    MMM-Weather-Now is borking my MagicMirror after v2.13.0 update
    8 Posts 2 Posters 907 Views 2 Watching
    • schrutesbeetsS Offline
      schrutesbeets Project Sponsor
      Context: I am a noob but seriously addicted to the Raspberry Pi platform. I am learning about Git, javascript, and CSS little by little and am by no means expert with any of those languages so apologies for any basic questions.
      Here are the steps I performed that created a blank (black) screen after MagicMirror v2.13.0 update.
      • I first backed up previous version of MagicMirror build
      • Tried to perform update via the MMM-Remote-Control module - update failed
      • Tried to perform update via RPi terminal command git pull - received the “Your local changes to the following files would be overwritten by merge” and didn’t know how to stash and pop so I didn’t know how to get past this error
      • Removed all 3rd party modules and tried git pull again - received the “Your local changes to the following files would be overwritten by merge” because I must have changed some details in the js of a few of the default modules, oops, I thought that is how to customize colors and padding when tinkering.
      • Deleted current build of MagicMirror (since I already had a backup) and started fresh by following the basic installation instructions and then added config file and all 3rd party modules form backup - resulted in blank (black) screen when I execute npm start
      • After fresh install of MagicMirror, I then tried adding back all of the 3rd party modules and executed npm install on each module to make sure they were updated - resulted in blank (black) screen when I execute npm start
      • I then removed all 3rd party modules (again) and added them back one-by-one figuring it would help identify the issue since I never received errors upon starting MagicMirror during any of these steps so my config file syntax must be fine. I found that the MMM-Weather-Now module is causing the blank (black) screen somehow, otherwise without that module the MagicMirror starts up fine.
      Any thoughts how I can troubleshoot the MMM-Weather-Now module to fix the issue?
      My config file for reference (private info obfuscated) sorry for the messy code:
       * By Michael Teeuw https://michaelteeuw.nl
       * MIT Licensed.
      var config = {
      	address: "0.0.0.0",
      		// Address to listen on, can be:
      	port: 8080,
      	basePath: "/",
      		// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
      	ipWhitelist: [],
      		// Set [] to allow all IP addresses
      		// ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.218"],
      	useHttps: false, 	// Support HTTPS or not, default "false" will use HTTP
      	language: "en",
      	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
      	timeFormat: 24,
      	units: "metric",	// serverOnly:  true/false/"local" ,
      			module: "MMM-MyCalendar",
      			position: "top_left",	// This can be any of the regions. Best results in left or right regions.
      				colored: false,
      				fade: true,
      				maximumEntries: 25,
      				fadePoint: 0.75,
      				useRelativeDates: false,
      				urgency: 30,
      				maxTitleLength: 50,
      				url: 'obfuscated-info',
      			symbol: 'calendar',
      				auth: {
      			    		user: 'obfuscated-info',
      			    		pass: 'obfuscated-info',
      			    		method: 'basic'
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_right"
      	    		module:     'MMM-3Day-Forecast',
      			header: "3-day Forecast",
      	    		position:   'top_right',
      				api_key:    'obfuscated-info',
      				lat:        obfuscated-info,
      				lon:        obfuscated-info,
      				units:      'I',
      				lang:       'en',
      				horizontalView: true,
      				interval:   900000
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
      			module: "MMM-MyStandings",
      			header: "Standings",
      				updateInterval: 60 * 60 * 1000, // every 60 minutes
      				rotateInterval: .5 * 60 * 1000, // every 30 sec
      				sports: [
      					{ league: "NBA", groups: ["Atlantic"] },
      					{ league: "MLB", groups: ["American League East"] },
      					{ league: "NFL", groups: ["AFC East"] },
      					{ league: "NHL", groups: ["Atlantic Division"] },
      					{ league: "MLS", groups: ["Eastern Conference"] },
      				nameStyle: "short",
      				showLogos: true,
      				useLocalLogos: true,
      				showByDivision: true,
      				fadeSpeed: 1000,
      		    module: 'MMM-Remote-Control',
      		    	// position: "bottom_left",
      			customCommand: {},  // Optional, See "Using Custom Commands" below
      			customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
      			showModuleApiMenu: true, // Optional, Enable the Module Controls menu
      			apiKey: "",         // Optional, See API/README.md for details
      			module: 'MMM-PIR-Sensor',
      			position: "top_center", // Remove this line to avoid having an visible indicator
      				sensorPin: 22,
      				powerSavingDelay: 60, // Turn HDMI OFF after 60 seconds of no motion, until motion is detected again
      				preventHDMITimeout: 10, // Turn HDMI ON and OFF again every 10 minutes when power saving, to avoid LCD/TV timeout
      				supportCEC: true,
      				presenceIndicator: "fa-eye", // Customizing the indicator
      				presenceOffIndicator: "fa-eye", // Customizing the indicator
      				presenceIndicatorColor: "#2AE9F9", // Customizing the indicator
      				presenceOffIndicatorColor: "#2b271c" // Customizing the indicator
        sdetweil @schrutesbeets
        @schrutesbeets show the messages from the place where u start MM
        npm start
        or
        pm2
        if pm2, then pm2 logs --lines=???
        where ??? is a number, default is 15
        also, open the developers window, ctrl-shift-i on the mm keyboard, select the tab labeled ‘console’ and scroll up to see that errors
          @schrutesbeets
          looks like its the translation file
          translations/da.json
          which has a comment in it… not allowed in json
              /* NOW key can be translated to "Lige nu", please provide footage or description of where and how it's used */
              "NOW":          "Nu",
              "FEELS_LIKE":   "Føles som"
          remove that line.
          I opened issue https://github.com/nigel-daniels/MMM-Weather-Now/issues/6
          but its been 2 years since update, so unlikely
          schrutesbeetsS 2 Replies Last reply Reply Quote 0
            schrutesbeets Project Sponsor @sdetweil
            @sdetweil thanks for looking into this for me… I owe you a coffee or beer.
            This is the log from npm start
            [2020-10-04 10:44:51.126] [LOG]    Starting MagicMirror: v2.13.0
            [2020-10-04 10:44:51.133] [LOG]    Loading config ...
            [2020-10-04 10:44:51.138] [LOG]    Loading module helpers ...
            [2020-10-04 10:44:51.506] [LOG]    Initializing new module helper ...
            [2020-10-04 10:44:51.506] [LOG]    Module helper loaded: MMM-MyCalendar
            [2020-10-04 10:44:51.508] [LOG]    No helper found for module: alert.
            [2020-10-04 10:44:51.544] [LOG]    Initializing new module helper ...
            [2020-10-04 10:44:51.544] [LOG]    Module helper loaded: updatenotification
            [2020-10-04 10:44:51.545] [LOG]    No helper found for module: clock.
            [2020-10-04 10:44:51.849] [LOG]    Initializing new module helper ...
            [2020-10-04 10:44:51.850] [LOG]    Module helper loaded: MMM-Weather-Now
            [2020-10-04 10:44:51.852] [LOG]    Initializing new module helper ...
            [2020-10-04 10:44:51.852] [LOG]    Module helper loaded: MMM-3Day-Forecast
            [2020-10-04 10:44:51.874] [LOG]    Initializing new module helper ...
            [2020-10-04 10:44:51.874] [LOG]    Module helper loaded: newsfeed
            [2020-10-04 10:44:51.876] [LOG]    Initializing new module helper ...
            [2020-10-04 10:44:51.877] [LOG]    Module helper loaded: MMM-MyStandings
            [2020-10-04 10:44:51.994] [LOG]    Initializing new module helper ...
            [2020-10-04 10:44:51.994] [LOG]    Module helper loaded: MMM-Remote-Control
            [2020-10-04 10:44:52.024] [LOG]    Initializing new module helper ...
            [2020-10-04 10:44:52.024] [LOG]    Module helper loaded: MMM-PIR-Sensor
            [2020-10-04 10:44:52.025] [LOG]    All module helpers loaded.
            [2020-10-04 10:44:52.149] [LOG]    Starting server on port 8080 ...
            [2020-10-04 10:44:52.154] [INFO]   You're using a full whitelist configuration to allow for all IPs
            [2020-10-04 10:44:52.159] [LOG]    Server started ...
            [2020-10-04 10:44:52.160] [LOG]    Connecting socket for: MMM-MyCalendar
            [2020-10-04 10:44:52.161] [LOG]    Starting node helper for: MMM-MyCalendar
            [2020-10-04 10:44:52.162] [LOG]    Connecting socket for: updatenotification
            [2020-10-04 10:44:52.163] [LOG]    Connecting socket for: MMM-Weather-Now
            [2020-10-04 10:44:52.164] [LOG]    MMM-Weather-Now helper, started...
            [2020-10-04 10:44:52.165] [LOG]    Connecting socket for: MMM-3Day-Forecast
            [2020-10-04 10:44:52.166] [LOG]    MMM-3Day-Forecast helper, started...
            [2020-10-04 10:44:52.167] [LOG]    Connecting socket for: newsfeed
            [2020-10-04 10:44:52.168] [LOG]    Starting node helper for: newsfeed
            [2020-10-04 10:44:52.169] [LOG]    Connecting socket for: MMM-MyStandings
            [2020-10-04 10:44:52.169] [LOG]    MMM-MyStandings helper started ...
            [2020-10-04 10:44:52.170] [LOG]    Connecting socket for: MMM-Remote-Control
            [2020-10-04 10:44:52.171] [LOG]    Starting node helper for: MMM-Remote-Control
            [2020-10-04 10:44:52.179] [LOG]    Connecting socket for: MMM-PIR-Sensor
            [2020-10-04 10:44:52.180] [LOG]    Sockets connected & modules started ...
            [2020-10-04 10:44:52.298] [LOG]    Launching application.
            [2020-10-04 10:45:01.780] [LOG]    Shutting down server...
            [2020-10-04 10:45:01.781] [LOG]    Stopping module helper: MMM-MyCalendar
            [2020-10-04 10:45:01.782] [LOG]    Stopping module helper: updatenotification
            [2020-10-04 10:45:01.782] [LOG]    Stopping module helper: MMM-Weather-Now
            [2020-10-04 10:45:01.782] [LOG]    Stopping module helper: MMM-3Day-Forecast
            [2020-10-04 10:45:01.783] [LOG]    Stopping module helper: newsfeed
            [2020-10-04 10:45:01.783] [LOG]    Stopping module helper: MMM-MyStandings
            [2020-10-04 10:45:01.784] [LOG]    Stopping module helper: MMM-PIR-Sensor
            This is the log from npm start dev
            loader.js:195 Load stylesheet: vendor/css/font-awesome.css
            loader.js:155 Styles loaded for: MMM-MyCalendar
            loader.js:157 Translations loaded for: MMM-MyCalendar
            loader.js:176 Load script: modules/default/alert//alert.js
            module.js:513 Module registered: alert
            loader.js:148 Bootstrapping module: alert
            loader.js:176 Load script: modules/default/alert/notificationFx.js
            loader.js:153 Scripts loaded for: alert
            loader.js:195 Load stylesheet: modules/default/alert/notificationFx.css
            loader.js:236 File already loaded: font-awesome.css
            loader.js:155 Styles loaded for: alert
            translator.js:102 alert - Load translation fallback: translations/en.json
            /home/pi/Desktop/MM …rity-warnings.js:95 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure
              protocols.This exposes users of this app to unnecessary security risks.
              Consider loading the following resources over HTTPS or FTPS.
             - http://0.0.0.0:8080/css/main.css
            - http://0.0.0.0:8080/fonts/roboto.css
            - http://0.0.0.0:8080/socket.io/socket.io.js
            - http://0.0.0.0:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
            - http://0.0.0.0:8080/js/defaults.js
            - http://0.0.0.0:8080/config/config.js
            - http://0.0.0.0:8080/vendor/vendor.js
            - http://0.0.0.0:8080/modules/default/defaultmodules.js
            - http://0.0.0.0:8080/js/logger.js
            - http://0.0.0.0:8080/translations/translations.js
            - http://0.0.0.0:8080/js/translator.js
            - http://0.0.0.0:8080/js/class.js
            - http://0.0.0.0:8080/js/module.js
            - http://0.0.0.0:8080/js/loader.js
            - http://0.0.0.0:8080/js/socketclient.js
            - http://0.0.0.0:8080/js/main.js
            - http://0.0.0.0:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
            - http://0.0.0.0:8080/translations/en.json
            - http://0.0.0.0:8080/modules/MMM-MyCalendar//MMM-MyCalendar.js
            - http://0.0.0.0:8080/vendor/node_modules/moment/min/moment-with-locales.js
            - http://0.0.0.0:8080/modules/MMM-MyCalendar/MMM-MyCalendar.css
            - http://0.0.0.0:8080/vendor/css/font-awesome.css
            - http://0.0.0.0:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/all.min.css
            - http://0.0.0.0:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/v4-shims.min.css
            - http://0.0.0.0:8080/modules/default/alert//alert.js
            - http://0.0.0.0:8080/modules/default/alert/notificationFx.js
            - http://0.0.0.0:8080/modules/default/alert/notificationFx.css
            For more information and help, consult
            https://electronjs.org/docs/tutorial/security.
             This warning will not show up
            once the app is packaged.
            /home/pi/Desktop/MM …ity-warnings.js:145 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
                Policy set or a policy with "unsafe-eval" enabled. This exposes users of
            loader.js:157 Translations loaded for: alert
            loader.js:176 Load script: modules/default/updatenotification//updatenotification.js
            module.js:513 Module registered: updatenotification
            loader.js:148 Bootstrapping module: updatenotification
            loader.js:153 Scripts loaded for: updatenotification
            loader.js:155 Styles loaded for: updatenotification
            loader.js:157 Translations loaded for: updatenotification
            loader.js:176 Load script: modules/default/clock//clock.js
            module.js:513 Module registered: clock
            loader.js:148 Bootstrapping module: clock
            loader.js:236 File already loaded: moment.js
            loader.js:176 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
            loader.js:176 Load script: vendor/node_modules/suncalc/suncalc.js
            loader.js:153 Scripts loaded for: clock
            loader.js:195 Load stylesheet: modules/default/clock/clock_styles.css
            loader.js:155 Styles loaded for: clock
            loader.js:157 Translations loaded for: clock
            loader.js:176 Load script: modules/MMM-Weather-Now//MMM-Weather-Now.js
            module.js:513 Module registered: MMM-Weather-Now
            loader.js:148 Bootstrapping module: MMM-Weather-Now
            loader.js:153 Scripts loaded for: MMM-Weather-Now
            loader.js:195 Load stylesheet: modules/MMM-Weather-Now/weather-now.css
            loader.js:155 Styles loaded for: MMM-Weather-Now
            translator.js:100 MMM-Weather-Now - Load translation: translations/en.json
            translator.js:102 MMM-Weather-Now - Load translation fallback: translations/da.json
            VM143:2 Uncaught SyntaxError: Unexpected token / in JSON at position 6
                at JSON.parse (<anonymous>)
                at XMLHttpRequest.xhr.onreadystatechange (translator.js:22)
              @sdetweil that worked… I removed the comment line in the da.json file and it runs like normal now. Much appreciated.
                @schrutesbeets glad it worked… don’t see the change that caused that yet…
                it would always fail with that comment, so it wasn’t parsed for some reason, and now is…
                  see the sticky topic at the top of the troubleshooting section
                  https://forum.magicmirror.builders/topic/13774/2-13-back-screen
                  schrutesbeetsS 1 Reply Last reply Reply Quote 0
                    @sdetweil nice thanks
