    MMM-ArduPort
    14 Posts 3 Posters 4.7k Views 4 Watching
    • K
      Kereknjek
      How do I do that?
      • K
        Kereknjek
        It seems I’m having isues with Python.
        I have reinstaled Python and Python3, npm, python-shell and node js. Nothing worked. It was sending errors even with blank arduino, arduino sending only “starting” and “started” commands…
        So, due to my lack of knowlege of Python or anything else surrounding ArduPort, I’m abandoning it…
        To bad. It is very elagant module.
          sdetweil @Kereknjek
          @Kereknjek said in MMM-ArduPort:
          How do I do that?
          on the pi, ctrl-alt-t, will open a terminal window, you can also ssh into the pi
          then execute the command that the module would use
          python .......  whatever
          I see u dropped this path, but for other…
          • K
            Kereknjek @Kereknjek
            I tried that.
            Now, when running
            python arduport.py
            I get this:
            {"debug": "SerialPort shell started..."}
            {"debug": "Waiting Ardunio to connect on port..."}
            {"status": {"data": "connected", "name": "connect"}}
            {"status": {"data": "starting", "name": "setup"}}
            {"status": {"data": "started", "name": "setup"}}
            {"sensor": {"data": "0.02", "name": "Baterija"}}
            {"sensor": {"data": "-0.00", "name": "Struja"}}
            {"sensor": {"data": "0.00", "name": "Solarno"}}
            {"sensor": {"data": "-0.12", "name": "Panel"}}
            {"sensor": {"data": "-0.00", "name": "Inverter"}}
            {"sensor": {"data": "0.04", "name": "Baterija"}}
              sdetweil @Kereknjek
              @Kereknjek that looks good…
              looks at the MMM-Arduino module, it shows debugging info on the developers window
              ctrl-shift-i on the keyboard, select the tab labeled ‘console’
              you can filter out other modules messages by putting part of the module name in the filter field
              ardu
              also, have to set developerMode:true in the module config.js section
              		    if (self.config.developerMode) {
              			      var date = new Date();
              			      var time = date.getHours() + ":" + date.getMinutes() + ":" + date.getSeconds();
              			      message = self.name + ": (" + self.data.index + ")(" + time + ") " + message;
              		    } else { message = self.name + ": " + message; }
              		    switch (type) {
              			  case "error": Log.error(this.logPrefix + message); break;
              			  case "warn": Log.warn(this.logPrefix + message); break;
              			  case "info": Log.info(this.logPrefix + message); break;
              			  case "dev": if (self.config.developerMode) { Log.log(this.logPrefix + message); } break;
              			  default: Log.log(this.logPrefix + message);
                Crime
                has anyone solved this problem?
                I don’t understand anything at all in JS?
                error text from console:
                Uncaught (in promise) TypeError: "({0}) ".format is MMM-ArduPort.js:143
                not a function
                    at Class.formatValue (MMM-ArduPort.js:143)
                    at Class.getDom (MMM-ArduPort.js:250)
                    at main.js:111
                    at new Promise (<anonymous>)
                    at updateDom (main.js:110)
                    at Object.updateDom (main.js:542)
                    at Class.updateDom (module.js:357)
                    at Class.socketNotificationReceived (MMM-ArduPort.js:118)
                    at module.js:243
                    at r.<anonymous> (socketclient.js:39)
                help someone, I’ve been trying to run it for a long time !!!
                  sdetweil @Crime
                  @Crime as I posted the other day, someone posted a fix in the issue for the module
                  u have to change some code
                  C 1 Reply Last reply
                    Crime @sdetweil
                    @sdetweil please, more details. I really need help
                      sdetweil @Crime
                      @Crime sorry, other topic
                      see this issue on the module
                      https://github.com/Dentrax/MMM-ArduPort/issues/3
                        Crime @sdetweil
                        @sdetweil thank you so much! it really helped! now my sensors are working as they should!
                        and how I did not notice this topic before
                          sdetweil @Crime
                          @Crime could you help this guy
                          https://forum.magicmirror.builders/topic/13681/is-it-possible-to-ad-an-arduino/53
                          his sketch and module data don’t match.
