    PIR-Sensor - put your mirror to sleep if not used
    126 Posts 37 Posters 259.4k Views 20 Watching
    • BangeeB
      Bangee Module Developer
      This PDF shows how to adjust your PIR Sensor.
      https://cdn.openimpulse.com/blog/wp-content/uploads/wpsc/downloadables/DYP-ME003_PIR_Sensor_Module_Datasheet.pdf
      Today, i don’t know why but after a few minutes the monitor turns off, but then it reactivates again without any motion in front of the mirror. Any sugestions?
      paviroP 1 Reply Last reply
      • paviroP
        paviro @Bangee
        @Bangee you can always try to add some logging to the code console.log("something") to see where it is triggered and if the script is the cause or something else :)
        – The Doctor
        • BangeeB
          This is all 10 seconds. But there is noone in front of the mirror… :-(
          meteoblueForecast received a module notification: USER_PRESENCE from sender: MMM-PIR-Sensor
          logger.js (Zeile 20)
          newsfeed received a module notification: USER_PRESENCE from sender: MMM-PIR-Sensor
          clock received a module notification: USER_PRESENCE from sender: MMM-PIR-Sensor
          calendar received a module notification: USER_PRESENCE from sender: MMM-PIR-Sensor
          swisstransport received a module notification: USER_PRESENCE from sender: MMM-PIR-Sensor
          • paviroP
            paviro @Bangee
            @Bangee Wait! That’s just all modules logging they received the notification, thats probably the same message over and over again logged by different modules.
            – The Doctor
            • BangeeB
              @paviro will there be any chance to log what information the sensor is returning?
              I’m not sure why my screen is alway going on and off, but i’ll get nervous…
              • paviroP
                paviro @Bangee
                @Bangee Sure in the node_helper.js find the comment Detected movement and add console.log() so that it looks like the following:
                gpio.wiringPiISR(this.config.sensorPIN, gpio.INT_EDGE_BOTH, function(delta) {
                        console.log(gpio.digitalRead(self.config.sensorPIN))
                – The Doctor
                BangeeB 1 Reply Last reply
                  jrleeman @paviro
                  @paviro I dug out a junk-box PIR sensor. Everything is installed and no white-screen problems, but this sensor only puts out an “on” signal for about a second after motion is detected. Any way to make the mirror stay awake for some time (say 2-5 minutes) with that timer being reset on any motion signal? Then if nobody is in front of the mirror for awhile it goes off. Currently mine flickers off and on, not the ideal behavior.
                  • paviroP
                    paviro @jrleeman
                    @jrleeman you should be able to change that by modifying the PIR-Sensor mine has the possibility to exactly adjust that :)
                    – The Doctor
                    J 1 Reply Last reply
                    • MichMichM
                      MichMich
                      For the record: node 6.1.0 is supported.
                      • paviroP
                        paviro @MichMich
                        @MichMich is it? Not sure I think one dependencies of THIS plugin does not support it, yet :/
                        – The Doctor
                        MichMichM 1 Reply Last reply
                        • MichMichM
                          MichMich @paviro
                          @paviro ah sorry. Throught you were talking about mm2 in general.
                          • BangeeB
                            Bangee Module Developer @paviro
                            @paviro i’ve added the console.log as you described, but there is no log output in firebug. where can I check this log elsewhere?
                            • paviroP
                              paviro @Bangee
                              @Bangee it is node output! You have to check the log of the backend :)
                              – The Doctor
                              • BangeeB
                                @paviro sorry, i’m still a node noob… how can I check this? ;-)
                                • paviroP
                                  paviro @Bangee
                                  @Bangee how do you start your mirror?
                                  – The Doctor
                                  • BangeeB
                                    @paviro
                                    pm2 start mm
                                    • paviroP
                                      paviro @Bangee
                                      @Bangee in that case read the wiki ;)
                                      – The Doctor
                                      • BangeeB
                                        Funny…
                                        pi@raspberrypi:~ $ tail -f /home/pi/.pm2/logs/mm-out-0.log
                                        GIPO Status:1
                                        GIPO Status:0
                                        GIPO Status:1
                                        GIPO Status:0
                                        GIPO Status:1
                                        GIPO Status:0
                                        GIPO Status:1
                                        GIPO Status:0
                                        GIPO Status:1
                                        GIPO Status:0
                                          jrleeman @paviro
                                          @paviro The sensor I’ve got doesn’t have any adjustments on it. I suppose I can make little timed latch in hardware to add on, but it could be nice to do in software too.
                                          • paviroP
                                            paviro @jrleeman
                                            @jrleeman feel free to send a pull request! :) the sensor I use cost 3€ do I don’t really see a reason to do it in software of the sensors are that cheap :smiley:
                                            – The Doctor
                                            • 2 / 7
