    MMM-SORT still needs API key ?
    8 Posts 3 Posters 1.4k Views 3 Watching
      RIKKO14
        sdetweil @RIKKO14
        @RIKKO14 it will work if you BUY a key. otherwise not
        no dependencies means the code is self contained, no other libraries used. (not useful info if no apikey)
          RIKKO14
          ok, thanks you.
            RIKKO14 @RIKKO14
            ok, thanks you.
            do you know if it exist a module without buy a key to have the tides ?
              sdetweil @RIKKO14
              @RIKKO14 no, i do not know
              • thgmirrorT Offline
                thgmirror
                @RIKKO14 as a workaround you can show the content of a website with the following HTML-code (as an example Cadiz in Spain):
                Store this as a file in the modules-folder with the extension html and use SmartWebDisplay to display it.
                To get another location go to https://www.tideking.com/ and use the search function to find it. Take the url and enter it in the HTML.
                Leads to
                  sdetweil @thgmirror
                  @thgmirror u might be able to use one of the iframe modules for that
                    thgmirror
                    @sdetweil yes, I tried it but the parameter (margin/width/high etc.) drives me crazy…it was much easier for me to create a local html. And it is not time-critical. updating every 24 hours will be enough.
                    Thomas
