    Black screen after 2.13 update - tentatively resolved
    53 Posts 9 Posters 24.8k Views 9 Watching
    • swvalentiS Offline
      swvalenti Project Sponsor
      This is what the dev console error is…
      /home/pi/MagicMirror…rity-warnings.js:95 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure
        protocols.This exposes users of this app to unnecessary security risks.
        Consider loading the following resources over HTTPS or FTPS.
       - http://0.0.0.0:8080/css/main.css
      - http://0.0.0.0:8080/fonts/roboto.css
      - http://0.0.0.0:8080/socket.io/socket.io.js
      - http://0.0.0.0:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
      - http://0.0.0.0:8080/js/defaults.js
      - http://0.0.0.0:8080/config/config.js
      - http://0.0.0.0:8080/vendor/vendor.js
      - http://0.0.0.0:8080/modules/default/defaultmodules.js
      - http://0.0.0.0:8080/js/logger.js
      - http://0.0.0.0:8080/translations/translations.js
      - http://0.0.0.0:8080/js/translator.js
      - http://0.0.0.0:8080/js/class.js
      - http://0.0.0.0:8080/js/module.js
      - http://0.0.0.0:8080/js/loader.js
      - http://0.0.0.0:8080/js/socketclient.js
      - http://0.0.0.0:8080/js/main.js
      - http://0.0.0.0:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
      - http://0.0.0.0:8080/translations/en.json
      - http://0.0.0.0:8080/modules/default/alert//alert.js
      - http://0.0.0.0:8080/modules/default/alert/notificationFx.js
      - http://0.0.0.0:8080/modules/default/alert/notificationFx.css
      - http://0.0.0.0:8080/vendor/css/font-awesome.css
      - http://0.0.0.0:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/all.min.css
      - http://0.0.0.0:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/v4-shims.min.css
      For more information and help, consult
      https://electronjs.org/docs/tutorial/security.
       This warning will not show up
      once the app is packaged.
      /home/pi/MagicMirror…ity-warnings.js:145 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
          Policy set or a policy with "unsafe-eval" enabled. This exposes users of
        sdetweil @swvalenti
        @swvalenti said in Black screen after 2.13 update - tentatively resolved:
        hm…
        try this
        edit ~/MagicMirror/index.html
        < head>
        	< title>MagicMirror²< /title>
        	< meta name="google" content="notranslate" />
        	< meta http-equiv="Content-type" content="text/html; charset=utf-8" />
        	< meta name="apple-mobile-web-app-capable" content="yes">
        	< meta name="apple-mobile-web-app-status-bar-style" content="black">
        	< meta name="format-detection" content="telephone=no">
        	< meta name="mobile-web-app-capable" content="yes">
        	< meta http-equiv="Content-Security-Policy" content="script-src 'self';"> < ---- insert this line without the space after <
          Sam, that worked thank you very much!
            sdetweil @swvalenti
            @swvalenti i wonder why YOU see it and no one else does…
              I have no clue on that as all my units run the same hardware and OS
                sdetweil @swvalenti
                @swvalenti I opened issue https://github.com/MichMich/MagicMirror/issues/2147 to track this
                  Same unit that give me earlier issue does not load darksky or pokemon…my kids monitor…lol…other mirrors run darksky with no problem.
                  Scripts loaded for: MMM-EARTH
                  loader.js:195 Load stylesheet: modules/MMM-EARTH/MMM-EARTH.css
                  loader.js:155 Styles loaded for: MMM-EARTH
                  loader.js:157 Translations loaded for: MMM-EARTH
                  loader.js:176 Load script: modules/MMM-DarkSkyForecast//MMM-DarkSkyForecast.js
                  module.js:505 Check MagicMirror version for module 'MMM-DarkSkyForecast' - Minimum version:  2.2.0 - Current version: undefined
                  module.js:528 Uncaught TypeError: Cannot read property 'replace' of undefined
                      at cmpVersions (module.js:528)
                      at Function.Module.register (module.js:506)
                      at MMM-DarkSkyForecast.js:41
                  loader.js:176 Load script: modules/MMM-DailyPokemon//MMM-DailyPokemon.js
                  module.js:505 Check MagicMirror version for module 'MMM-DailyPokemon' - Minimum version:  2.1.0 - Current version: undefined
                      at MMM-DailyPokemon.js:10
                  loader.js:176 Load script: modules/MMM-EventHorizon//MMM-EventHorizon.js
                  module.js:513 Module registered: MMM-EventHorizon
                  loader.js:148 Bootstrapping module: MMM-EventHorizon
                  loader.js:153 Scripts loaded for: MMM-EventHorizon
                  loader.js:195 Load stylesheet: modules/MMM-EventHorizon/MMM-EventHorizon.css
                  loader.js:155 Styles loaded for: MMM-EventHorizon
                    sdetweil @swvalenti
                    @swvalenti weird. this is 2.13 now?
                    grep version ~/MagicMirror/package.json
                    can’t believe the version check would fail
                    swvalentiS 1 Reply Last reply Reply Quote 0
                      swvalenti Project Sponsor @sdetweil
                      @sdetweil Yes sir 2.13
                      Last login: Fri Oct  2 17:10:33 2020
                      pi@raspberrypi:~ $ grep version ~/MagicMirror/package.json
                              "version": "2.13.0",
                      pi@raspberrypi:~ $
                        sdetweil @swvalenti
                        @swvalenti edit the modulename.js for each
                        comment out (leading //)
                        requiresVersion: “2.1.0”,
                          That gave me a black screen
                            sdetweil @swvalenti
                            @swvalenti
                            //requiresVersion: “2.1.0”,
                              Correct, only pokemon had 2.1.0 I didnt see 2.1.0 in darksky just 2.2.0
                                sdetweil @swvalenti
                                @swvalenti and u commented it out in darksky, yes?
                                show errors
                                  Refused to execute inline script because it violates the following Content Security Policy directive: "script-src 'self'". Either the 'unsafe-inline' keyword, a hash ('sha256-YvJxUhUeeIN7m4Y4YEc1FVS+YDCNVK6VsHIHx5z29EE='), or a nonce ('nonce-...') is required to enable inline execution.
                                  main.js:487 Initializing MagicMirror.
                                  translator.js:129 Loading core translation file: translations/en.json
                                  translator.js:154 Loading core translation fallback file: translations/en.json
                                  loader.js:176 Load script: modules/default/alert//alert.js
                                  module.js:513 Module registered: alert
                                  loader.js:148 Bootstrapping module: alert
                                  loader.js:176 Load script: modules/default/alert/notificationFx.js
                                  loader.js:153 Scripts loaded for: alert
                                  loader.js:195 Load stylesheet: modules/default/alert/notificationFx.css
                                  loader.js:195 Load stylesheet: vendor/css/font-awesome.css
                                  loader.js:155 Styles loaded for: alert
                                  translator.js:102 alert - Load translation fallback: translations/en.json
                                  loader.js:157 Translations loaded for: alert
                                  0.0.0.0/:4 Uncaught SyntaxError: Unexpected token / in JSON at position 44
                                      at JSON.parse (<anonymous>)
                                      at XMLHttpRequest.xhr.onreadystatechange (translator.js:22)
                                    sdetweil @swvalenti
                                    @swvalenti let me work on it. is that a pi0 perhaps, running chrome instead of electron?
                                      No sir it is a pi3b+ running buster
                                        sdetweil @swvalenti
                                        @swvalenti after looking at my dev console I see the same content security warning, but it is not fatal… just a warning…
                                        I added the
                                        requiresVersion: "2.1.0",
                                        to the calendar and it worked fine,
                                        then commented out
                                        //requiresVersion: "2.1.0",
                                        still worked ok…
                                        and didn’t need that meta tag…
                                        so, there must be something else going on…
                                        can u rename the config.js out of the way (config.js.save)
                                        and copy the sample
                                        cp config.js.sample config.js
                                        and try MM again
                                        • spitzlbergerjS Offline
                                          spitzlbergerj Project Sponsor Module Developer @m0bed
                                          @m0bed said in Black screen after 2.13 update - tentatively resolved:
                                          @m0bed So, I changed my config found out that this modules dont work at the moment:
                                          MMM-Homematic-Heaters
                                          The problem are the comments in the two translation files . Remove the comments and it will work again.
                                          Since MMM-Homematic-Heaters seems to be no longer maintained, I have forked the module MMM-Homematic-Thermostats from it and developed it further. There the error is fixed. Maybe changing the module will help :-)
                                          Regards
                                          Josef
                                          http://www.spitzlberger.de/smartmirror, https://github.com/spitzlbergerj/MMM-TeslaLogger, https://github.com/spitzlbergerj/CaravanPi, https://www.la-gondola-barocca.de
                                            Somehow it was the MMM-DailyPokemon jacking all things up. Removed and all is working fine again.
                                            • 2 / 3
