    MMM-ResRobot - Public transport information for Sweden
    138 Posts 27 Posters 219.1k Views 28 Watching
      jocke.almgren
      Hi
      I hope this forum still is active ;)
      I just started my Magic Mirror project, and of course i need bus departures to be on the mirror.
      But i can’t figure out why it never shows on the screen… it’s not the whole screen that is black, the ResRobot module just doesn’t show.
      this is my config.js
      			module: "MMM-ResRobot",
      			position: "top_center",
      			header: "Departures",
      				routes: [
      					{from: "740054292", to: "740040961"},
      					{from: "740053855", to: "740010956"}
      				skipMinutes: 0,
      				maximumEntries: 6,
      				truncateAfter: 5,
      				apiKey: "XXXXXX"
      Any help so much appreciated
        Alvinger @jocke.almgren
        @jocke-almgren just to make sure: you have registered for an API key at Trafiklab?
          jocke.almgren @Alvinger
          @Alvinger Hi - thanks for your reply. Turns out i was a total idiot and placed the module in the “modules/default” directory instead of the modules root :man_facepalming: Moved the folder and all is good.
          Thanks for the support anyways
            sweup
            Hi, how do i update?, i tried
            cd ~/MagicMirror/modules/MMM-ResRobot
            git pull
            npm install
            But frontend still says a newer update is found…
            S A 2 Replies Last reply Reply Quote 0
              sdetweil @sweup
              @sweup what was the output of git pull?
                Alvinger @sweup
                @sweup did you restart the MagicMirror service after you updated?
                  sweup @sdetweil
                  @sdetweil - I only got this
                  pi@raspberrypi:~ $ cd ~/MagicMirror/modules/MMM-ResRobot
                  pi@raspberrypi:~/MagicMirror/modules/MMM-ResRobot $ git pull
                  Updating 1618fcc..695f70d
                  error: Your local changes to the following files would be overwritten by merge:
                  	package.json
                  Please commit your changes or stash them before you merge.
                  Aborting
                  pi@raspberrypi:~/MagicMirror/modules/MMM-ResRobot $ npm install
                  npm WARN npm npm does not support Node.js v10.21.0
                  npm WARN npm You should probably upgrade to a newer version of node as we
                  npm WARN npm can't make any promises that npm will work with this version.
                  npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
                  npm WARN npm You can find the latest version at https://nodejs.org/
                  up to date in 1.083s
                  @Alvinger - I did a sudo reboot
                    Alvinger @sweup
                    @sweup it seems you have changed the file package.json
                    Stash it away with “git stash” and try the update again.
                      sweup @Alvinger
                      @Alvinger said in MMM-ResRobot - Public transport information for Sweden:
                      git stash
                      Like this?
                      git stash
                      npm install
                      Edit:misspell
                        Alvinger @sweup
                        @sweup
                        git stash
                        git pull
                        npm install
                          sweup @Alvinger
                          @Alvinger - hmm something email adress. Any advice?
                          pi@raspberrypi:~/MagicMirror/modules/MMM-ResRobot $ git stash
                          *** Please tell me who you are.
                          Run
                            git config --global user.email "you@example.com"
                            git config --global user.name "Your Name"
                          to set your account's default identity.
                          Omit --global to set the identity only in this repository.
                          fatal: unable to auto-detect email address (got 'pi@raspberrypi.(none)')
                          Cannot save the current index state
                          	package.json
                          Aborting
                          up to date in 1.02s
                            sdetweil @sweup
                            @sweup let’s find out what u changed
                            do
                            git diff
                              sweup @sdetweil
                              @sdetweil - sry I’m a bit lost, do I do “git diff” after?
                              git stash
                              git pull
                              npm install
                                sdetweil @sweup
                                @sweup git stash fails cause u are not registered to git on your machine
                                git pull fails cause it would overwrite a change u.made to package.json
                                so, I was trying to find out what the change was, and how important it is…
                                the other commands won’t work til we resolve the diff(erence) issue
                                  sweup
                                  @sdetweil @Alvinger - thx guys, after
                                  $ git config --global user.email "you@example.com"
                                  $ git config --global user.name "Your Name"
                                  I could solve it with git stash
                                    sdetweil @sweup
                                    @sweup yeh, but we don’t know what change u lost/stashed
                                      Alvinger @sdetweil
                                      @sdetweil @sweup
                                      My guess is that it is an unintended change probably caused by saving rather than exiting when viewing the file.
                                      Anyway, package.json only contains information about the module and can without issue be replaced with a “git pull”.
                                      @sweup Great that you solved it. A small suggestion for the future: as most modules (and MagicMirror itself) uses Github you should read up on GIT and its basic commands. It will make life easier for you!
                                        Alvinger
                                        @sweup I just pushed a minor update with some new options. Feel free to try the new version out.
                                        • Z Offline
                                          Zapman
                                          Hello! :D
                                          Got some issue with the module. The module loads when starting up MagicMirror, but stays at “Fetching departures …”. I tried my API key here;
                                          (https://api.resrobot.se/v2/trip?key=API-KEY-HERE&originId=740047279&destId=740010151&format=xml) and it worked fine. So the key itself seams to work. I’m using the API key from “ResRobot - Reseplanerare”. I set the key in the config.js.
                                          My current config.js;
        routes: [ // stations from:
        {from: "740015972", to: ""},
        apiKey: "API-KEY-HERE"
                                          Terminal message;
                                          [2020-09-23 03:21:58.036] [LOG]    node_helper for MMM-ResRobot received a socket notification: CONFIG - Payload: {
                                            "updateInterval": 60000,
                                            "animationSpeed": 2000,
                                            "fade": true,
                                            "fadePoint": 0.25,
                                            "apiBase": "https://api.resrobot.se/v2/departureBoard?format=json&passlist=0",
                                            "apiKey": "API-KEY-HERE",
                                            "routes": [
                                                "from": "740015972",
                                                "to": ""
                                            "skipMinutes": 0,
                                            "maximumEntries": 6,
                                            "truncateAfter": 5,
                                            "truncateLineAfter": 5,
                                            "showTrack": true,
                                            "getRelative": 0,
                                            "coloredIcons": false,
                                            "iconTable": {
                                              "B": "fa fa-bus",
                                              "S": "fa fa-subway",
                                              "J": "fa fa-train",
                                              "U": "fa fa-subway",
                                              "F": "fa fa-ship"
                                            "colorTable": {
                                              "B": "#DA4439",
                                              "S": "#019CD5",
                                              "J": "#FDB813",
                                              "U": "#019CD5",
                                              "F": "#444400"
                                          Maybe someone can have an idea what might be wrong here :crazy_face:
                                            Alvinger @Zapman
                                            @Zapman I’ll have a look. Your config looks fine at a first look.
                                            • 6 / 7
