    MMM-ResRobot - Public transport information for Sweden
    138 Posts 27 Posters 225.2k Views 28 Watching
      sdetweil @sweup
      @sweup what was the output of git pull?
      • A
        Alvinger @sweup
        @sweup did you restart the MagicMirror service after you updated?
          sweup @sdetweil
          @sdetweil - I only got this
          pi@raspberrypi:~ $ cd ~/MagicMirror/modules/MMM-ResRobot
          pi@raspberrypi:~/MagicMirror/modules/MMM-ResRobot $ git pull
          Updating 1618fcc..695f70d
          error: Your local changes to the following files would be overwritten by merge:
          	package.json
          Please commit your changes or stash them before you merge.
          Aborting
          pi@raspberrypi:~/MagicMirror/modules/MMM-ResRobot $ npm install
          npm WARN npm npm does not support Node.js v10.21.0
          npm WARN npm You should probably upgrade to a newer version of node as we
          npm WARN npm can't make any promises that npm will work with this version.
          npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
          npm WARN npm You can find the latest version at https://nodejs.org/
          up to date in 1.083s
          @Alvinger - I did a sudo reboot
          • A
            Alvinger @sweup
            @sweup it seems you have changed the file package.json
            Stash it away with “git stash” and try the update again.
              sweup @Alvinger
              @Alvinger said in MMM-ResRobot - Public transport information for Sweden:
              git stash
              Like this?
              git stash
              npm install
              Edit:misspell
              • A
                Alvinger @sweup
                @sweup
                git stash
                git pull
                npm install
                  sweup @Alvinger
                  @Alvinger - hmm something email adress. Any advice?
                  pi@raspberrypi:~/MagicMirror/modules/MMM-ResRobot $ git stash
                  *** Please tell me who you are.
                  Run
                    git config --global user.email "you@example.com"
                    git config --global user.name "Your Name"
                  to set your account's default identity.
                  Omit --global to set the identity only in this repository.
                  fatal: unable to auto-detect email address (got 'pi@raspberrypi.(none)')
                  Cannot save the current index state
                  	package.json
                  Aborting
                  up to date in 1.02s
                    sdetweil @sweup
                    @sweup let’s find out what u changed
                    do
                    git diff
                      sweup @sdetweil
                      @sdetweil - sry I’m a bit lost, do I do “git diff” after?
                      git stash
                      git pull
                      npm install
                        sdetweil @sweup
                        @sweup git stash fails cause u are not registered to git on your machine
                        git pull fails cause it would overwrite a change u.made to package.json
                        so, I was trying to find out what the change was, and how important it is…
                        the other commands won’t work til we resolve the diff(erence) issue
                          sweup
                          @sdetweil @Alvinger - thx guys, after
                          $ git config --global user.email "you@example.com"
                          $ git config --global user.name "Your Name"
                          I could solve it with git stash
                            sdetweil @sweup
                            @sweup yeh, but we don’t know what change u lost/stashed
                            • A
                              Alvinger @sdetweil
                              @sdetweil @sweup
                              My guess is that it is an unintended change probably caused by saving rather than exiting when viewing the file.
                              Anyway, package.json only contains information about the module and can without issue be replaced with a “git pull”.
                              @sweup Great that you solved it. A small suggestion for the future: as most modules (and MagicMirror itself) uses Github you should read up on GIT and its basic commands. It will make life easier for you!
                              • A
                                Alvinger
                                @sweup I just pushed a minor update with some new options. Feel free to try the new version out.
                                • Z
                                  Zapman
                                  Hello! :D
                                  Got some issue with the module. The module loads when starting up MagicMirror, but stays at “Fetching departures …”. I tried my API key here;
                                  (https://api.resrobot.se/v2/trip?key=API-KEY-HERE&originId=740047279&destId=740010151&format=xml) and it worked fine. So the key itself seams to work. I’m using the API key from “ResRobot - Reseplanerare”. I set the key in the config.js.
                                  My current config.js;
                                  			module: "MMM-ResRobot",
                                                          header: "Departures",
        routes: [ // stations from:
        {from: "740015972", to: ""},
        apiKey: "API-KEY-HERE"
                                  Terminal message;
                                  [2020-09-23 03:21:58.036] [LOG]    node_helper for MMM-ResRobot received a socket notification: CONFIG - Payload: {
                                    "updateInterval": 60000,
                                    "animationSpeed": 2000,
                                    "fade": true,
                                    "fadePoint": 0.25,
                                    "apiBase": "https://api.resrobot.se/v2/departureBoard?format=json&passlist=0",
                                    "apiKey": "API-KEY-HERE",
                                    "routes": [
                                        "from": "740015972",
                                        "to": ""
                                    "skipMinutes": 0,
                                    "maximumEntries": 6,
                                    "truncateAfter": 5,
                                    "truncateLineAfter": 5,
                                    "showTrack": true,
                                    "getRelative": 0,
                                    "coloredIcons": false,
                                    "iconTable": {
                                      "B": "fa fa-bus",
                                      "S": "fa fa-subway",
                                      "J": "fa fa-train",
                                      "U": "fa fa-subway",
                                      "F": "fa fa-ship"
                                    "colorTable": {
                                      "B": "#DA4439",
                                      "S": "#019CD5",
                                      "J": "#FDB813",
                                      "U": "#019CD5",
                                      "F": "#444400"
                                  Maybe someone can have an idea what might be wrong here :crazy_face:
                                  A 2 Replies Last reply Reply Quote 0
                                  • A
                                    Alvinger @Zapman
                                    @Zapman I’ll have a look. Your config looks fine at a first look.
                                      sweup @Alvinger
                                      @Alvinger - thx for you work in this module!
                                      Sidenote, after updated my Rpi (3B) my wifi reception is far worst, never had problem with it before but now it’s loosing connection after a couple of minutes - but I was fast and manage to update to latest ResRobot :) working nicely
                                      • A
                                        Alvinger @Zapman
                                        @Zapman said in MMM-ResRobot - Public transport information for Sweden:
                                        @Zapman You can’t have a comment in the middle of the config. Remove the " // stations from: " and it should work.
                                        This is what it looks like for me:
                                          sdetweil @Alvinger
                                          sure you can, they are ignored, there are comments all over the place
                                          • A
                                            Alvinger @sdetweil
                                            @sdetweil Yes, they should be. However, when I pasted @Zapman’s config into my test site, it didn’t work. When I removed the comment it worked. Go figure!
                                            Z S 2 Replies Last reply Reply Quote 0
                                            • 6 / 7
