    Black screen after 2.13 update - tentatively resolved
    53 Posts 9 Posters 26.3k Views 9 Watching
      sdetweil @swvalenti
      @swvalenti i wonder why YOU see it and no one else does…
      • swvalentiS
        swvalenti Project Sponsor
        I have no clue on that as all my units run the same hardware and OS
          sdetweil @swvalenti
          @swvalenti I opened issue https://github.com/MichMich/MagicMirror/issues/2147 to track this
          • swvalentiS
            Same unit that give me earlier issue does not load darksky or pokemon…my kids monitor…lol…other mirrors run darksky with no problem.
            Scripts loaded for: MMM-EARTH
            loader.js:195 Load stylesheet: modules/MMM-EARTH/MMM-EARTH.css
            loader.js:155 Styles loaded for: MMM-EARTH
            loader.js:157 Translations loaded for: MMM-EARTH
            loader.js:176 Load script: modules/MMM-DarkSkyForecast//MMM-DarkSkyForecast.js
            module.js:505 Check MagicMirror version for module 'MMM-DarkSkyForecast' - Minimum version:  2.2.0 - Current version: undefined
            module.js:528 Uncaught TypeError: Cannot read property 'replace' of undefined
                at cmpVersions (module.js:528)
                at Function.Module.register (module.js:506)
                at MMM-DarkSkyForecast.js:41
            loader.js:176 Load script: modules/MMM-DailyPokemon//MMM-DailyPokemon.js
            module.js:505 Check MagicMirror version for module 'MMM-DailyPokemon' - Minimum version:  2.1.0 - Current version: undefined
                at MMM-DailyPokemon.js:10
            loader.js:176 Load script: modules/MMM-EventHorizon//MMM-EventHorizon.js
            module.js:513 Module registered: MMM-EventHorizon
            loader.js:148 Bootstrapping module: MMM-EventHorizon
            loader.js:153 Scripts loaded for: MMM-EventHorizon
            loader.js:195 Load stylesheet: modules/MMM-EventHorizon/MMM-EventHorizon.css
            loader.js:155 Styles loaded for: MMM-EventHorizon
              sdetweil @swvalenti
              @swvalenti weird. this is 2.13 now?
              grep version ~/MagicMirror/package.json
              can’t believe the version check would fail
              swvalentiS 1 Reply Last reply Reply Quote 0
              • swvalentiS
                swvalenti Project Sponsor @sdetweil
                @sdetweil Yes sir 2.13
                Last login: Fri Oct  2 17:10:33 2020
                pi@raspberrypi:~ $ grep version ~/MagicMirror/package.json
                        "version": "2.13.0",
                pi@raspberrypi:~ $
                  sdetweil @swvalenti
                  @swvalenti edit the modulename.js for each
                  comment out (leading //)
                  requiresVersion: “2.1.0”,
                  • swvalentiS
                    That gave me a black screen
                      sdetweil @swvalenti
                      @swvalenti
                      //requiresVersion: “2.1.0”,
                      • swvalentiS
                        Correct, only pokemon had 2.1.0 I didnt see 2.1.0 in darksky just 2.2.0
                          sdetweil @swvalenti
                          @swvalenti and u commented it out in darksky, yes?
                          show errors
                          • swvalentiS
                            Refused to execute inline script because it violates the following Content Security Policy directive: "script-src 'self'". Either the 'unsafe-inline' keyword, a hash ('sha256-YvJxUhUeeIN7m4Y4YEc1FVS+YDCNVK6VsHIHx5z29EE='), or a nonce ('nonce-...') is required to enable inline execution.
                            main.js:487 Initializing MagicMirror.
                            translator.js:129 Loading core translation file: translations/en.json
                            translator.js:154 Loading core translation fallback file: translations/en.json
                            loader.js:176 Load script: modules/default/alert//alert.js
                            module.js:513 Module registered: alert
                            loader.js:148 Bootstrapping module: alert
                            loader.js:176 Load script: modules/default/alert/notificationFx.js
                            loader.js:153 Scripts loaded for: alert
                            loader.js:195 Load stylesheet: modules/default/alert/notificationFx.css
                            loader.js:195 Load stylesheet: vendor/css/font-awesome.css
                            loader.js:155 Styles loaded for: alert
                            translator.js:102 alert - Load translation fallback: translations/en.json
                            /home/pi/MagicMirror…rity-warnings.js:95 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure
                              protocols.This exposes users of this app to unnecessary security risks.
                              Consider loading the following resources over HTTPS or FTPS.
                             - http://0.0.0.0:8080/css/main.css
                            - http://0.0.0.0:8080/fonts/roboto.css
                            - http://0.0.0.0:8080/socket.io/socket.io.js
                            - http://0.0.0.0:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
                            - http://0.0.0.0:8080/js/defaults.js
                            - http://0.0.0.0:8080/config/config.js
                            - http://0.0.0.0:8080/vendor/vendor.js
                            - http://0.0.0.0:8080/modules/default/defaultmodules.js
                            - http://0.0.0.0:8080/js/logger.js
                            - http://0.0.0.0:8080/translations/translations.js
                            - http://0.0.0.0:8080/js/translator.js
                            - http://0.0.0.0:8080/js/class.js
                            - http://0.0.0.0:8080/js/module.js
                            - http://0.0.0.0:8080/js/loader.js
                            - http://0.0.0.0:8080/js/socketclient.js
                            - http://0.0.0.0:8080/js/main.js
                            - http://0.0.0.0:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
                            - http://0.0.0.0:8080/translations/en.json
                            - http://0.0.0.0:8080/modules/default/alert//alert.js
                            - http://0.0.0.0:8080/modules/default/alert/notificationFx.js
                            - http://0.0.0.0:8080/modules/default/alert/notificationFx.css
                            - http://0.0.0.0:8080/vendor/css/font-awesome.css
                            - http://0.0.0.0:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/all.min.css
                            - http://0.0.0.0:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/v4-shims.min.css
                            For more information and help, consult
                            https://electronjs.org/docs/tutorial/security.
                             This warning will not show up
                            once the app is packaged.
                            loader.js:157 Translations loaded for: alert
                            0.0.0.0/:4 Uncaught SyntaxError: Unexpected token / in JSON at position 44
                                at JSON.parse (<anonymous>)
                                at XMLHttpRequest.xhr.onreadystatechange (translator.js:22)
                              sdetweil @swvalenti
                              @swvalenti let me work on it. is that a pi0 perhaps, running chrome instead of electron?
                              • swvalentiS
                                No sir it is a pi3b+ running buster
                                  sdetweil @swvalenti
                                  @swvalenti after looking at my dev console I see the same content security warning, but it is not fatal… just a warning…
                                  I added the
                                  requiresVersion: "2.1.0",
                                  to the calendar and it worked fine,
                                  then commented out
                                  //requiresVersion: "2.1.0",
                                  still worked ok…
                                  and didn’t need that meta tag…
                                  so, there must be something else going on…
                                  can u rename the config.js out of the way (config.js.save)
                                  and copy the sample
                                  cp config.js.sample config.js
                                  and try MM again
                                  • spitzlbergerjS
                                    spitzlbergerj Project Sponsor Module Developer @m0bed
                                    @m0bed said in Black screen after 2.13 update - tentatively resolved:
                                    @m0bed So, I changed my config found out that this modules dont work at the moment:
                                    MMM-Homematic-Heaters
                                    The problem are the comments in the two translation files . Remove the comments and it will work again.
                                    Since MMM-Homematic-Heaters seems to be no longer maintained, I have forked the module MMM-Homematic-Thermostats from it and developed it further. There the error is fixed. Maybe changing the module will help :-)
                                    Regards
                                    Josef
                                    http://www.spitzlberger.de/smartmirror, https://github.com/spitzlbergerj/MMM-TeslaLogger, https://github.com/spitzlbergerj/CaravanPi, https://www.la-gondola-barocca.de
                                    • swvalentiS
                                      Somehow it was the MMM-DailyPokemon jacking all things up. Removed and all is working fine again.
                                        sdetweil @swvalenti
                                        @swvalenti probably the comments in the translation files, en and fr
                                        • swvalentiS
                                          Yes that is the error it was showing but I didn’t know how to proceed in fixing.
                                            sdetweil @swvalenti
                                            @swvalenti edit the json files in the translations folder and remove the comment. one of the others does not have a comment for example
                                            • 2 / 3
