    Mm-googlephotos
    7 Posts 2 Posters 871 Views 2 Watching
    • V Offline
      videogame95
      • My google photos are trying to load with screen saying loading
        I’ve tried different positions but it’s still no t load
        What should I check first
        I’ve set it up fullscreen_below
        Size 600
        X 1
        Place my photos name in “New Mirror”
      Any help please as it’s change since I built my latest mirror.
        sdetweil @videogame95
        @videogame95 check the messages where you start mm
        pm2 logs --lines=???
        ??? is some number, default 15
        or the shell u use for npm start
        or look on the developers window, ctrl-shift-i on the pi keyboard, select the console tab and scroll up to see any errors. usually red text
        • V Offline
          videogame95
          Hi Thanks for your advice , l have fix my calendar &photos loading l had used auto install that did not work , once l use manual install it all works My advice to anyone building it for the first time do not use auto install nothing would load.
          Thanks again all fixed
          • V Offline
            videogame95
            Ok l give it a go thanks
              @videogame95 auto install of what?
              • V Offline
                videogame95 @sdetweil
                @sdetweil Hi auto install script Magic Mirror did not work for me .
                So I used the Manual install method and it all works.
                The only Problem I had is there was no custom .CSS folder
                So I had to use the main one . I of course made a copy of it.
                  @videogame95 auto install script?
                  u mean this the install script from here?
                  if so, please send the install.log fil to my email userid. same userid on gmail.
                  I am the author and maintainer of the script.
