MMM-ResRobot - Public transport information for Sweden
@sweup I just pushed a minor update with some new options. Feel free to try the new version out.
Hello! :D
Got some issue with the module. The module loads when starting up MagicMirror, but stays at “Fetching departures …”. I tried my API key here;
(https://api.resrobot.se/v2/trip?key=API-KEY-HERE&originId=740047279&destId=740010151&format=xml) and it worked fine. So the key itself seams to work. I’m using the API key from “ResRobot - Reseplanerare”. I set the key in the config.js.My current config.js;
{ module: "MMM-ResRobot", position: "top_right", header: "Departures", config: { routes: [ // stations from: {from: "740015972", to: ""}, ], apiKey: "API-KEY-HERE" }, },
Terminal message;
[2020-09-23 03:21:58.036] [LOG] node_helper for MMM-ResRobot received a socket notification: CONFIG - Payload: { "updateInterval": 60000, "animationSpeed": 2000, "fade": true, "fadePoint": 0.25, "apiBase": "https://api.resrobot.se/v2/departureBoard?format=json&passlist=0", "apiKey": "API-KEY-HERE", "routes": [ { "from": "740015972", "to": "" } ], "skipMinutes": 0, "maximumEntries": 6, "truncateAfter": 5, "truncateLineAfter": 5, "showTrack": true, "getRelative": 0, "coloredIcons": false, "iconTable": { "B": "fa fa-bus", "S": "fa fa-subway", "J": "fa fa-train", "U": "fa fa-subway", "F": "fa fa-ship" }, "colorTable": { "B": "#DA4439", "S": "#019CD5", "J": "#FDB813", "U": "#019CD5", "F": "#444400" } }
Maybe someone can have an idea what might be wrong here :crazy_face:
@Zapman I’ll have a look. Your config looks fine at a first look.
@Alvinger - thx for you work in this module!
Sidenote, after updated my Rpi (3B) my wifi reception is far worst, never had problem with it before but now it’s loosing connection after a couple of minutes - but I was fast and manage to update to latest ResRobot :) working nicely -
@Zapman said in MMM-ResRobot - Public transport information for Sweden:
@Zapman You can’t have a comment in the middle of the config. Remove the " // stations from: " and it should work.
This is what it looks like for me:
@Alvinger said in MMM-ResRobot - Public transport information for Sweden:
sure you can, they are ignored, there are comments all over the place
@Alvinger Everything is working great now! Thank you for the fast response to my issue! I’ll use this module a lot from now on :smiling_face_with_open_mouth:
@Alvinger i added that config to another module with the comment and got what was expected. 1 route structure in an array
