    Black screen after 2.13 update - tentatively resolved
    53 Posts 9 Posters 26.7k Views 9 Watching
      m0bed @m0bed
      @m0bed So, I changed my config found out that this modules dont work at the moment:
      MMM-Homematic-Heaters
      MMM-FRITZ-Box-Callmonitor
      On the callmonitor I tried this help topic, but not working.
      https://github.com/MichMich/MagicMirror/issues/2144
      After deleting this two moduls form the config, every thing works fine, but still getting the messages from npm install.
      Daniel
      S spitzlbergerjS 2 Replies Last reply
        retroflex Project Sponsor Module Developer
        Found one more in module MMM-Vasttrafik-PublicTransport. I have created an issue for that:
        https://github.com/bureus/MMM-Vasttrafik-PublicTransport/issues/14
        • K
          Klinge
          Found one more module too. In my case a black screen appears through the standard calendar module.
          my config is
                                  header: "Termine",
                                          timeFormat: 'absolute',
                                          maximumEntries: 10,
                                          dateFormat: 'ddd DD MMM HH:mm',
                                          fullDayEventDateFormat: 'ddd DD MMM',
                                          showEnd: false,
                                          urgency: 0,
                                          getRelative: 0,
                                                          symbol: "calendar-check",
                                                          url: "https://calendar.google.com/calendar/ical/XXXXXXXXXXXXX/basic.ics"
                                                          url: "https://calendar.google.com/calendar/ical/XXXXXXXXXXX/basic.ics"
          How can I create an issue for that?
          Or is there a problem in my config?
            sdetweil @Klinge
            @Klinge black screen
            look in two places,
            the window where you start mm,
            using npm start
            or
            pm2
            if pm2 use the command
            pm2 logs --lines=???
            ??? is a number, default is 15
            also look in the developers window
            ctrl-shift-i and select the console tab and scroll up to see any errors
              sdetweil @m0bed
              @m0bed did u run npm install in all the module folders which have a package.json file?
              next time, use my upgrade script
              see here
              • K
                Klinge
                @sdetweil said in Black screen after 2.13 update - tentatively resolved:
                When I run the pm2 logs, I got the following logs
                0|mm     | [2020-10-02 14:32:00.841] [LOG]    Module helper loaded: updatenotification
                0|mm     | [2020-10-02 14:32:00.843] [LOG]    No helper found for module: clock.
                0|mm     | [2020-10-02 14:32:01.602] [LOG]
                0|mm     | Initializing new module helper ...
                0|mm     | [2020-10-02 14:32:01.604] [LOG]    Module helper loaded: MMM-DarkSkyForecast
                0|mm     | [2020-10-02 14:32:01.620] [ERROR]
                0|mm     | WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node-ical'
                0|mm     | Require stack:
                0|mm     | - /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js
                0|mm     | - /home/pi/MagicMirror/modules/default/calendar/node_helper.js
                0|mm     | - /home/pi/MagicMirror/js/app.js
                0|mm     | - /home/pi/MagicMirror/js/electron.js
                0|mm     | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                0|mm     | -
                0|mm     | [2020-10-02 14:32:01.621] [LOG]    Loading module helpers ...
                0|mm     | [2020-10-02 14:32:01.623] [LOG]    No helper found for module: alert.
                0|mm     | [2020-10-02 14:32:01.627] [LOG]    Initializing new module helper ...
                0|mm     | [2020-10-02 14:32:01.629] [LOG]    Module helper loaded: updatenotification
                0|mm     | [2020-10-02 14:32:01.633] [LOG]    No helper found for module: clock.
                0|mm     | [2020-10-02 14:32:01.637] [LOG]    Initializing new module helper ...
                0|mm     | [2020-10-02 14:32:01.640] [LOG]    Module helper loaded: MMM-DarkSkyForecast
                0|mm     | [2020-10-02 14:32:01.649] [ERROR]
                0|mm     | App threw an error during load
                0|mm     | [2020-10-02 14:32:01.651] [ERROR]  Error: Cannot find module 'node-ical'
                0|mm     | -
                0|mm     |     at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                0|mm     |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                0|mm     |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                0|mm     |     at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                0|mm     |     at Module.require (internal/modules/cjs/loader.js:685:19)
                0|mm     |     at require (internal/modules/cjs/helpers.js:16:16)
                0|mm     |     at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:8:14)
                0|mm     |     at Module._compile (internal/modules/cjs/loader.js:786:30)
                0|mm     |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                0|mm     |     at Module.load (internal/modules/cjs/loader.js:645:32)
                0|mm     | [2020-10-02 14:32:01.654] [ERROR]  Whoops! There was an uncaught exception...
                0|mm     | [2020-10-02 14:32:01.655] [ERROR]
                0|mm     | Error: Cannot find module 'node-ical'
                0|mm     | -
                0|mm     |     at Module.load (internal/modules/cjs/loader.js:645:32) {
                0|mm     |   code: 'MODULE_NOT_FOUND',
                0|mm     |   requireStack: [
                0|mm     |     '/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js',
                0|mm     |     '/home/pi/MagicMirror/modules/default/calendar/node_helper.js',
                0|mm     |     '/home/pi/MagicMirror/js/app.js',
                0|mm     |     '/home/pi/MagicMirror/js/electron.js',
                0|mm     |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                0|mm     |     undefined
                0|mm     |   ]
                0|mm     | }
                0|mm     | [2020-10-02 14:32:01.682] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                0|mm     | [2020-10-02 14:32:01.683] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                0|mm     | [2020-10-02 14:32:01.845] [LOG]
                0|mm     | Launching application.
                  sdetweil @Klinge
                  @Klinge looks like u did not run
                  npm install
                  after the git pull
                  darksky looks like it will need one too
                  or use the upgrade script with force at the end, instead of apply
                  see here
                  K 1 Reply Last reply
                  • swvalentiS
                    swvalenti Project Sponsor
                    Sam,
                    Used your scrips on 3 updates with no issue except for one install. Getting black screen and ran the logs showing calendar error?
                    /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                    0|MagicMir |   syscall: 'read'
                    0|MagicMir | }
                    0|MagicMir | [2020-09-29 00:11:23.035] [ERROR]  Calendar Error. Could not fetch calendar:  http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics Error: connect ETIMEDOUT 69.16.220.190:80
                    0|MagicMir |     at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1054:14) {
                    0|MagicMir |   errno: 'ETIMEDOUT',
                    0|MagicMir |   code: 'ETIMEDOUT',
                    0|MagicMir |   syscall: 'connect',
                    0|MagicMir |   address: '69.16.220.190',
                    0|MagicMir |   port: 80
                    0|MagicMir | }
                    0|MagicMir | [25300:0930/035804.824753:FATAL:memory.cc(22)] Out of memory. size=262144
                    0|MagicMir | [12409:1001/033404.599579:FATAL:memory.cc(22)] Out of memory. size=262144
                    0|MagicMir | [14477:1001/034403.637658:FATAL:memory.cc(22)] Out of memory. size=262144
                    0|MagicMir | [14677:1001/034505.102662:FATAL:memory.cc(22)] Out of memory. size=262144
                    0|MagicMir | [1436:1002/084636.370183:FATAL:memory.cc(22)] Out of memory. size=262144
                    /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                    0|MagicMir | [2020-10-02 08:53:45.855] [LOG]    No helper found for module: MMM-EyeCandy.
                    0|MagicMir | [2020-10-02 08:53:45.856] [LOG]    No helper found for module: on-this-day.
                    0|MagicMir | [2020-10-02 08:53:45.856] [LOG]    All module helpers loaded.
                    0|MagicMir | [2020-10-02 08:53:46.035] [LOG]    Starting server on port 8080 ...
                    0|MagicMir | [2020-10-02 08:53:46.044] [INFO]   You're using a full whitelist configuration to allow for all IPs
                    0|MagicMir | [2020-10-02 08:53:46.053] [LOG]    Server started ...
                    0|MagicMir | [2020-10-02 08:53:46.054] [LOG]    Connecting socket for: updatenotification
                    0|MagicMir | [2020-10-02 08:53:46.056] [LOG]    Connecting socket for: calendar
                    0|MagicMir | [2020-10-02 08:53:46.057] [LOG]    Starting node helper for: calendar
                    0|MagicMir | [2020-10-02 08:53:46.058] [LOG]    Connecting socket for: MMM-EARTH
                    0|MagicMir | [2020-10-02 08:53:46.059] [LOG]    Starting module: MMM-EARTH
                    0|MagicMir | [2020-10-02 08:53:46.060] [LOG]    Connecting socket for: MMM-DarkSkyForecast
                    0|MagicMir | [2020-10-02 08:53:46.061] [LOG]    ====================== Starting node_helper for module [MMM-DarkSkyForecast]
                    0|MagicMir | [2020-10-02 08:53:46.062] [LOG]    Sockets connected & modules started ...
                    0|MagicMir | [2020-10-02 08:53:46.177] [LOG]    Launching application.
                      sdetweil @swvalenti
                      @swvalenti hm… connection timeout
                      it should handle that for sure.
                      I will look at the code in a while
                      that url worked here just now
                      • swvalentiS
                        Hmm weird, two other updates went fine and this one only has the error shown giving black screen. Ran script again too and didn’t do anything. Restarted pi and nothing still error and black screen.
                          sdetweil @swvalenti
                          @swvalenti that calendar problem is from Sept 29. so not relevant now
                          can u open the dev window, see the instructions a few messages back
                          • K
                            Klinge @sdetweil
                            @sdetweil you are right. After an npm install it works. But I don´t understand it. Because, I run an update script with git pull && npm install in the MagicMirror Folder.
                            Whtatever, after the npm install it works. Is it running now because the electron was rebuilt?
                            Thank you for your help.
                              sdetweil @Klinge
                              @Klinge said in Black screen after 2.13 update - tentatively resolved:
                              where did u run this npm install?
                              that command stinks,
                              if git pull returns non-0, then the npm install will not be executed
                              "&&" is used to chain commands together, such that the next command is run if and only if the preceding command exited without errors
                              use my script!..
                              • swvalentiS
                                This is what the dev console error is…
                                /home/pi/MagicMirror…rity-warnings.js:95 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure
                                  protocols.This exposes users of this app to unnecessary security risks.
                                  Consider loading the following resources over HTTPS or FTPS.
                                 - http://0.0.0.0:8080/css/main.css
                                - http://0.0.0.0:8080/fonts/roboto.css
                                - http://0.0.0.0:8080/socket.io/socket.io.js
                                - http://0.0.0.0:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
                                - http://0.0.0.0:8080/js/defaults.js
                                - http://0.0.0.0:8080/config/config.js
                                - http://0.0.0.0:8080/vendor/vendor.js
                                - http://0.0.0.0:8080/modules/default/defaultmodules.js
                                - http://0.0.0.0:8080/js/logger.js
                                - http://0.0.0.0:8080/translations/translations.js
                                - http://0.0.0.0:8080/js/translator.js
                                - http://0.0.0.0:8080/js/class.js
                                - http://0.0.0.0:8080/js/module.js
                                - http://0.0.0.0:8080/js/loader.js
                                - http://0.0.0.0:8080/js/socketclient.js
                                - http://0.0.0.0:8080/js/main.js
                                - http://0.0.0.0:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
                                - http://0.0.0.0:8080/translations/en.json
                                - http://0.0.0.0:8080/modules/default/alert//alert.js
                                - http://0.0.0.0:8080/modules/default/alert/notificationFx.js
                                - http://0.0.0.0:8080/modules/default/alert/notificationFx.css
                                - http://0.0.0.0:8080/vendor/css/font-awesome.css
                                - http://0.0.0.0:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/all.min.css
                                - http://0.0.0.0:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/v4-shims.min.css
                                For more information and help, consult
                                https://electronjs.org/docs/tutorial/security.
                                 This warning will not show up
                                once the app is packaged.
                                /home/pi/MagicMirror…ity-warnings.js:145 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
                                    Policy set or a policy with "unsafe-eval" enabled. This exposes users of
                                  sdetweil @swvalenti
                                  @swvalenti said in Black screen after 2.13 update - tentatively resolved:
                                  hm…
                                  try this
                                  edit ~/MagicMirror/index.html
                                  < head>
                                  	< title>MagicMirror²< /title>
                                  	< meta name="google" content="notranslate" />
                                  	< meta http-equiv="Content-type" content="text/html; charset=utf-8" />
                                  	< meta name="apple-mobile-web-app-capable" content="yes">
                                  	< meta name="apple-mobile-web-app-status-bar-style" content="black">
                                  	< meta name="format-detection" content="telephone=no">
                                  	< meta name="mobile-web-app-capable" content="yes">
                                  	< meta http-equiv="Content-Security-Policy" content="script-src 'self';"> < ---- insert this line without the space after <
                                  • swvalentiS
                                    Sam, that worked thank you very much!
                                      sdetweil @swvalenti
                                      @swvalenti i wonder why YOU see it and no one else does…
                                      • swvalentiS
                                        I have no clue on that as all my units run the same hardware and OS
                                          sdetweil @swvalenti
                                          @swvalenti I opened issue https://github.com/MichMich/MagicMirror/issues/2147 to track this
                                          • swvalentiS
                                            Same unit that give me earlier issue does not load darksky or pokemon…my kids monitor…lol…other mirrors run darksky with no problem.
                                            Scripts loaded for: MMM-EARTH
                                            loader.js:195 Load stylesheet: modules/MMM-EARTH/MMM-EARTH.css
                                            loader.js:155 Styles loaded for: MMM-EARTH
                                            loader.js:157 Translations loaded for: MMM-EARTH
                                            loader.js:176 Load script: modules/MMM-DarkSkyForecast//MMM-DarkSkyForecast.js
                                            module.js:505 Check MagicMirror version for module 'MMM-DarkSkyForecast' - Minimum version:  2.2.0 - Current version: undefined
                                            module.js:528 Uncaught TypeError: Cannot read property 'replace' of undefined
                                                at cmpVersions (module.js:528)
                                                at Function.Module.register (module.js:506)
                                                at MMM-DarkSkyForecast.js:41
                                            loader.js:176 Load script: modules/MMM-DailyPokemon//MMM-DailyPokemon.js
                                            module.js:505 Check MagicMirror version for module 'MMM-DailyPokemon' - Minimum version:  2.1.0 - Current version: undefined
                                                at MMM-DailyPokemon.js:10
                                            loader.js:176 Load script: modules/MMM-EventHorizon//MMM-EventHorizon.js
                                            module.js:513 Module registered: MMM-EventHorizon
                                            loader.js:148 Bootstrapping module: MMM-EventHorizon
                                            loader.js:153 Scripts loaded for: MMM-EventHorizon
                                            loader.js:195 Load stylesheet: modules/MMM-EventHorizon/MMM-EventHorizon.css
                                            loader.js:155 Styles loaded for: MMM-EventHorizon
                                            • 2 / 3
