    MMM-ResRobot - Public transport information for Sweden
    138 Posts 27 Posters 219.2k Views 28 Watching
      sdetweil @sweup
      @sweup git stash fails cause u are not registered to git on your machine
      git pull fails cause it would overwrite a change u.made to package.json
      so, I was trying to find out what the change was, and how important it is…
      the other commands won’t work til we resolve the diff(erence) issue
        sweup
        @sdetweil @Alvinger - thx guys, after
        $ git config --global user.email "you@example.com"
        $ git config --global user.name "Your Name"
        I could solve it with git stash
          sdetweil @sweup
          @sweup yeh, but we don’t know what change u lost/stashed
            Alvinger @sdetweil
            @sdetweil @sweup
            My guess is that it is an unintended change probably caused by saving rather than exiting when viewing the file.
            Anyway, package.json only contains information about the module and can without issue be replaced with a “git pull”.
            @sweup Great that you solved it. A small suggestion for the future: as most modules (and MagicMirror itself) uses Github you should read up on GIT and its basic commands. It will make life easier for you!
              Alvinger
              @sweup I just pushed a minor update with some new options. Feel free to try the new version out.
              • Z Offline
                Zapman
                Hello! :D
                Got some issue with the module. The module loads when starting up MagicMirror, but stays at “Fetching departures …”. I tried my API key here;
                (https://api.resrobot.se/v2/trip?key=API-KEY-HERE&originId=740047279&destId=740010151&format=xml) and it worked fine. So the key itself seams to work. I’m using the API key from “ResRobot - Reseplanerare”. I set the key in the config.js.
                My current config.js;
                			module: "MMM-ResRobot",
                                        header: "Departures",
                                                routes: [ // stations from:
                                                        {from: "740015972", to: ""},
                                                apiKey: "API-KEY-HERE"
                Terminal message;
                [2020-09-23 03:21:58.036] [LOG]    node_helper for MMM-ResRobot received a socket notification: CONFIG - Payload: {
                  "updateInterval": 60000,
                  "animationSpeed": 2000,
                  "fade": true,
                  "fadePoint": 0.25,
                  "apiBase": "https://api.resrobot.se/v2/departureBoard?format=json&passlist=0",
                  "apiKey": "API-KEY-HERE",
                  "routes": [
                      "from": "740015972",
                      "to": ""
                  "skipMinutes": 0,
                  "maximumEntries": 6,
                  "truncateAfter": 5,
                  "truncateLineAfter": 5,
                  "showTrack": true,
                  "getRelative": 0,
                  "coloredIcons": false,
                  "iconTable": {
                    "B": "fa fa-bus",
                    "S": "fa fa-subway",
                    "J": "fa fa-train",
                    "U": "fa fa-subway",
                    "F": "fa fa-ship"
                  "colorTable": {
                    "B": "#DA4439",
                    "S": "#019CD5",
                    "J": "#FDB813",
                    "U": "#019CD5",
                    "F": "#444400"
                Maybe someone can have an idea what might be wrong here :crazy_face:
                A 2 Replies Last reply Reply Quote 0
                  Alvinger @Zapman
                  @Zapman I’ll have a look. Your config looks fine at a first look.
                    sweup @Alvinger
                    @Alvinger - thx for you work in this module!
                    Sidenote, after updated my Rpi (3B) my wifi reception is far worst, never had problem with it before but now it’s loosing connection after a couple of minutes - but I was fast and manage to update to latest ResRobot :) working nicely
                      Alvinger @Zapman
                      @Zapman said in MMM-ResRobot - Public transport information for Sweden:
                      @Zapman You can’t have a comment in the middle of the config. Remove the " // stations from: " and it should work.
                      This is what it looks like for me:
                        sdetweil @Alvinger
                        @Alvinger said in MMM-ResRobot - Public transport information for Sweden:
                        sure you can, they are ignored, there are comments all over the place
                          Alvinger @sdetweil
                          @sdetweil Yes, they should be. However, when I pasted @Zapman’s config into my test site, it didn’t work. When I removed the comment it worked. Go figure!
                          Z S 2 Replies Last reply Reply Quote 0
                          • Z Offline
                            Zapman @Alvinger
                            @Alvinger Everything is working great now! Thank you for the fast response to my issue! I’ll use this module a lot from now on :smiling_face_with_open_mouth:
                              sdetweil @Alvinger
                              @Alvinger i added that config to another module with the comment and got what was expected. 1 route structure in an array
                                Alvinger @sdetweil
                                @sdetweil Really strange. You got the expected behavior but @Zapman and I got it to work when we removed the comment. I should state that I use a fork of MM as my screens are iPad 4 running IOS9.3.5 which might have an impact. But I don’t know which MM @Zapman uses.
                                  Alvinger @Zapman
                                  @Zapman You’re welcome. Do let me know if you see anything you want to add/change.
                                    SvenT @Alvinger
                                    @Alvinger Thank You for a brilliant module that works like a charm.
                                    Do You have a simple fix for limiting updates?
                                    I want frequent updates for my bus stop when present, and none when I’m not present…
                                    I have a PIR sensor hooked up. Possible to use that? Suspend module?
                                    OR a simple schedule as proposed by Trafiklab:
                                    https://www.trafiklab.se/docs/using-trafiklab-data/best-practices/limiting-requests/
                                    Not a high prio request…
                                    Cheers
                                    /Sven
                                    S A 2 Replies Last reply Reply Quote 0
                                      sdetweil @SvenT
                                      @SvenT I would post an issue to the module GitHub issues page to engage the author
                                        Alvinger @SvenT
                                        @SvenT I have experimented with a number of algorithms for minimizing updates but ended up with the one implemented. The current algorithm is:
                                        • If initial request, get updates from Trafiklab
                                        • If the first item in departure list (per routeId) is “old”, i.e. before cutoff time (now + skipMinutes), clear list (for routeId) and get updates from Trafiklab
                                        What the above means is that updates only occur ON ACTUAL DEPARTURES, e.g. if a bus departs every 15 minutes the module will get updates from Trafiklab every 15 minutes (per routeId). In rush hour this often means that the module get updates every minute but at night it might only update once per 60 minutes or longer (per routeId). This behavior has the benefit of automatically adjusting to rush hour and slow hours without user intervention or tweaking.
                                        If only one routeId is configured, the number of Trafiklab updates is usually way below the Trafiklab suggestions.
                                        /j
                                          SvenT @Alvinger
                                          @Alvinger I see.
                                          My local bus station has departures every 3 minutes almost all day. :-(
                                          I’ll tinker with the change profile module to see if I can pause the Reslust module.
                                          Cheers
                                          /Sven
                                            Alvinger @SvenT
                                            @SvenT I think that if you just hide the module it will stop updating (but I’m not sure). Try it.
                                            • 6 / 7
