MMM-Wunderlist: Invalid namespace Error
I am unable to get the Wunderlist module to successfully render my list items. I am able to successfully curl the API with my token and client id - my config matches those settings.
The only error I can see standing out is the "MMM-Wunderlist,‘Invalid namespace’ " error I see in the network traffic back to the socket. I updated node to v7 and socket.io to make sure I was running the latest of each.
Any help would be appreciated. Thanks.
‘Invalid namespace’ is logged to the console?
Correct. When viewing the socket traffic in the Network tab. I’ve also stepped through the JS on the client side and confirmed nothing is in the array.
My config:
{ module: 'MMM-Wunderlist', position: 'top_left', // This can be any of the regions. Best results in left or right regions. header: 'Home', // This is optional config: { // See 'Configuration options' for more information. accessToken: 'token', clientID: 'client_id', maximumEntries: 60, interval: 60, lists: [ "Home" ], fade: false } }, -
Successful curl:
However, on the client side when it is checking for ToDos, nothing comes through:
Obviously there will be subsequent I/O with the socket but I’m assuming if nothing returns here then any of the other requests will follow suit.
Is there a specific spot in the server side code I should focus on?
