’ve time, I will get a wireless transmitter.
                                Would be embarrasing if it wouldnt work because I’ve never tried :anguished:
                                • I Offline
                                  IngmarSwart @paviro
                                  @paviro I finally found some time to look into the problem I had some more. The exact origin is still unclear to me, but I did figure out that my problem, it is not related to your module, or the MM software in general. I got the same behaviour over ssh: tvservice -o switches the monitor connected to the Pi off, tvservice -p switches it back on, but the screen would appear black. After fiddling around a little bit, I found another solution that does not require root rights. Instead of using the sudo chvt 7 && sudo chvt 9 command, the problem can also be solved using fbset. My modified version of the activateMonitor function file node_helper.js:
                                  activateMonitor: function () {
                                      if (this.config.relayPIN != false) {
                                        gpio.digitalWrite(this.config.relayPIN, this.config.relayOnState)
                                      else if (this.config.relayPIN == false){
                                        exec("/opt/vc/bin/tvservice -p", null);
                                        exec("/bin/fbset -depth 8 && /bin/fbset -depth 16 ", null);
                                        exec("/usr/bin/xrefresh",null);
                                  For the command xrefresh to work when given via ssh, the correct display variable has to be set (in my case):
                                  export DISPLAY=:0 I have added this line to my .profile file in the /home/pi directory so that I don’t have to type it every time I log in via ssh.
                                  • I Offline
                                    IngmarSwart @MechMatt
                                    @MechMatt Have a look at the PowerSwitch Tail. If you live in the US, you can buy an assembled version from Adafruit. If you’re in 240V land (like me), you will have to do some (basic) soldering. Works like a charm for me. :-)
                                    • K Offline
                                      KirAsh4 Moderator
                                      That’s really odd that you have to go through all of that. On my rPi-3 with the most recent Raspbian Jessie release, I can use 'tvservice -o' and 'tvservice -p' and it just works. I don’t have to do anything else. It’s all running as the unprivileged user 'pi' (and without issuing 'sudo' before each command.) I wonder if it has something to do with the monitor and what it responds with when a signal is sent … Glad you figured it out though.
                                      • I Offline
                                        IngmarSwart @KirAsh4
                                        @KirAsh4 I agree, it’s very strange. Like you, I am using a rPi-3 with the most recent version of Raspbian Jessie and run everything as user pi. So maybe it is the monitor (Philips 273V5l). Which one do you use?
                                        Although the problem is fixed, I would like to know what is going on.
                                        • K Offline
                                          KirAsh4 Moderator
                                          Let me get home and get you the details on it. It a monitor we had sitting around at the office, some high end graphic Pro monitor that wasn’t being used anymore. I also have a test I want to perform on it, see if that makes a difference in what I’m seeing. Stay tuned.
                                            joerod @paviro
                                            @paviro I donwloaded to node 5.0.0 and I know get the following error
                                            Failed at the magicmirror@2.0.0 start script 'electron js/electron.js'.
                                            • 3 / 7
