    MMM-Weather-Now is borking my MagicMirror after v2.13.0 update
    8 Posts 2 Posters 893 Views 2 Watching
    • schrutesbeetsS Offline
      schrutesbeets Project Sponsor @sdetweil
      @sdetweil thanks for looking into this for me… I owe you a coffee or beer.
      This is the log from npm start
      [2020-10-04 10:44:51.126] [LOG]    Starting MagicMirror: v2.13.0
      [2020-10-04 10:44:51.133] [LOG]    Loading config ...
      [2020-10-04 10:44:51.138] [LOG]    Loading module helpers ...
      [2020-10-04 10:44:51.506] [LOG]    Initializing new module helper ...
      [2020-10-04 10:44:51.506] [LOG]    Module helper loaded: MMM-MyCalendar
      [2020-10-04 10:44:51.508] [LOG]    No helper found for module: alert.
      [2020-10-04 10:44:51.544] [LOG]    Initializing new module helper ...
      [2020-10-04 10:44:51.544] [LOG]    Module helper loaded: updatenotification
      [2020-10-04 10:44:51.545] [LOG]    No helper found for module: clock.
      [2020-10-04 10:44:51.849] [LOG]    Initializing new module helper ...
      [2020-10-04 10:44:51.850] [LOG]    Module helper loaded: MMM-Weather-Now
      [2020-10-04 10:44:51.852] [LOG]    Initializing new module helper ...
      [2020-10-04 10:44:51.852] [LOG]    Module helper loaded: MMM-3Day-Forecast
      [2020-10-04 10:44:51.874] [LOG]    Initializing new module helper ...
      [2020-10-04 10:44:51.874] [LOG]    Module helper loaded: newsfeed
      [2020-10-04 10:44:51.876] [LOG]    Initializing new module helper ...
      [2020-10-04 10:44:51.877] [LOG]    Module helper loaded: MMM-MyStandings
      [2020-10-04 10:44:51.994] [LOG]    Initializing new module helper ...
      [2020-10-04 10:44:51.994] [LOG]    Module helper loaded: MMM-Remote-Control
      [2020-10-04 10:44:52.024] [LOG]    Initializing new module helper ...
      [2020-10-04 10:44:52.024] [LOG]    Module helper loaded: MMM-PIR-Sensor
      [2020-10-04 10:44:52.025] [LOG]    All module helpers loaded.
      [2020-10-04 10:44:52.149] [LOG]    Starting server on port 8080 ...
      [2020-10-04 10:44:52.154] [INFO]   You're using a full whitelist configuration to allow for all IPs
      [2020-10-04 10:44:52.159] [LOG]    Server started ...
      [2020-10-04 10:44:52.160] [LOG]    Connecting socket for: MMM-MyCalendar
      [2020-10-04 10:44:52.161] [LOG]    Starting node helper for: MMM-MyCalendar
      [2020-10-04 10:44:52.162] [LOG]    Connecting socket for: updatenotification
      [2020-10-04 10:44:52.163] [LOG]    Connecting socket for: MMM-Weather-Now
      [2020-10-04 10:44:52.164] [LOG]    MMM-Weather-Now helper, started...
      [2020-10-04 10:44:52.165] [LOG]    Connecting socket for: MMM-3Day-Forecast
      [2020-10-04 10:44:52.166] [LOG]    MMM-3Day-Forecast helper, started...
      [2020-10-04 10:44:52.167] [LOG]    Connecting socket for: newsfeed
      [2020-10-04 10:44:52.168] [LOG]    Starting node helper for: newsfeed
      [2020-10-04 10:44:52.169] [LOG]    Connecting socket for: MMM-MyStandings
      [2020-10-04 10:44:52.169] [LOG]    MMM-MyStandings helper started ...
      [2020-10-04 10:44:52.170] [LOG]    Connecting socket for: MMM-Remote-Control
      [2020-10-04 10:44:52.171] [LOG]    Starting node helper for: MMM-Remote-Control
      [2020-10-04 10:44:52.179] [LOG]    Connecting socket for: MMM-PIR-Sensor
      [2020-10-04 10:44:52.180] [LOG]    Sockets connected & modules started ...
      [2020-10-04 10:44:52.298] [LOG]    Launching application.
      [2020-10-04 10:45:01.780] [LOG]    Shutting down server...
      [2020-10-04 10:45:01.781] [LOG]    Stopping module helper: MMM-MyCalendar
      [2020-10-04 10:45:01.782] [LOG]    Stopping module helper: updatenotification
      [2020-10-04 10:45:01.782] [LOG]    Stopping module helper: MMM-Weather-Now
      [2020-10-04 10:45:01.782] [LOG]    Stopping module helper: MMM-3Day-Forecast
      [2020-10-04 10:45:01.783] [LOG]    Stopping module helper: newsfeed
      [2020-10-04 10:45:01.783] [LOG]    Stopping module helper: MMM-MyStandings
      [2020-10-04 10:45:01.784] [LOG]    Stopping module helper: MMM-PIR-Sensor
      This is the log from npm start dev
      loader.js:195 Load stylesheet: vendor/css/font-awesome.css
      loader.js:155 Styles loaded for: MMM-MyCalendar
      loader.js:157 Translations loaded for: MMM-MyCalendar
      loader.js:176 Load script: modules/default/alert//alert.js
      module.js:513 Module registered: alert
      loader.js:148 Bootstrapping module: alert
      loader.js:176 Load script: modules/default/alert/notificationFx.js
      loader.js:153 Scripts loaded for: alert
      loader.js:195 Load stylesheet: modules/default/alert/notificationFx.css
      loader.js:236 File already loaded: font-awesome.css
      loader.js:155 Styles loaded for: alert
      translator.js:102 alert - Load translation fallback: translations/en.json
      /home/pi/Desktop/MM …rity-warnings.js:95 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure
        protocols.This exposes users of this app to unnecessary security risks.
        Consider loading the following resources over HTTPS or FTPS.
       - http://0.0.0.0:8080/css/main.css
      - http://0.0.0.0:8080/fonts/roboto.css
      - http://0.0.0.0:8080/socket.io/socket.io.js
      - http://0.0.0.0:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
      - http://0.0.0.0:8080/js/defaults.js
      - http://0.0.0.0:8080/config/config.js
      - http://0.0.0.0:8080/vendor/vendor.js
      - http://0.0.0.0:8080/modules/default/defaultmodules.js
      - http://0.0.0.0:8080/js/logger.js
      - http://0.0.0.0:8080/translations/translations.js
      - http://0.0.0.0:8080/js/translator.js
      - http://0.0.0.0:8080/js/class.js
      - http://0.0.0.0:8080/js/module.js
      - http://0.0.0.0:8080/js/loader.js
      - http://0.0.0.0:8080/js/socketclient.js
      - http://0.0.0.0:8080/js/main.js
      - http://0.0.0.0:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
      - http://0.0.0.0:8080/translations/en.json
      - http://0.0.0.0:8080/modules/MMM-MyCalendar//MMM-MyCalendar.js
      - http://0.0.0.0:8080/vendor/node_modules/moment/min/moment-with-locales.js
      - http://0.0.0.0:8080/modules/MMM-MyCalendar/MMM-MyCalendar.css
      - http://0.0.0.0:8080/vendor/css/font-awesome.css
      - http://0.0.0.0:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/all.min.css
      - http://0.0.0.0:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/v4-shims.min.css
      - http://0.0.0.0:8080/modules/default/alert//alert.js
      - http://0.0.0.0:8080/modules/default/alert/notificationFx.js
      - http://0.0.0.0:8080/modules/default/alert/notificationFx.css
      For more information and help, consult
      https://electronjs.org/docs/tutorial/security.
       This warning will not show up
      once the app is packaged.
      /home/pi/Desktop/MM …ity-warnings.js:145 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
          Policy set or a policy with "unsafe-eval" enabled. This exposes users of
      loader.js:157 Translations loaded for: alert
      loader.js:176 Load script: modules/default/updatenotification//updatenotification.js
      module.js:513 Module registered: updatenotification
      loader.js:148 Bootstrapping module: updatenotification
      loader.js:153 Scripts loaded for: updatenotification
      loader.js:155 Styles loaded for: updatenotification
      loader.js:157 Translations loaded for: updatenotification
      loader.js:176 Load script: modules/default/clock//clock.js
      module.js:513 Module registered: clock
      loader.js:148 Bootstrapping module: clock
      loader.js:236 File already loaded: moment.js
      loader.js:176 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
      loader.js:176 Load script: vendor/node_modules/suncalc/suncalc.js
      loader.js:153 Scripts loaded for: clock
      loader.js:195 Load stylesheet: modules/default/clock/clock_styles.css
      loader.js:155 Styles loaded for: clock
      loader.js:157 Translations loaded for: clock
      loader.js:176 Load script: modules/MMM-Weather-Now//MMM-Weather-Now.js
      module.js:513 Module registered: MMM-Weather-Now
      loader.js:148 Bootstrapping module: MMM-Weather-Now
      loader.js:153 Scripts loaded for: MMM-Weather-Now
      loader.js:195 Load stylesheet: modules/MMM-Weather-Now/weather-now.css
      loader.js:155 Styles loaded for: MMM-Weather-Now
      translator.js:100 MMM-Weather-Now - Load translation: translations/en.json
      translator.js:102 MMM-Weather-Now - Load translation fallback: translations/da.json
      VM143:2 Uncaught SyntaxError: Unexpected token / in JSON at position 6
          at JSON.parse (<anonymous>)
          at XMLHttpRequest.xhr.onreadystatechange (translator.js:22)
        @sdetweil that worked… I removed the comment line in the da.json file and it runs like normal now. Much appreciated.
          sdetweil @schrutesbeets
          @schrutesbeets glad it worked… don’t see the change that caused that yet…
          it would always fail with that comment, so it wasn’t parsed for some reason, and now is…
            see the sticky topic at the top of the troubleshooting section
            https://forum.magicmirror.builders/topic/13774/2-13-back-screen
            schrutesbeetsS 1 Reply Last reply Reply Quote 0
              @sdetweil nice thanks
