    Trigger showing IP camera stream (iFrame?) via API call
    5 Posts 3 Posters 979 Views 3 Watching
    • V Offline
      velkrosmaak
      Loving my magicmirror setup, mainly showing Google photos and news which is great. I’ve been trying to work out how I can have the display switch to a full screen camera view when movement is detected on that camera. I’m using motioneye for the cameras, and Home Assistant for automation. From that, I can easily make an API call when movement is detected, so I wondered if there was a way I could achieve that.
      I couldn’t find any plugins that seemed to support this, and the MM API docs don’t suggest this would work either. Anyone tried anything similar?
        sdetweil @velkrosmaak
        @velkrosmaak I use this
        https://motion-project.github.io/
        for motion detection on my MagicMirror
        I don’t stream video, but it’s possible.
        there are events when motion starts, and u can control what to do w the video stream.
        • V Offline
          velkrosmaak
          I see! Motioneye is a web frontend for motion (https://github.com/ccrisan/motioneye) but I don’t understand how the MM side would work.
          S B 2 Replies Last reply Reply Quote 0
            @velkrosmaak trigger rtpstream or some such
              BluP Project Sponsor @velkrosmaak
              @velkrosmaak
              I also use motion to detect and then stream the video via to the MM via MMM_SmartWebDisplay
              In the motion config file (/etc/motion) search for
              ’ # Command to be executed when an event starts. (default: none)
              '# An event starts at first motion detected after a period of no motion defined by event_gap
              '# on_event_start value
              '# Show iFrame in MagicMirror
              on_event_start /etc/motion/notifyOn_MM.sh
              '# Command to be executed when an event ends after a period of no motion
              '# (default: none). The period of no motion is defined by option event_gap.
              '# on_event_end value
              '# Hide iFrame on MagicMirror
              on_event_end /etc/motion/notifyOff_MM.sh
              and the scripts could look like:
              '# Show SmartWebDisplay in MagicMirror (iFrame no longer supported in MM 2.7.1)
              curl --no-verbose http://:8080/remote?action=SHOW"&"module=module_10_MMM-SmartWebDisplay
              Peter
