    Error found: Error: Module version mismatch. Expected 50, got 46.
    9 Posts 4 Posters 8.9k Views 4 Watching
    • T Offline
      titusece
      Thanks.
      Now, I’m getting the below different version error.
      *pi@raspberrypi:~/MagicMirror $ npm start
      > magicmirror@2.0.0 start /home/pi/MagicMirror
      > electron js/electron.js
      Loading config ...
      Loading module helpers ...
      WARNING! Could not load config file. Starting with default configuration. **Error found: Error: Module version mismatch. Expected 50, got 49.**
      App threw an error during load
      **Error: Module version mismatch. Expected 50, got 49.**
          at Error (native)
          at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:178:20)
          at Object.Module._extensions..node (module.js:583:18)
          at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:178:20)
          at Module.load (module.js:473:32)
          at tryModuleLoad (module.js:432:12)
          at Function.Module._load (module.js:424:3)
          at Module.require (module.js:483:17)
          at require (internal/module.js:20:19)
          at bindings (/home/pi/MagicMirror/modules/MMM-Button/node_modules/bindings/bindings.js:76:44)
          at Error (native)
      Launching application.*
      • yawnsY Offline
        yawns Moderator
        please run npm list, which electron version are you running?
        If it is 1.4 then please run
        npm rebuild --runtime=electron --target=1.4.0 --disturl=https://atom.io/download/atom-shell --build-from-source
        lolobyteL 1 Reply Last reply Reply Quote 1
        • T Offline
          titusece
          Awesome, nice hint.
          pi@raspberrypi:~/MagicMirror $ npm list | grep electron
          ├─┬ electron-prebuilt@1.4.5
          │ ├─┬ electron-download@3.0.1
          npm ERR! peer dep missing: grunt@~0.4.0, required by grunt-yamllint@0.2.0
          I did this and no more problem now.
          npm rebuild --runtime=electron --target=1.4.5 --disturl=https://atom.io/download/atom-shell --abi=50
          Thanks much. :)
          • lolobyteL Offline
            lolobyte @yawns
            @yawns
            My Problem is:
            Error: Module version mismatch. Expected 50, got 51.
            NOT: Expected 50, got 46
            Hello, i have another version of electron:
            ├─┬ electron-prebuilt@1.4.6
            npm ERR! extraneous: stylelint@7.5.0 /home/pi/MagicMirror/node_modules/stylelint
            What must be done here?
            npm rebuild --runtime=electron --target=1.4.6 --disturl=https://atom.io/download/atom-shell --abi=50
            Is that ok???
            • T Offline
              titusece
              Yes, you can do like that to fix the problem.
              lolobyteL 1 Reply Last reply Reply Quote 0
              • lolobyteL Offline
                lolobyte @titusece
                @titusece
                Good morning (for me) my friend.
                it is resolved, but… no video.
                omx is running with a testfile.
                I think i must change my troubleshooting topic. ;-)
                Thank you
                0|mm       |            ,"query_zone": "999",
                0|mm       |    "alerts": [
                0|mm       |    ]
                0|mm       | }
                0|mm       | button pressed
                0|mm       | undefined
                0|mm       | omxplayer still running. kill forced
                0|mm       | undefined
                0|mm       | undefined
                • foxF Offline
                  fox
                  @yawns:
                  I did it with the named command, but no effect, can you help me please?
                  pi@magicpi:~/MagicMirror $ npm rebuild --runtime=electron --target=1.4.15 --disturl=https://atom.io/download/atom-shell --abi=50
                  > electron@1.4.15 postinstall /home/pi/MagicMirror/node_modules/electron
                  > node install.js
                  > electron-chromedriver@1.7.1 install /home/pi/MagicMirror/node_modules/electron-chromedriver
                  > node ./download-chromedriver.js
                  /home/pi/MagicMirror/node_modules/electron-chromedriver/download-chromedriver.js:16
                    if (error != null) throw error
                  Error: Could not parse checksum file at line 1:
                      at data.trim.split.forEach.line (/home/pi/MagicMirror/node_modules/electron-chromedriver/node_modules/sumchecker/index.js:85:18)
                      at Array.forEach ()
                      at Promise (/home/pi/MagicMirror/node_modules/electron-chromedriver/node_modules/sumchecker/index.js:80:36)
                      at new Promise ()
                      at ChecksumValidator.parseChecksumFile (/home/pi/MagicMirror/node_modules/electron-chromedriver/node_modules/sumchecker/index.js:76:12)
                      at
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 1
                  npm ERR! electron-chromedriver@1.7.1 install: `node ./download-chromedriver.js`
                  npm ERR! Exit status 1
                  npm ERR!
                  npm ERR! Failed at the electron-chromedriver@1.7.1 install script.
                  Reason-Link
                  Issues With MMM-WatchDog known?
                  https://forum.magicmirror.builders/post/29827
                  Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
