    Is it possible to ad an Arduino?
    55 Posts 4 Posters 27.6k Views 4 Watching
      sdetweil @Shinji0912
      @Shinji0912 so, I would use the linked examples outside mm to make sure it works
        Shinji0912 @sdetweil
        @sdetweil Ok so i have installed Serialport on the Pi and told the arduino to digitalwrite 10 but how to i let the Pi read 10?
          @Shinji0912 Google , there are many examples
            @sdetweil , @wishmaster270
            Ok , so now i got the Arduino to communicate with the PI via usb, (i got the right Portname using NodeRed). This is the current Arduino Script :
            #include <Wire.h>
            #include "DHT.h"
            #define DHTPIN 2
            #define DHTTYPE 11
            DHT dht (DHTPIN, DHTTYPE);
            void setup()
              Wire.begin();
              Serial.begin(9600);
              dht.begin();
            void loop()
              delay(2000);
              float temp = dht.readTemperature();
              float rel_hum = dht.readHumidity();
              if (isnan(rel_hum) || isnan(temp)) {
                Serial.println(F("Daten vom Sensor konnten nicht gelesen werden!"));
                return;
              float hif = dht.computeHeatIndex(rel_hum);
              float hic = dht.computeHeatIndex(temp, rel_hum, false);
              Serial.print(F("Luftfeuchtigkeit: "));
              Serial.print(rel_hum);
              Serial.print(F("%  Temperatur: "));
              Serial.print(temp);
              Serial.print(F("°C "));
              Serial.println(F(""));
            Some things are in german so dont be suprised ^^
            and via NodeRed i know that it is working and the Pi is currently reading the data.
            alt text
            My issue now is that my Config.js isn’t working anymore after installing ArduPorts ??
            alt text
            This is the current config :
            /* Magic Mirror Config Sample
             * By Michael Teeuw https://michaelteeuw.nl
             * MIT Licensed.
            var config = {
            	address: "localhost", 	// Address to listen on, can be:
            	port: 8080,
            	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
            	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
            	language: "de",
            	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
            	timeFormat: 24,
            	units: "metric",
            		module: 'MMM-ArduPort',
            		position: "bottom_right",
            		portname: "/dev/ttyACM0",
            		updateInterval: 2,
            		animationSpeed: 1000,
            		displayIcons: ture,
            		showDescription: true,
            		useColors: true,
            	sensors: [ {
            	description: "Temperatur",
            		module: 'MMM-TelegramBot',
            			telegramAPIKey: '',
            			allowedUser: [''],
            			adminChatId: ''
            			module: "MMM-Online-State",
            			module: "updatenotification",
            			position: "bottom_bar"
            			module: "clock",
            			position: "top_right"
                        module: 'MMM-RBB-Weather',
                        position: "top_left", // All available positions
                                     days: "0",
                                     updateInterval: "600",
            			header: "Events",
            						symbol: "calendar-check-o ",
            						url: "",
            						maximumEntries: "5",
            						maximumNumberOfDays: "7"
              module: "MMM-NowPlayingOnSpotify",
              position: "bottom_left",
                showCoverArt: false,
                clientID: "",
                clientSecret: "",
                accessToken: "",
                refreshToken: ""
            alt text
            i don’t know what to do now :C i thought i had it working this time finally …
            EDIT :
            Found the mistake i’ve written “ture” not “true” fml…
            EDIT 2 :
            But it’s still not working as i want it to it still says :“Waiting for Connection” on the Arduport module when launching the MagicMirror.
              @Shinji0912 and u did the npm install in the arduport module folder?
                @sdetweil yes i did .-.
                  @Shinji0912 ok, need to see the console logs
                  from nom start or pm2 logs
                  and the developers window ctrl-shift-i on the keyboard, then select the console tab and scroll up to see any errors.
                  u can also filter messages by.module, by adding part.of the module name to the filter field, ardu for example
                    @sdetweil Ok currently im not at home but will upload when home ^^
                      @Shinji0912 add
                      debug:true
                      to the config section of the arduport module def in config.js
                          Ok so like i said it starts now , but the ArduPorts module still says : “waiting for connection”
                          and i added the
                          debug: true,
                          line. And for some reason Ctrl + shift + i does nothing for me except that the radeon software takes a screenshot… so heres the full console log :
                          pi@raspberrypi:~/MagicMirror $ npm run start
                          > magicmirror@2.12.0 start /home/pi/MagicMirror
                          [2020-09-18 18:12:43.751] [LOG]    Starting MagicMirror: v2.12.0
                          [2020-09-18 18:12:43.764] [LOG]    Loading config ...
                          [2020-09-18 18:12:43.776] [LOG]    Loading module helpers ...
                          [2020-09-18 18:12:43.801] [LOG]    Initializing new module helper ...
                          [2020-09-18 18:12:43.802] [LOG]    Module helper loaded: MMM-ArduPort
                          node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
                          In the future, you will have to enable it yourself.
                          See https://github.com/yagop/node-telegram-bot-api/issues/319. internal/modules/cjs/loader.js:786:30
                          [2020-09-18 18:12:45.439] [LOG]    Initializing new module helper ...
                          [2020-09-18 18:12:45.440] [LOG]    Module helper loaded: MMM-TelegramBot
                          [2020-09-18 18:12:45.442] [LOG]    No helper found for module: MMM-Online-State.
                          [2020-09-18 18:12:45.519] [LOG]    Initializing new module helper ...
                          [2020-09-18 18:12:45.520] [LOG]    Module helper loaded: updatenotification
                          [2020-09-18 18:12:45.521] [LOG]    No helper found for module: clock.
                          [2020-09-18 18:12:45.698] [LOG]    Initializing new module helper ...
                          [2020-09-18 18:12:45.700] [LOG]    Module helper loaded: MMM-RBB-Weather
                          [2020-09-18 18:12:46.359] [LOG]    Initializing new module helper ...
                          [2020-09-18 18:12:46.360] [LOG]    Module helper loaded: calendar
                          [2020-09-18 18:12:47.125] [LOG]    Initializing new module helper ...
                          [2020-09-18 18:12:47.126] [LOG]    Module helper loaded: MMM-NowPlayingOnSpotify
                          [2020-09-18 18:12:47.126] [LOG]    All module helpers loaded.
                          [2020-09-18 18:12:47.336] [LOG]    Starting server on port 8080 ...
                          [2020-09-18 18:12:47.362] [LOG]    Server started ...
                          [2020-09-18 18:12:47.364] [LOG]    Connecting socket for: MMM-ArduPort
                          [2020-09-18 18:12:47.365] [LOG]    [MMM-ArduPort]:: Starting node_helper for module [MMM-ArduPort]
                          [2020-09-18 18:12:47.366] [LOG]    Connecting socket for: MMM-TelegramBot
                          [2020-09-18 18:12:47.367] [LOG]    Connecting socket for: updatenotification
                          [2020-09-18 18:12:47.369] [LOG]    Connecting socket for: MMM-RBB-Weather
                          [2020-09-18 18:12:47.369] [LOG]    Starting module helper: MMM-RBB-Weather
                          [2020-09-18 18:12:47.371] [LOG]    Connecting socket for: calendar
                          [2020-09-18 18:12:47.371] [LOG]    Starting node helper for: calendar
                          [2020-09-18 18:12:47.372] [LOG]    Connecting socket for: MMM-NowPlayingOnSpotify
                          [2020-09-18 18:12:47.373] [LOG]    Sockets connected & modules started ...
                          [2020-09-18 18:12:47.553] [LOG]    Launching application.
                          [2020-09-18 18:12:50.879] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/oliver.kuck12%40gmail.com/public/basic.ics - Interval: 300000
                          [2020-09-18 18:12:51.091] [LOG]    MMM-RBB-Weather[18.9.2020, 18:12:50]: Load data for ID "18228265" and "0" days ...
                          [2020-09-18 18:12:51.100] [INFO]   Checking git for module: MMM-ArduPort
                          [2020-09-18 18:12:51.132] [INFO]   Checking git for module: MMM-TelegramBot
                          [2020-09-18 18:12:51.168] [INFO]   Checking git for module: MMM-Online-State
                          [2020-09-18 18:12:51.209] [INFO]   Checking git for module: MMM-RBB-Weather
                          [2020-09-18 18:12:51.246] [INFO]   Checking git for module: MMM-NowPlayingOnSpotify
                          [2020-09-18 18:12:51.281] [ERROR]  (node:1451) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                          [2020-09-18 18:12:51.283] [ERROR]  (node:1451) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                          [2020-09-18 18:12:51.420] [LOG]    MMM-RBB-Weather[18.9.2020, 18:12:51]: Fetch data for day "0" ...
                          [2020-09-18 18:12:51.446] [LOG]    { debug: 'SerialPort shell started...' }
                          [2020-09-18 18:12:51.458] [LOG]    undefined[MMM-ArduPort] SerialPort shell started...
                          [2020-09-18 18:12:51.459] [LOG]    { debug: 'Waiting Ardunio to connect on port...' }
                          [2020-09-18 18:12:51.460] [LOG]    undefined[MMM-ArduPort] Waiting Ardunio to connect on port...
                          [2020-09-18 18:12:51.461] [LOG]    { status: { name: 'connect', data: 'connected' } }
                          [2020-09-18 18:12:51.462] [LOG]    { name: 'connect', data: 'connected' }
                          [2020-09-18 18:12:51.484] [ERROR]  Whoops! There was an uncaught exception...
                          [2020-09-18 18:12:51.485] [ERROR]  SyntaxError: Unexpected token E in JSON at position 0
                             at JSON.parse (<anonymous>)
                             at PythonShell.asJson (/home/pi/MagicMirror/modules/MMM-ArduPort/node_modules/python-shell/index.js:381:21)
                             at /home/pi/MagicMirror/modules/MMM-ArduPort/node_modules/python-shell/index.js:323:42
                             at Array.forEach (<anonymous>)
                             at PythonShell.receiveInternal (/home/pi/MagicMirror/modules/MMM-ArduPort/node_modules/python-shell/index.js:319:15)
                             at PythonShell.receiveStderr (/home/pi/MagicMirror/modules/MMM-ArduPort/node_modules/python-shell/index.js:303:21)
                             at Socket.emit (events.js:205:15)
                             at addChunk (_stream_readable.js:294:12)
                             at readableAddChunk (_stream_readable.js:271:13)
                             at Socket.Readable.push (_stream_readable.js:210:10)
                             at Pipe.onStreamRead (internal/stream_base_commons.js:166:17)
                          [2020-09-18 18:12:51.494] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                          [2020-09-18 18:12:51.495] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                          [2020-09-18 18:12:51.515] [LOG]    [MMM-ArduPort] finished running...
                          [2020-09-18 18:12:52.033] [LOG]    Refreshed access token because it has expired. Expired at: 18:12:50 now is: 18:12:52
                          [2020-09-18 18:12:52.074] [LOG]    Refreshed access token because it has expired. Expired at: 19:12:52 now is: 18:12:52
                          [2020-09-18 18:12:52.241] [LOG]    MMM-RBB-Weather[18.9.2020, 18:12:52]: Data received, send to module ...
                          [2020-09-18 18:12:52.420] [INFO]   Calendar-Fetcher: Broadcasting 0 events.
                          [2020-09-18 18:13:14.146] [LOG]    Shutting down server...
                          [2020-09-18 18:13:14.149] [LOG]    Stopping module helper: MMM-ArduPort
                          [2020-09-18 18:13:14.150] [LOG]    Stopping module helper: MMM-TelegramBot
                          [2020-09-18 18:13:14.152] [LOG]    Stopping module helper: updatenotification
                          [2020-09-18 18:13:14.153] [LOG]    Stopping module helper: MMM-RBB-Weather
                          [2020-09-18 18:13:14.155] [LOG]    Stopping module helper: calendar
                          [2020-09-18 18:13:14.157] [LOG]    Stopping module helper: MMM-NowPlayingOnSpotify
                          EDIT:
                          Seems like it can’t find the Arduino but via NodeRed i can see it is sending Informations which the Pi is able to read.
                            @Shinji0912 it found the Arduino and then died when the data arrived on wrong format
                              @sdetweil Ok … so is it the Arduino sketch that is the problem and if yes what should i change?
                                @Shinji0912 says json.parse failed. are u sending json formatted data as required?
                                  @sdetweil Im not sure about that …
                                  Like i said im a reallyyy bloody newbie… sry :C
                                  #include
                                  #include "DHT.h"
                                  #define DHTPIN 2
                                  #define DHTTYPE 11
                                  void setup()
                                    Wire.begin();
                                    Serial.begin(9600);
                                    dht.begin();
                                  void loop()
                                    delay(2000);
                                      return;
                                    Serial.print(temp);
                                  this is the arduino code
                                  When i tried to rewrite the given code by ArduPorts it didn’t even showed me the temperature in the SerialMonitor this was the sketch ;
                                  volatile int32_t m_counter = 0;
                                  bool WasStarted = false;
                                  static const char *pcDHT11Prefix = "[sensor:DHT11:";
                                  static const char *pcPostfix = "]";
                                  void setup() {
                                    Serial.begin(9600);
                                    while(!Serial);
                                    Serial.println("[status:setup:starting]");
                                    Serial.println("[sensor:DHT11:11]");
                                    int test = 1;
                                    m_counter = test;
                                    if(test > 1) {
                                      WasStarted = false;
                                      Serial.println("[status:setup:failed]");
                                      return;
                                    delay(3000);
                                    WasStarted = true;
                                    Serial.println("[status:setup:started]");
                                    delay(100);
                                  void loop() {
                                    Serial.print(m_counter + 11);
                                    Serial.println(pcPostfix);
                                    if(m_counter % 3 == 0) {
                                      delay(1000);
                                      Serial.print(pcDHT11Prefix);
                                      delay(2000);
                                    if(m_counter >= 60) m_counter = 0;
                                    m_counter++;
                                    delay(1000);
                                  EDIT 2 :
                                  This is what the Arduino SerialOutput looks like in NoteRed
                                  ( using the Rewritten ArduPorts Sketch)
                                  alt text
                                    @Shinji0912 use one of the online json validators to check your messages
                                      @sdetweil alt text
                                      alt text
                                        @Shinji0912 only what u send(println) not the whole sketch
                                        json, all text strings must be in double quotes
                                        Serial.print(pcMQ2Prefix);
                                        Serial.print(m_counter);
                                        sample shows sketch sending sensor info
                                          @sdetweil U mean like this?
                                             Serial.println("pcPostfix)"
                                             "Serial.println(""[status:setup:starting]"")"
                                             "Serial.println(""[sensor:DHT11:11]"")"
                                             "Serial.println(""[status:setup:failed]"")"
                                            @Shinji0912 see prior post
                                            • 2 / 3
