    Black screen after 2.13 update - tentatively resolved
    53 Posts 9 Posters 26.3k Views 9 Watching
      sdetweil @Klinge
      @Klinge black screen
      look in two places,
      the window where you start mm,
      using npm start
      or
      pm2
      if pm2 use the command
      pm2 logs --lines=???
      ??? is a number, default is 15
      also look in the developers window
      ctrl-shift-i and select the console tab and scroll up to see any errors
        sdetweil @m0bed
        @m0bed did u run npm install in all the module folders which have a package.json file?
        next time, use my upgrade script
        see here
        • K
          Klinge
          @sdetweil said in Black screen after 2.13 update - tentatively resolved:
          When I run the pm2 logs, I got the following logs
          0|mm     | [2020-10-02 14:32:00.841] [LOG]    Module helper loaded: updatenotification
          0|mm     | [2020-10-02 14:32:00.843] [LOG]    No helper found for module: clock.
          0|mm     | [2020-10-02 14:32:01.602] [LOG]
          0|mm     | Initializing new module helper ...
          0|mm     | [2020-10-02 14:32:01.604] [LOG]    Module helper loaded: MMM-DarkSkyForecast
          0|mm     | [2020-10-02 14:32:01.620] [ERROR]
          0|mm     | WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node-ical'
          0|mm     | Require stack:
          0|mm     | - /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js
          0|mm     | - /home/pi/MagicMirror/modules/default/calendar/node_helper.js
          0|mm     | - /home/pi/MagicMirror/js/app.js
          0|mm     | - /home/pi/MagicMirror/js/electron.js
          0|mm     | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
          0|mm     | -
          0|mm     | [2020-10-02 14:32:01.621] [LOG]    Loading module helpers ...
          0|mm     | [2020-10-02 14:32:01.623] [LOG]    No helper found for module: alert.
          0|mm     | [2020-10-02 14:32:01.627] [LOG]    Initializing new module helper ...
          0|mm     | [2020-10-02 14:32:01.629] [LOG]    Module helper loaded: updatenotification
          0|mm     | [2020-10-02 14:32:01.633] [LOG]    No helper found for module: clock.
          0|mm     | [2020-10-02 14:32:01.637] [LOG]    Initializing new module helper ...
          0|mm     | [2020-10-02 14:32:01.640] [LOG]    Module helper loaded: MMM-DarkSkyForecast
          0|mm     | [2020-10-02 14:32:01.649] [ERROR]
          0|mm     | App threw an error during load
          0|mm     | [2020-10-02 14:32:01.651] [ERROR]  Error: Cannot find module 'node-ical'
          0|mm     | -
          0|mm     |     at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
          0|mm     |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
          0|mm     |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
          0|mm     |     at Function.Module._load (internal/modules/cjs/loader.js:531:27)
          0|mm     |     at Module.require (internal/modules/cjs/loader.js:685:19)
          0|mm     |     at require (internal/modules/cjs/helpers.js:16:16)
          0|mm     |     at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:8:14)
          0|mm     |     at Module._compile (internal/modules/cjs/loader.js:786:30)
          0|mm     |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
          0|mm     |     at Module.load (internal/modules/cjs/loader.js:645:32)
          0|mm     | [2020-10-02 14:32:01.654] [ERROR]  Whoops! There was an uncaught exception...
          0|mm     | [2020-10-02 14:32:01.655] [ERROR]
          0|mm     | Error: Cannot find module 'node-ical'
          0|mm     | -
          0|mm     |     at Module.load (internal/modules/cjs/loader.js:645:32) {
          0|mm     |   code: 'MODULE_NOT_FOUND',
          0|mm     |   requireStack: [
          0|mm     |     '/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js',
          0|mm     |     '/home/pi/MagicMirror/modules/default/calendar/node_helper.js',
          0|mm     |     '/home/pi/MagicMirror/js/app.js',
          0|mm     |     '/home/pi/MagicMirror/js/electron.js',
          0|mm     |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
          0|mm     |     undefined
          0|mm     |   ]
          0|mm     | }
          0|mm     | [2020-10-02 14:32:01.682] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          0|mm     | [2020-10-02 14:32:01.683] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          0|mm     | [2020-10-02 14:32:01.845] [LOG]
          0|mm     | Launching application.
            sdetweil @Klinge
            @Klinge looks like u did not run
            npm install
            after the git pull
            darksky looks like it will need one too
            or use the upgrade script with force at the end, instead of apply
            see here
            • swvalentiS
              swvalenti Project Sponsor
              Sam,
              Used your scrips on 3 updates with no issue except for one install. Getting black screen and ran the logs showing calendar error?
              /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
              0|MagicMir |   syscall: 'read'
              0|MagicMir | }
              0|MagicMir | [2020-09-29 00:11:23.035] [ERROR]  Calendar Error. Could not fetch calendar:  http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics Error: connect ETIMEDOUT 69.16.220.190:80
              0|MagicMir |     at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1054:14) {
              0|MagicMir |   errno: 'ETIMEDOUT',
              0|MagicMir |   code: 'ETIMEDOUT',
              0|MagicMir |   syscall: 'connect',
              0|MagicMir |   address: '69.16.220.190',
              0|MagicMir |   port: 80
              0|MagicMir | }
              0|MagicMir | [25300:0930/035804.824753:FATAL:memory.cc(22)] Out of memory. size=262144
              0|MagicMir | [12409:1001/033404.599579:FATAL:memory.cc(22)] Out of memory. size=262144
              0|MagicMir | [14477:1001/034403.637658:FATAL:memory.cc(22)] Out of memory. size=262144
              0|MagicMir | [14677:1001/034505.102662:FATAL:memory.cc(22)] Out of memory. size=262144
              0|MagicMir | [1436:1002/084636.370183:FATAL:memory.cc(22)] Out of memory. size=262144
              /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
              0|MagicMir | [2020-10-02 08:53:45.855] [LOG]    No helper found for module: MMM-EyeCandy.
              0|MagicMir | [2020-10-02 08:53:45.856] [LOG]    No helper found for module: on-this-day.
              0|MagicMir | [2020-10-02 08:53:45.856] [LOG]    All module helpers loaded.
              0|MagicMir | [2020-10-02 08:53:46.035] [LOG]    Starting server on port 8080 ...
              0|MagicMir | [2020-10-02 08:53:46.044] [INFO]   You're using a full whitelist configuration to allow for all IPs
              0|MagicMir | [2020-10-02 08:53:46.053] [LOG]    Server started ...
              0|MagicMir | [2020-10-02 08:53:46.054] [LOG]    Connecting socket for: updatenotification
              0|MagicMir | [2020-10-02 08:53:46.056] [LOG]    Connecting socket for: calendar
              0|MagicMir | [2020-10-02 08:53:46.057] [LOG]    Starting node helper for: calendar
              0|MagicMir | [2020-10-02 08:53:46.058] [LOG]    Connecting socket for: MMM-EARTH
              0|MagicMir | [2020-10-02 08:53:46.059] [LOG]    Starting module: MMM-EARTH
              0|MagicMir | [2020-10-02 08:53:46.060] [LOG]    Connecting socket for: MMM-DarkSkyForecast
              0|MagicMir | [2020-10-02 08:53:46.061] [LOG]    ====================== Starting node_helper for module [MMM-DarkSkyForecast]
              0|MagicMir | [2020-10-02 08:53:46.062] [LOG]    Sockets connected & modules started ...
              0|MagicMir | [2020-10-02 08:53:46.177] [LOG]    Launching application.
                sdetweil @swvalenti
                @swvalenti hm… connection timeout
                it should handle that for sure.
                I will look at the code in a while
                that url worked here just now
                • swvalentiS
                  Hmm weird, two other updates went fine and this one only has the error shown giving black screen. Ran script again too and didn’t do anything. Restarted pi and nothing still error and black screen.
                    sdetweil @swvalenti
                    @swvalenti that calendar problem is from Sept 29. so not relevant now
                    can u open the dev window, see the instructions a few messages back
                    • K
                      Klinge @sdetweil
                      @sdetweil you are right. After an npm install it works. But I don´t understand it. Because, I run an update script with git pull && npm install in the MagicMirror Folder.
                      Whtatever, after the npm install it works. Is it running now because the electron was rebuilt?
                      Thank you for your help.
                        sdetweil @Klinge
                        @Klinge said in Black screen after 2.13 update - tentatively resolved:
                        where did u run this npm install?
                        that command stinks,
                        if git pull returns non-0, then the npm install will not be executed
                        "&&" is used to chain commands together, such that the next command is run if and only if the preceding command exited without errors
                        use my script!..
                        • swvalentiS
                          This is what the dev console error is…
                          /home/pi/MagicMirror…rity-warnings.js:95 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure
                            protocols.This exposes users of this app to unnecessary security risks.
                            Consider loading the following resources over HTTPS or FTPS.
                           - http://0.0.0.0:8080/css/main.css
                          - http://0.0.0.0:8080/fonts/roboto.css
                          - http://0.0.0.0:8080/socket.io/socket.io.js
                          - http://0.0.0.0:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
                          - http://0.0.0.0:8080/js/defaults.js
                          - http://0.0.0.0:8080/config/config.js
                          - http://0.0.0.0:8080/vendor/vendor.js
                          - http://0.0.0.0:8080/modules/default/defaultmodules.js
                          - http://0.0.0.0:8080/js/logger.js
                          - http://0.0.0.0:8080/translations/translations.js
                          - http://0.0.0.0:8080/js/translator.js
                          - http://0.0.0.0:8080/js/class.js
                          - http://0.0.0.0:8080/js/module.js
                          - http://0.0.0.0:8080/js/loader.js
                          - http://0.0.0.0:8080/js/socketclient.js
                          - http://0.0.0.0:8080/js/main.js
                          - http://0.0.0.0:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
                          - http://0.0.0.0:8080/translations/en.json
                          - http://0.0.0.0:8080/modules/default/alert//alert.js
                          - http://0.0.0.0:8080/modules/default/alert/notificationFx.js
                          - http://0.0.0.0:8080/modules/default/alert/notificationFx.css
                          - http://0.0.0.0:8080/vendor/css/font-awesome.css
                          - http://0.0.0.0:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/all.min.css
                          - http://0.0.0.0:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/v4-shims.min.css
                          For more information and help, consult
                          https://electronjs.org/docs/tutorial/security.
                           This warning will not show up
                          once the app is packaged.
                          /home/pi/MagicMirror…ity-warnings.js:145 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
                              Policy set or a policy with "unsafe-eval" enabled. This exposes users of
                            sdetweil @swvalenti
                            @swvalenti said in Black screen after 2.13 update - tentatively resolved:
                            hm…
                            try this
                            edit ~/MagicMirror/index.html
                            < head>
                            	< title>MagicMirror²< /title>
                            	< meta name="google" content="notranslate" />
                            	< meta http-equiv="Content-type" content="text/html; charset=utf-8" />
                            	< meta name="apple-mobile-web-app-capable" content="yes">
                            	< meta name="apple-mobile-web-app-status-bar-style" content="black">
                            	< meta name="format-detection" content="telephone=no">
                            	< meta name="mobile-web-app-capable" content="yes">
                            	< meta http-equiv="Content-Security-Policy" content="script-src 'self';"> < ---- insert this line without the space after <
                            • swvalentiS
                              Sam, that worked thank you very much!
                                sdetweil @swvalenti
                                @swvalenti i wonder why YOU see it and no one else does…
                                • swvalentiS
                                  I have no clue on that as all my units run the same hardware and OS
                                    sdetweil @swvalenti
                                    @swvalenti I opened issue https://github.com/MichMich/MagicMirror/issues/2147 to track this
                                    • swvalentiS
                                      Same unit that give me earlier issue does not load darksky or pokemon…my kids monitor…lol…other mirrors run darksky with no problem.
                                      Scripts loaded for: MMM-EARTH
                                      loader.js:195 Load stylesheet: modules/MMM-EARTH/MMM-EARTH.css
                                      loader.js:155 Styles loaded for: MMM-EARTH
                                      loader.js:157 Translations loaded for: MMM-EARTH
                                      loader.js:176 Load script: modules/MMM-DarkSkyForecast//MMM-DarkSkyForecast.js
                                      module.js:505 Check MagicMirror version for module 'MMM-DarkSkyForecast' - Minimum version:  2.2.0 - Current version: undefined
                                      module.js:528 Uncaught TypeError: Cannot read property 'replace' of undefined
                                          at cmpVersions (module.js:528)
                                          at Function.Module.register (module.js:506)
                                          at MMM-DarkSkyForecast.js:41
                                      loader.js:176 Load script: modules/MMM-DailyPokemon//MMM-DailyPokemon.js
                                      module.js:505 Check MagicMirror version for module 'MMM-DailyPokemon' - Minimum version:  2.1.0 - Current version: undefined
                                          at MMM-DailyPokemon.js:10
                                      loader.js:176 Load script: modules/MMM-EventHorizon//MMM-EventHorizon.js
                                      module.js:513 Module registered: MMM-EventHorizon
                                      loader.js:148 Bootstrapping module: MMM-EventHorizon
                                      loader.js:153 Scripts loaded for: MMM-EventHorizon
                                      loader.js:195 Load stylesheet: modules/MMM-EventHorizon/MMM-EventHorizon.css
                                      loader.js:155 Styles loaded for: MMM-EventHorizon
                                        sdetweil @swvalenti
                                        @swvalenti weird. this is 2.13 now?
                                        grep version ~/MagicMirror/package.json
                                        can’t believe the version check would fail
                                        swvalentiS 1 Reply Last reply Reply Quote 0
                                        • swvalentiS
                                          swvalenti Project Sponsor @sdetweil
                                          @sdetweil Yes sir 2.13
                                          Last login: Fri Oct  2 17:10:33 2020
                                          pi@raspberrypi:~ $ grep version ~/MagicMirror/package.json
                                                  "version": "2.13.0",
                                          pi@raspberrypi:~ $
                                            sdetweil @swvalenti
                                            @swvalenti edit the modulename.js for each
                                            comment out (leading //)
                                            requiresVersion: “2.1.0”,
                                            • 2 / 3
