    MMM-ArduPort
    14 Posts 3 Posters 4.7k Views 4 Watching
    • K
      Kereknjek
      I’m having trouble setting up MMM-ArduPort. So if anyone can help…
      I have to point out that I’m using SAME serial port on arduino for communication with raspberry and RS485 network. For transmiting and receiveing data on RS485 I use fantastic EasyTransfer arduino library.
      Posible problem:
      When arduino receives data from RS485, it gets to TX pin on USB side and never gets to raspberry. Wich is good.
      When arduino is sending data, to transmit over RS485, it first have to activate transmision mode on RS485 module.
      In this situation, data is being sent from arduino TX to RS485 RX. But it is allso sent to USB RX, and to raspberry. Wich is bad. I gues.
      Here are symptoms:
      MM starts and ArduPort is waiting for arduino.
      I connect arduino, ArduPort receives “[status:setup:starting]” and “[status:setup:started]”
      ArduPort shows my sensors list and then it removes them and returns to “Waiting for connection…”
      My arduino code sends “[status:setup:starting]”, waits for 3 seconds and sends “[status:setup:started]” witch is normaly received by Arduport.
      But! Arduino then sends request for sensors status to RS485 wich is allso transmited to raspberry. I think that in this moment it switches to “Waiting for connection”.
      But, again, I have modified MMM-ArduPort.js so it doesen’t disconnect (commented ), and I have aded “this.isArduinoStarting = false;” and “this.isArduinoStarted = true;” right after "case ‘sensor’: "
      I modified this so arduino always stays connected, and data should be displayed whenever and whatever sensor data is received. And it actualy does switch to listing my sensors, but, again, sensor data isn’t shown.
      I taught that EasyTransfer requests that get to PI are chrashing communication, but after my mod, I can see that data is passed normaly and is not affected by EasyTransfer part.
      I gues, that part is discarded at this part in arduino.py
      match = re.match(rgxData, data)
      if match:
                  data = data[1:-1]
                  case, name, value = data.split(":")
                  to_node(case.lower(), {"name": name, "data": value})
      Here is photo of data being received on screen /dev/ttyUSB0 (yes… photo. I was in a hurry…)
      Pictograms between [sensor:name:data] are EasyTransfer requests.
      I’ve even tryed this modification. It didn’t help.
      • K
        Kereknjek
        I have reinstaled all original files for arduport and started debuging… Again.:smiling_face_with_open_mouth_cold_sweat:
        I didn’t mention it before, but I’m running MM on Raspbian lite.
        I’ve found I had problems with python. Force reinstalling modules solved it.
        I have allso found some errors in arduino.py,
        Had to change:
        rgxData = re.compile("[\[][a-zA-Z0-9-].*[\:][a-zA-Z0-9-].*[\:][a-zA-Z0-9-.].*[\]]")
        to
        rgxData = re.compile("[\[][a-zA-Z0-9\-].*[\:][a-zA-Z0-9\-].*[\:][a-zA-Z0-9\-\.].*[\]]")
        and
        incoming = self.arduino.readline(self.arduino.in_waiting).decode('ascii').replace('\r', '').replace('\n', '')
        to
        incoming = self.arduino.readline(self.arduino.in_waiting).decode('ascii', errors="ignore").replace('\r', '').replace('\n', '')
        Now, when running
        python arduport.py
        I get this:
        {"debug": "SerialPort shell started..."}
        {"debug": "Waiting Ardunio to connect on port..."}
        {"status": {"data": "connected", "name": "connect"}}
        {"status": {"data": "starting", "name": "setup"}}
        {"status": {"data": "started", "name": "setup"}}
        {"sensor": {"data": "0.02", "name": "Baterija"}}
        {"sensor": {"data": "-0.00", "name": "Struja"}}
        {"sensor": {"data": "0.00", "name": "Solarno"}}
        {"sensor": {"data": "-0.12", "name": "Panel"}}
        {"sensor": {"data": "-0.00", "name": "Inverter"}}
        {"sensor": {"data": "0.04", "name": "Baterija"}}
        I’m guesing, this should be working now. But ArduPort is still stuck at “Waiting for connection…”
        Here is C/P from my config.js
                      module: "MMM-ArduPort",
                      header: "Solarni sustav",
                      config:{
                              portname: "/dev/ttyUSB0",
                              updateInterval: 1,
                              animationSpeed: 1000,
                              displayIcons: false,
                              showDescriptopn: true,
                              hideLoading: false,
                              hideWaiting: false,
                              useColors: false,
                              sensors: [
                                      description: "Solarni sustav",
                                      maxValue: 5,
                                      maxFormat: "({0}) ",
                                      highestValue: 4,
                                      highestFormat: "({0}) Greska - pregrijavanje",
                                      highValue: 3,
                                      highFormat: "({0}) Greska - preopterecenje",
                                      lowValue: 2,
                                      lowFormat: "({0}) Backup mod",
                                      lowestValue: 1,
                                      lowestFormat: "({0}) Ukljuceno",
                                      minValue: 0,
                                      minFormat: "({0}) Iskljuceno"
                                      description: "Stanje baterije",
                                      maxValue: 26,
                                      maxFormat: "({0} V) Balansiranje",
                                      highestValue: 25.5,
                                      highestFormat: "({0} V) 100%",
                                      highValue: 24.87,
                                      highFormat: "({0} V) 75%",
                                      lowValue: 24.2,
                                      lowFormat: "({0} V) 50%",
                                      lowestValue: 11.74,
                                      lowestFormat: "({0} V) 25%",
                                      minValue: 23.2,
                                      minFormat: "({0} V) 0%"
                                      description: "Punjenje ili praznjenje",
                                      maxValue: 20,
                                      maxFormat: "({0} A) Punjenje",
                                      highestValue: 10,
                                      highestFormat: "({0} A) Punjenje",
                                      highValue: 0,
                                      highFormat: "({0} A) ",
                                      lowValue: -20,
                                      lowFormat: "({0} A) Praznjenje",
                                      lowestValue: -40,
                                      lowestFormat: "({0} A) Brzo preznjenje",
                                      minValue: -60,
                                      minFormat: "({0} A) PREOPTERECENJE"
                                      description: "Snaga solarnih panela",
                                      maxValue: 500,
                                      maxFormat: "({0} W)",
                                      highestValue: 400,
                                      highestFormat: "({0} W)",
                                      highValue: 300,
                                      highFormat: "({0} W)",
                                      lowValue: 200,
                                      lowFormat: "({0} W)",
                                      lowestValue: 100,
                                      lowestFormat: "({0} W)",
                                      minValue: 0,
                                      minFormat: "({0} W)"
                                      description: "Potrosnja invertera",
                                      maxValue: 1000,
                                      highestValue: 800,
                                      highValue: 600,
                                      lowValue: 400,
                                      lowestValue: 200,
                                      minValue: 0,
        EDIT:
        Here is C/P from chrome console:
        Starting module: MMM-ArduPort
        MMM-ArduPort.js:286 [MMM-ArduPort]:: MMM-ArduPort: status
        MMM-ArduPort.js:286 [MMM-ArduPort]:: MMM-ArduPort: {
            "action": "status",
            "name": "initialized"
        MMM-ArduPort.js:286 [MMM-ArduPort]:: MMM-ArduPort: error
        MMM-ArduPort.js:286 [MMM-ArduPort]:: MMM-ArduPort: "pyshell-throw"
        MMM-ArduPort.js:123 [socketNotificationReceived::error]:
        S K 2 Replies Last reply
          sdetweil @Kereknjek
          @Kereknjek said in MMM-ArduPort:
          MMM-ArduPort.js:286 [MMM-ArduPort]:: MMM-ArduPort: “pyshell-throw”
          yes, according to the code, this notifies the module that the python script running in the background ended, unexpectedly.
          I would try running it from the commandshell in the foreground without the MM and see what is going on
          • K
            Kereknjek
            How do I do that?
            • K
              Kereknjek
              It seems I’m having isues with Python.
              I have reinstaled Python and Python3, npm, python-shell and node js. Nothing worked. It was sending errors even with blank arduino, arduino sending only “starting” and “started” commands…
              So, due to my lack of knowlege of Python or anything else surrounding ArduPort, I’m abandoning it…
              To bad. It is very elagant module.
                sdetweil @Kereknjek
                How do I do that?
                on the pi, ctrl-alt-t, will open a terminal window, you can also ssh into the pi
                then execute the command that the module would use
                python .......  whatever
                I see u dropped this path, but for other…
                • K
                  Kereknjek @Kereknjek
                  I tried that.
                  Now, when running
                  python arduport.py
                  I get this:
                    sdetweil @Kereknjek
                    @Kereknjek that looks good…
                    looks at the MMM-Arduino module, it shows debugging info on the developers window
                    ctrl-shift-i on the keyboard, select the tab labeled ‘console’
                    you can filter out other modules messages by putting part of the module name in the filter field
                    ardu
                    also, have to set developerMode:true in the module config.js section
                    		    if (self.config.developerMode) {
                    			      var date = new Date();
                    			      var time = date.getHours() + ":" + date.getMinutes() + ":" + date.getSeconds();
                    			      message = self.name + ": (" + self.data.index + ")(" + time + ") " + message;
                    		    } else { message = self.name + ": " + message; }
                    		    switch (type) {
                    			  case "error": Log.error(this.logPrefix + message); break;
                    			  case "warn": Log.warn(this.logPrefix + message); break;
                    			  case "info": Log.info(this.logPrefix + message); break;
                    			  case "dev": if (self.config.developerMode) { Log.log(this.logPrefix + message); } break;
                    			  default: Log.log(this.logPrefix + message);
                      Crime
                      has anyone solved this problem?
                      I don’t understand anything at all in JS?
                      error text from console:
                      Uncaught (in promise) TypeError: "({0}) ".format is MMM-ArduPort.js:143
                      not a function
                          at Class.formatValue (MMM-ArduPort.js:143)
                          at Class.getDom (MMM-ArduPort.js:250)
                          at main.js:111
                          at new Promise (<anonymous>)
                          at updateDom (main.js:110)
                          at Object.updateDom (main.js:542)
                          at Class.updateDom (module.js:357)
                          at Class.socketNotificationReceived (MMM-ArduPort.js:118)
                          at module.js:243
                          at r.<anonymous> (socketclient.js:39)
                      help someone, I’ve been trying to run it for a long time !!!
                        sdetweil @Crime
                        @Crime as I posted the other day, someone posted a fix in the issue for the module
                        u have to change some code
                        C 1 Reply Last reply
                          Crime @sdetweil
                          @sdetweil please, more details. I really need help
                            sdetweil @Crime
                            @Crime sorry, other topic
                            see this issue on the module
                            https://github.com/Dentrax/MMM-ArduPort/issues/3
                              Crime @sdetweil
                              @sdetweil thank you so much! it really helped! now my sensors are working as they should!
                              and how I did not notice this topic before
                                sdetweil @Crime
                                @Crime could you help this guy
                                https://forum.magicmirror.builders/topic/13681/is-it-possible-to-ad-an-arduino/53
                                his sketch and module data don’t match.
