    MMM-ResRobot - Public transport information for Sweden
    138 Posts 27 Posters 219.1k Views 28 Watching
      sweup @Alvinger
      @Alvinger - hmm something email adress. Any advice?
      pi@raspberrypi:~ $ cd ~/MagicMirror/modules/MMM-ResRobot
      pi@raspberrypi:~/MagicMirror/modules/MMM-ResRobot $ git stash
      *** Please tell me who you are.
      Run
        git config --global user.email "you@example.com"
        git config --global user.name "Your Name"
      to set your account's default identity.
      Omit --global to set the identity only in this repository.
      fatal: unable to auto-detect email address (got 'pi@raspberrypi.(none)')
      Cannot save the current index state
      pi@raspberrypi:~/MagicMirror/modules/MMM-ResRobot $ git pull
      Updating 1618fcc..695f70d
      error: Your local changes to the following files would be overwritten by merge:
      	package.json
      Please commit your changes or stash them before you merge.
      Aborting
      pi@raspberrypi:~/MagicMirror/modules/MMM-ResRobot $ npm install
      npm WARN npm npm does not support Node.js v10.21.0
      npm WARN npm You should probably upgrade to a newer version of node as we
      npm WARN npm can't make any promises that npm will work with this version.
      npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
      npm WARN npm You can find the latest version at https://nodejs.org/
      up to date in 1.02s
        sdetweil @sweup
        @sweup let’s find out what u changed
        do
        git diff
          sweup @sdetweil
          @sdetweil - sry I’m a bit lost, do I do “git diff” after?
          git stash
          git pull
          npm install
            sdetweil @sweup
            @sweup git stash fails cause u are not registered to git on your machine
            git pull fails cause it would overwrite a change u.made to package.json
            so, I was trying to find out what the change was, and how important it is…
            the other commands won’t work til we resolve the diff(erence) issue
              sweup
              @sdetweil @Alvinger - thx guys, after
              $ git config --global user.email "you@example.com"
              $ git config --global user.name "Your Name"
              I could solve it with git stash
                sdetweil @sweup
                @sweup yeh, but we don’t know what change u lost/stashed
                  Alvinger @sdetweil
                  @sdetweil @sweup
                  My guess is that it is an unintended change probably caused by saving rather than exiting when viewing the file.
                  Anyway, package.json only contains information about the module and can without issue be replaced with a “git pull”.
                  @sweup Great that you solved it. A small suggestion for the future: as most modules (and MagicMirror itself) uses Github you should read up on GIT and its basic commands. It will make life easier for you!
                    Alvinger
                    @sweup I just pushed a minor update with some new options. Feel free to try the new version out.
                    • Z Offline
                      Zapman
                      Hello! :D
                      Got some issue with the module. The module loads when starting up MagicMirror, but stays at “Fetching departures …”. I tried my API key here;
                      (https://api.resrobot.se/v2/trip?key=API-KEY-HERE&originId=740047279&destId=740010151&format=xml) and it worked fine. So the key itself seams to work. I’m using the API key from “ResRobot - Reseplanerare”. I set the key in the config.js.
                      My current config.js;
                      			module: "MMM-ResRobot",
                                              header: "Departures",
                                                      routes: [ // stations from:
                                                              {from: "740015972", to: ""},
                                                      apiKey: "API-KEY-HERE"
                      Terminal message;
                      [2020-09-23 03:21:58.036] [LOG]    node_helper for MMM-ResRobot received a socket notification: CONFIG - Payload: {
                        "updateInterval": 60000,
                        "animationSpeed": 2000,
                        "fade": true,
                        "fadePoint": 0.25,
                        "apiBase": "https://api.resrobot.se/v2/departureBoard?format=json&passlist=0",
                        "apiKey": "API-KEY-HERE",
                        "routes": [
                            "from": "740015972",
                            "to": ""
                        "skipMinutes": 0,
                        "maximumEntries": 6,
                        "truncateAfter": 5,
                        "truncateLineAfter": 5,
                        "showTrack": true,
                        "getRelative": 0,
                        "coloredIcons": false,
                        "iconTable": {
                          "B": "fa fa-bus",
                          "S": "fa fa-subway",
                          "J": "fa fa-train",
                          "U": "fa fa-subway",
                          "F": "fa fa-ship"
                        "colorTable": {
                          "B": "#DA4439",
                          "S": "#019CD5",
                          "J": "#FDB813",
                          "U": "#019CD5",
                          "F": "#444400"
                      Maybe someone can have an idea what might be wrong here :crazy_face:
                      A 2 Replies Last reply Reply Quote 0
                        Alvinger @Zapman
                        @Zapman I’ll have a look. Your config looks fine at a first look.
                          sweup @Alvinger
                          @Alvinger - thx for you work in this module!
                          Sidenote, after updated my Rpi (3B) my wifi reception is far worst, never had problem with it before but now it’s loosing connection after a couple of minutes - but I was fast and manage to update to latest ResRobot :) working nicely
                            Alvinger @Zapman
                            @Zapman said in MMM-ResRobot - Public transport information for Sweden:
                            @Zapman You can’t have a comment in the middle of the config. Remove the " // stations from: " and it should work.
                            This is what it looks like for me:
                              sdetweil @Alvinger
                              @Alvinger said in MMM-ResRobot - Public transport information for Sweden:
                              sure you can, they are ignored, there are comments all over the place
                                Alvinger @sdetweil
                                @sdetweil Yes, they should be. However, when I pasted @Zapman’s config into my test site, it didn’t work. When I removed the comment it worked. Go figure!
                                Z S 2 Replies Last reply Reply Quote 0
                                • Z Offline
                                  Zapman @Alvinger
                                  @Alvinger Everything is working great now! Thank you for the fast response to my issue! I’ll use this module a lot from now on :smiling_face_with_open_mouth:
                                    sdetweil @Alvinger
                                    @Alvinger i added that config to another module with the comment and got what was expected. 1 route structure in an array
                                      Alvinger @sdetweil
                                      @sdetweil Really strange. You got the expected behavior but @Zapman and I got it to work when we removed the comment. I should state that I use a fork of MM as my screens are iPad 4 running IOS9.3.5 which might have an impact. But I don’t know which MM @Zapman uses.
                                        Alvinger @Zapman
                                        @Zapman You’re welcome. Do let me know if you see anything you want to add/change.
                                          SvenT @Alvinger
                                          @Alvinger Thank You for a brilliant module that works like a charm.
                                          Do You have a simple fix for limiting updates?
                                          I want frequent updates for my bus stop when present, and none when I’m not present…
                                          I have a PIR sensor hooked up. Possible to use that? Suspend module?
                                          OR a simple schedule as proposed by Trafiklab:
                                          https://www.trafiklab.se/docs/using-trafiklab-data/best-practices/limiting-requests/
                                          Not a high prio request…
                                          Cheers
                                          /Sven
                                          S A 2 Replies Last reply Reply Quote 0
                                            sdetweil @SvenT
                                            @SvenT I would post an issue to the module GitHub issues page to engage the author
                                            • 6 / 7
