    PIR-Sensor - put your mirror to sleep if not used
    126 Posts 37 Posters 258.5k Views 20 Watching
      Bangee Module Developer @paviro
      @paviro
      pm2 start mm
      P 1 Reply Last reply
        paviro @Bangee
        @Bangee in that case read the wiki ;)
        – The Doctor
          Funny…
          pi@raspberrypi:~ $ tail -f /home/pi/.pm2/logs/mm-out-0.log
          GIPO Status:1
          GIPO Status:0
          GIPO Status:1
          GIPO Status:0
          GIPO Status:1
          GIPO Status:0
          GIPO Status:1
          GIPO Status:0
          GIPO Status:1
          GIPO Status:0
            jrleeman @paviro
            @paviro The sensor I’ve got doesn’t have any adjustments on it. I suppose I can make little timed latch in hardware to add on, but it could be nice to do in software too.
              paviro @jrleeman
              @jrleeman feel free to send a pull request! :) the sensor I use cost 3€ do I don’t really see a reason to do it in software of the sensors are that cheap :smiley:
              – The Doctor
              J 1 Reply Last reply
                jrleeman @paviro
                @paviro Fair enough. I’ll see which I find easier, code or hardware. :smiley:
                N 1 Reply Last reply
                  sjuulbosmans
                  @paviro
                  Thanks for making this module. I am experiencing the same issue as @incubik as my screen turns white when I start the MM. My PIR sensor works as I tested it on the R Pi and with some LEDs and my breadboard. I have reinstalled the MM and this module but I can’t seem to get it working. I have also no idea what causes this. Do you have any thought on this?
                    paviro @sjuulbosmans
                    @sjuulbosmans white and black screens are mostly caused by wrong configuration. Check your web inspector!
                    – The Doctor
                    • I
                      incubik
                      I’ve tried to check the web inspector but when the screen is white… problems ahead —> The web inspector doesn’t pop up.
                      I’ve tried this without installing the PIR Sensor module and the web inspector works but again when the screen is in “white mode” doesn’t.
                      Any thoughts?
                        paviro @incubik
                        @incubik try the serveronly mode (see the wiki) :)
                        – The Doctor
                        • I
                          IngmarSwart
                          First of all: @paviro, many thanks for this module.
                          I ran into some troubles with the module and thought I should share this (and my solution) here.
                          Problem:
                          Without the PIR module, everything worked as it should. After installing the PIR module, everything appeared fine and the (HDMI) monitor switched off after a given amount of time (set via a variable resistance on the sensor itself). Upon motion detection by the PIR, the monitor switched back on but didn’t display anything (I could tell the monitor was on from the backlight). Remote access via ssh was not affected.
                          In the end, I figured out that this was due to an incorrect setting of the virtual terminal. Typing ‘sudo chvt 9 && sudo chvt 7’ on the remote terminal brought the image back to the monitor connected to the RasPi. After stopping the mirror, modifying the ‘activateMonitor’ function in ‘node_helper.js’ as below, and restarting the mirror, the problem was solved. I hpe this is helpful to others.
                          Modified section of ‘node_helper.js’:
                          activateMonitor: function () {
                              if (this.config.relayPIN != false) {
                                gpio.digitalWrite(this.config.relayPIN, this.config.relayOnState)
                              else if (this.config.relayPIN == false){
                                exec("/opt/vc/bin/tvservice -p", null);
                                exec("/usr/bin/sudo /bin/chvt 9 && /usr/bin/sudo /bin/chvt 7 ", null);
                          PS: There may be more elegant solutions to this, but I my node.js skills are, shall we say, limited?
                            paviro @IngmarSwart
                            @IngmarSwart could you explain what setting this changes? And may open a pull request? Is this only possible with sudo?
                            Please also note: Use Markdown on code snippets so it is easier to read!
                            – The Doctor
                            • I
                              IngmarSwart
                              @paviro, if I understoof the documentation correctly, the command chvt simply changes the foreground terminal. It appears that in my case the the output of the RasPi is send to another terminal than that is displayed on the monitor.
                              My apologies for not using the markdown code. I only recently started using GitHub etc, so I have some learning to do when it comes to opening pull requests.
                              I just tested to confirm if the use of sudo is required. Unfortunately, it is.
                                paviro @IngmarSwart
                                @IngmarSwart Strange that you have this issue, since I do not. I only have the problem when the monitor is disabled via a relay while the Pi boots.
                                Could you do some more research on why this is happening and maybe find a way to fix it without root rights?
                                – The Doctor
                                I 1 Reply Last reply
                                • I
                                  IngmarSwart
                                  @paviro, I also don’t understand where it comes from, especially since the MagicMirror appears as it should immediately after boot. At first glance, the monitor (Philips 273V5L) and Pi seem to play nice: EDID information is correct, tvservice -s gives the native resolution and refresh rate of the monitor. If I can find some time, I will look into it. However, I am also quite earger to start playing with your Facial-Recognition module… :relaxed:
                                  • K
                                    KirAsh4 Moderator
                                    This is more of a PSA than anything else, but particularly since the tvservice is part of the rPi’s firmware. While running 'sudo apt-get update && sudo apt-get upgrade' will upgrade your rPi’s packages and firmware, it may not be the latest version. For most, this is okay. But if you’re like me, who likes to live on the bleeding edge of things, particularly when something isn’t working right, running 'sudo rpi-update' separately will update the firmware only, including binaries such as 'tvservice' since they’re part of the firmware, not just a standard package (in fact, you can’t find it as a stand alone package through 'apt-cache'.)
                                    Use at your own risk. :)
                                    • W
                                      witschi87
                                      I’m getting the following error:
                                      start-magic-0 (err): WARNING! Could not find config. Please create one.
                                      start-magic-0 (err): App threw an error when running [Error: Module version mismatch. Expected 47, got 48.]
                                      start-magic-0 (err): [Error: Module version mismatch. Expected 47, got 48.]
                                      I’ve just cloned the git repository and installed the dependencies.
                                      And that is my config:
                                      	module: 'MMM-PIR-Sensor',
                                      		sensorPIN: 22,
                                      		powerSaving: true
                                        paviro
                                        Please use Node v5 not v6 one of the dependencies is not yet ready for v6.
                                        – The Doctor
                                        K 1 Reply Last reply
                                        • W
                                          witschi87
                                          Can you tell me how to do that, please?!
                                            paviro
                                            First Google result when searching for downgrade node to v5 :)
                                            Also do not forget to execute npm installand if that does not work reinstall the module from GitHub after you downgraded.
                                            – The Doctor
                                            J D 2 Replies Last reply
                                            • 3 / 7
