    MMM-Wunderlist: Invalid namespace Error
    4 Posts 2 Posters 2.9k Views 2 Watching
    • H Offline
      huckstopper
      I am unable to get the Wunderlist module to successfully render my list items. I am able to successfully curl the API with my token and client id - my config matches those settings.
      The only error I can see standing out is the "MMM-Wunderlist,‘Invalid namespace’ " error I see in the network traffic back to the socket. I updated node to v7 and socket.io to make sure I was running the latest of each.
      Any help would be appreciated. Thanks.
        paviro
        ‘Invalid namespace’ is logged to the console?
        – The Doctor
        • H Offline
          huckstopper
          Correct. When viewing the socket traffic in the Network tab. I’ve also stepped through the JS on the client side and confirmed nothing is in the array.
          0_1479656148246_upload-4ef3273a-8930-4425-ac99-0d00dfd04ae8
          My config:
          	        module: 'MMM-Wunderlist',
          	        position: 'top_left',  // This can be any of the regions. Best results in left or right regions.
          	        header: 'Home', // This is optional
          	        config: { // See 'Configuration options' for more information.
          	            accessToken: 'token',
          	            clientID: 'client_id',
          	            maximumEntries: 60,
          	            interval: 60,
          	            lists: [ "Home" ],
          	            fade: false
          • H Offline
            huckstopper
            Successful curl:
            0_1479734984391_upload-0649f5be-43e3-4221-9b67-d1f9b3dc2a7b
            However, on the client side when it is checking for ToDos, nothing comes through:
            0_1479735598080_upload-e83f3dd2-ebed-4d40-909e-bb93cca5bf05
            0_1479736036922_upload-2f2887b4-ca87-41b1-ade6-c603636241f5
            Obviously there will be subsequent I/O with the socket but I’m assuming if nothing returns here then any of the other requests will follow suit.
            Is there a specific spot in the server side code I should focus on?
