    PIR-Sensor - put your mirror to sleep if not used
    126 Posts 37 Posters 257.3k Views 20 Watching
    • I
      incubik
      I have Raspbian install so Im using Epiphany. Does this browser has a web inspector? if so, where? Thx
        pugsly
        I got my sensor and hooked it up, same problem.
        Yes, I am using node version 6.0. When I did the install that’s the version that was installed, I think the install script now installs an older version?
          Bangee Module Developer
          I’ve tried to use PIN 26. In my electron errorlog, there was this msg:
          [Error: digitalRead: IsInt32(arguments['pin']) === false]
          So I went back to PIN 22 and now my mirror starts again. :-)
          EDIT:
          New idea -> Try without ’ ';
          module: 'MMM-PIR-Sensor’,
          sensorPIN: 2 ,
            paviro @incubik
            @incubik I don’t use that browser, Google it :)
            @pugsly Node v6 is not supported at the moment.
            @Bangee yes, the pin has to be an int :) @incubik you also made that mistake!
            – The Doctor
            • I
              incubik
              Ok, I will!
              Maybe it is a hardware problem? I’ve connected the PIR-sensor this way, is this correct?
              https://www.raspberrypi.org/learning/physical-computing-guide/connect-pir/
                paviro @incubik
                @incubik Looks fine, the hardware does not influence the module behavior tough, you could also run it without something connected.
                – The Doctor
                • I
                  incubik
                  Ok, so if it doesn’t support v6, how can @Bangee made it work? I guess I should:
                  1. Uninstall NodeJS v6 and install v5
                    or
                  2. Delete the Sensor Module for now
                    paviro
                    When I checked it did not work, maybe the dependencies were updated since then. If not install v5 :)
                    – The Doctor
                      This PDF shows how to adjust your PIR Sensor.
                      https://cdn.openimpulse.com/blog/wp-content/uploads/wpsc/downloadables/DYP-ME003_PIR_Sensor_Module_Datasheet.pdf
                      Today, i don’t know why but after a few minutes the monitor turns off, but then it reactivates again without any motion in front of the mirror. Any sugestions?
                        paviro @Bangee
                        @Bangee you can always try to add some logging to the code console.log("something") to see where it is triggered and if the script is the cause or something else :)
                        – The Doctor
                          This is all 10 seconds. But there is noone in front of the mirror… :-(
                          meteoblueForecast received a module notification: USER_PRESENCE from sender: MMM-PIR-Sensor
                          logger.js (Zeile 20)
                          newsfeed received a module notification: USER_PRESENCE from sender: MMM-PIR-Sensor
                          clock received a module notification: USER_PRESENCE from sender: MMM-PIR-Sensor
                          calendar received a module notification: USER_PRESENCE from sender: MMM-PIR-Sensor
                          swisstransport received a module notification: USER_PRESENCE from sender: MMM-PIR-Sensor
                            paviro @Bangee
                            @Bangee Wait! That’s just all modules logging they received the notification, thats probably the same message over and over again logged by different modules.
                            – The Doctor
                              @paviro will there be any chance to log what information the sensor is returning?
                              I’m not sure why my screen is alway going on and off, but i’ll get nervous…
                                paviro @Bangee
                                @Bangee Sure in the node_helper.js find the comment Detected movement and add console.log() so that it looks like the following:
                                gpio.wiringPiISR(this.config.sensorPIN, gpio.INT_EDGE_BOTH, function(delta) {
                                        console.log(gpio.digitalRead(self.config.sensorPIN))
                                – The Doctor
                                  jrleeman @paviro
                                  @paviro I dug out a junk-box PIR sensor. Everything is installed and no white-screen problems, but this sensor only puts out an “on” signal for about a second after motion is detected. Any way to make the mirror stay awake for some time (say 2-5 minutes) with that timer being reset on any motion signal? Then if nobody is in front of the mirror for awhile it goes off. Currently mine flickers off and on, not the ideal behavior.
                                    paviro @jrleeman
                                    @jrleeman you should be able to change that by modifying the PIR-Sensor mine has the possibility to exactly adjust that :)
                                    – The Doctor
                                    • MichMichM
                                      MichMich
                                      For the record: node 6.1.0 is supported.
                                        paviro @MichMich
                                        @MichMich is it? Not sure I think one dependencies of THIS plugin does not support it, yet :/
                                        – The Doctor
                                        MichMichM 1 Reply Last reply Reply Quote 0
                                        • MichMichM
                                          MichMich @paviro
                                          @paviro ah sorry. Throught you were talking about mm2 in general.
                                            Bangee Module Developer @paviro
                                            @paviro i’ve added the console.log as you described, but there is no log output in firebug. where can I check this log elsewhere?
                                            • 1 / 7
