    PIR-Sensor - put your mirror to sleep if not used
    126 Posts 37 Posters 259.4k Views 20 Watching
    • paviroP
      paviro @MichMich
      @MichMich is it? Not sure I think one dependencies of THIS plugin does not support it, yet :/
      – The Doctor
      MichMichM 1 Reply Last reply
      • MichMichM
        MichMich @paviro
        @paviro ah sorry. Throught you were talking about mm2 in general.
        • BangeeB
          Bangee Module Developer @paviro
          @paviro i’ve added the console.log as you described, but there is no log output in firebug. where can I check this log elsewhere?
          paviroP 1 Reply Last reply
          • paviroP
            paviro @Bangee
            @Bangee it is node output! You have to check the log of the backend :)
            – The Doctor
            BangeeB 1 Reply Last reply
            • BangeeB
              @paviro sorry, i’m still a node noob… how can I check this? ;-)
              • paviroP
                paviro @Bangee
                @Bangee how do you start your mirror?
                – The Doctor
                • BangeeB
                  @paviro
                  pm2 start mm
                  • paviroP
                    paviro @Bangee
                    @Bangee in that case read the wiki ;)
                    – The Doctor
                    • BangeeB
                      Funny…
                      pi@raspberrypi:~ $ tail -f /home/pi/.pm2/logs/mm-out-0.log
                      GIPO Status:1
                      GIPO Status:0
                      GIPO Status:1
                      GIPO Status:0
                      GIPO Status:1
                      GIPO Status:0
                      GIPO Status:1
                      GIPO Status:0
                      GIPO Status:1
                      GIPO Status:0
                        jrleeman @paviro
                        @paviro The sensor I’ve got doesn’t have any adjustments on it. I suppose I can make little timed latch in hardware to add on, but it could be nice to do in software too.
                        • paviroP
                          paviro @jrleeman
                          @jrleeman feel free to send a pull request! :) the sensor I use cost 3€ do I don’t really see a reason to do it in software of the sensors are that cheap :smiley:
                          – The Doctor
                          J 1 Reply Last reply
                            jrleeman @paviro
                            @paviro Fair enough. I’ll see which I find easier, code or hardware. :smiley:
                            N 1 Reply Last reply
                              sjuulbosmans
                              @paviro
                              Thanks for making this module. I am experiencing the same issue as @incubik as my screen turns white when I start the MM. My PIR sensor works as I tested it on the R Pi and with some LEDs and my breadboard. I have reinstalled the MM and this module but I can’t seem to get it working. I have also no idea what causes this. Do you have any thought on this?
                              • paviroP
                                paviro @sjuulbosmans
                                @sjuulbosmans white and black screens are mostly caused by wrong configuration. Check your web inspector!
                                – The Doctor
                                • I
                                  incubik
                                  I’ve tried to check the web inspector but when the screen is white… problems ahead —> The web inspector doesn’t pop up.
                                  I’ve tried this without installing the PIR Sensor module and the web inspector works but again when the screen is in “white mode” doesn’t.
                                  Any thoughts?
                                  • paviroP
                                    paviro @incubik
                                    @incubik try the serveronly mode (see the wiki) :)
                                    – The Doctor
                                    • IngmarSwartI
                                      IngmarSwart
                                      First of all: @paviro, many thanks for this module.
                                      I ran into some troubles with the module and thought I should share this (and my solution) here.
                                      Problem:
                                      Without the PIR module, everything worked as it should. After installing the PIR module, everything appeared fine and the (HDMI) monitor switched off after a given amount of time (set via a variable resistance on the sensor itself). Upon motion detection by the PIR, the monitor switched back on but didn’t display anything (I could tell the monitor was on from the backlight). Remote access via ssh was not affected.
                                      In the end, I figured out that this was due to an incorrect setting of the virtual terminal. Typing ‘sudo chvt 9 && sudo chvt 7’ on the remote terminal brought the image back to the monitor connected to the RasPi. After stopping the mirror, modifying the ‘activateMonitor’ function in ‘node_helper.js’ as below, and restarting the mirror, the problem was solved. I hpe this is helpful to others.
                                      Modified section of ‘node_helper.js’:
                                      activateMonitor: function () {
                                          if (this.config.relayPIN != false) {
                                            gpio.digitalWrite(this.config.relayPIN, this.config.relayOnState)
                                          else if (this.config.relayPIN == false){
                                            exec("/opt/vc/bin/tvservice -p", null);
                                            exec("/usr/bin/sudo /bin/chvt 9 && /usr/bin/sudo /bin/chvt 7 ", null);
                                      PS: There may be more elegant solutions to this, but I my node.js skills are, shall we say, limited?
                                      • paviroP
                                        paviro @IngmarSwart
                                        @IngmarSwart could you explain what setting this changes? And may open a pull request? Is this only possible with sudo?
                                        Please also note: Use Markdown on code snippets so it is easier to read!
                                        – The Doctor
                                        • IngmarSwartI
                                          IngmarSwart
                                          @paviro, if I understoof the documentation correctly, the command chvt simply changes the foreground terminal. It appears that in my case the the output of the RasPi is send to another terminal than that is displayed on the monitor.
                                          My apologies for not using the markdown code. I only recently started using GitHub etc, so I have some learning to do when it comes to opening pull requests.
                                          I just tested to confirm if the use of sudo is required. Unfortunately, it is.
                                          • paviroP
                                            paviro @IngmarSwart
                                            @IngmarSwart Strange that you have this issue, since I do not. I only have the problem when the monitor is disabled via a relay while the Pi boots.
                                            Could you do some more research on why this is happening and maybe find a way to fix it without root rights?
                                            – The Doctor
                                            IngmarSwartI 1 Reply Last reply
                                            • 2 / 7
