    MMM-ResRobot - Public transport information for Sweden
    138 Posts 27 Posters 227.4k Views 28 Watching
    • L
      leanro @leanro
      @leanro said in MMM-ResRobot - Public transport information for Sweden:
      Hej!
      I’m trying to get the MMM-Resrobot to work but … no success. In my MM, it permanently says “Fetching Departures …”
      Anyone who has an idea?
      Appreciated! Tack!
      After angrily restarting the RPi, the module works. Can’t tell you, why it didn’t work in the first place but I can confirm that the configs i posted before work.
      Good luck!
      Update: whenever sth is changed in the configs, a reload does not help I need to totally stop MM and restart for the changes to be effective.
      AlvingerA 1 Reply Last reply
      • AlvingerA
        Alvinger @leanro
        @leanro great to hear it works. I had one or two of these “fetching departures” when I ran MagicMirror on my Rpi 1 with 256MB memory but since switching to a VM I haven’t seen it. As you have noticed, the solution is to restart MagicMirror.
        • L
          leanro
          Hej!
          Now I do have another problem which could not be solved by restarting.
          I wanted to apply two sections for two different routes. Unfortunately, the settings from the second modules are taken over also for the first module. I have two identical timetables instead of two different ones.
          Do you know what the problem/solution could be?
          I have other modules which are used twice (e.g., calendar, weather), no problems there.
          • AlvingerA
            Alvinger
            Yes, I think I know what the issue is. Currently, only one section is supported due to the fact that the node helper only supports one set of data. As the daily request limits for ResRobot bronze are a bit low I try to cache data and reduce the number of calls as much as possible. And one of the design decisions I made was to only do one section. (You can have multiple routes in the same section which is my use case)
            However, I do realize the need for multiple sections and it is on my todo list. Unfortunately I’been bitten by the home automation bug and haven’t spent so much time on MagicMirror lately So there is no ETA for it.
            • L
              leanro
              @Alvinger Thanks for the quick answer! Now I know at least what the problem was/is.
              Good luck for other projects!
                jocke.almgren
                Hi
                I hope this forum still is active ;)
                I just started my Magic Mirror project, and of course i need bus departures to be on the mirror.
                But i can’t figure out why it never shows on the screen… it’s not the whole screen that is black, the ResRobot module just doesn’t show.
                this is my config.js
                			module: "MMM-ResRobot",
                			position: "top_center",
                			header: "Departures",
                				routes: [
                					{from: "740054292", to: "740040961"},
                					{from: "740053855", to: "740010956"}
                				skipMinutes: 0,
                				maximumEntries: 6,
                				truncateAfter: 5,
                				apiKey: "XXXXXX"
                Any help so much appreciated
                • AlvingerA
                  Alvinger @jocke.almgren
                  @jocke-almgren just to make sure: you have registered for an API key at Trafiklab?
                  J 1 Reply Last reply
                    jocke.almgren @Alvinger
                    @Alvinger Hi - thanks for your reply. Turns out i was a total idiot and placed the module in the “modules/default” directory instead of the modules root :man_facepalming: Moved the folder and all is good.
                    Thanks for the support anyways
                    • sweupS
                      sweup
                      Hi, how do i update?, i tried
                      cd ~/MagicMirror/modules/MMM-ResRobot
                      git pull
                      npm install
                      But frontend still says a newer update is found…
                      S AlvingerA 2 Replies Last reply
                        sdetweil @sweup
                        @sweup what was the output of git pull?
                        sweupS 1 Reply Last reply
                        • AlvingerA
                          Alvinger @sweup
                          @sweup did you restart the MagicMirror service after you updated?
                          • sweupS
                            sweup @sdetweil
                            @sdetweil - I only got this
                            pi@raspberrypi:~ $ cd ~/MagicMirror/modules/MMM-ResRobot
                            pi@raspberrypi:~/MagicMirror/modules/MMM-ResRobot $ git pull
                            Updating 1618fcc..695f70d
                            error: Your local changes to the following files would be overwritten by merge:
                            	package.json
                            Please commit your changes or stash them before you merge.
                            Aborting
                            pi@raspberrypi:~/MagicMirror/modules/MMM-ResRobot $ npm install
                            npm WARN npm npm does not support Node.js v10.21.0
                            npm WARN npm You should probably upgrade to a newer version of node as we
                            npm WARN npm can't make any promises that npm will work with this version.
                            npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
                            npm WARN npm You can find the latest version at https://nodejs.org/
                            up to date in 1.083s
                            @Alvinger - I did a sudo reboot
                            • AlvingerA
                              Alvinger @sweup
                              @sweup it seems you have changed the file package.json
                              Stash it away with “git stash” and try the update again.
                              • sweupS
                                sweup @Alvinger
                                @Alvinger said in MMM-ResRobot - Public transport information for Sweden:
                                git stash
                                Like this?
                                git stash
                                npm install
                                Edit:misspell
                                • AlvingerA
                                  Alvinger @sweup
                                  @sweup
                                  git stash
                                  git pull
                                  npm install
                                  • sweupS
                                    sweup @Alvinger
                                    @Alvinger - hmm something email adress. Any advice?
                                    pi@raspberrypi:~/MagicMirror/modules/MMM-ResRobot $ git stash
                                    *** Please tell me who you are.
                                    Run
                                      git config --global user.email "you@example.com"
                                      git config --global user.name "Your Name"
                                    to set your account's default identity.
                                    Omit --global to set the identity only in this repository.
                                    fatal: unable to auto-detect email address (got 'pi@raspberrypi.(none)')
                                    Cannot save the current index state
                                    	package.json
                                    Aborting
                                    up to date in 1.02s
                                      sdetweil @sweup
                                      @sweup let’s find out what u changed
                                      do
                                      git diff
                                      • sweupS
                                        sweup @sdetweil
                                        @sdetweil - sry I’m a bit lost, do I do “git diff” after?
                                        git stash
                                        git pull
                                        npm install
                                          sdetweil @sweup
                                          @sweup git stash fails cause u are not registered to git on your machine
                                          git pull fails cause it would overwrite a change u.made to package.json
                                          so, I was trying to find out what the change was, and how important it is…
                                          the other commands won’t work til we resolve the diff(erence) issue
                                          • sweupS
                                            sweup
                                            @sdetweil @Alvinger - thx guys, after
                                            $ git config --global user.email "you@example.com"
                                            $ git config --global user.name "Your Name"
                                            I could solve it with git stash
                                            • 5 / 7
