    Installing on a Pi Zero
    175 Posts 33 Posters 294.0k Views 33 Watching
      sdetweil @RushHour99
      @RushHour99 its NOT the same, there is an extra parameter at the end… apply
        RushHour99 @sdetweil
        @sdetweil Thanks! It is much more clear now. My screen size truncated the “apply” parameter at the end of the line. Now that I scroll horizontally I see the “apply”. Thanks again for the feedback.
          @RushHour99 as folks have invested a lot of time in setting up their systems, only to have an update crash everything,
          I wanted to provide a ‘test’ 1st, so people might be more comfortable with what might be impacted…
          and NOT make changes if they don’t want to continue…
          all my work suffers from problems in the base that is being applied, like some new translation file comments for years old modules this time…
            akz_g @sdetweil
            @sdetweil said in Installing on a Pi Zero:
            @akz_g use my script. the old instructions don’t work anymore
            see here
            Thanks for this @sdetweil I will try with a fresh image. Do I just run master/raspberry.sh… ?
            Going to try it tonight! many thanks
              sdetweil @akz_g
              @akz_g no… the script is not in the base anymore … run it directly from here
              it does everything, prep the system, download the code, install the dependencies, add support for pi 0,
              add support for starting at boot, turn off screen saver
                akz_g @sdetweil
                @sdetweil Thanks again! will let you know how I get on :)
                  akz_g @akz_g
                  @akz_g first message I got was
                  this appears not to be a Raspberry Pi 2, 3 or 4, do you want to continue installation (y/N)?
                  should I continue? don’t want to waste another hour if i’m doing it wrong.
                    sdetweil @akz_g
                    @akz_g no, keep going
                      akz_g @sdetweil
                      @sdetweil Thanks so much! got it working and it was a very easy install in the end. My next step is to have a look at the config.js file and tailor it to UK etc… I guess this is the place I can add new modules also?
                        sdetweil @akz_g
                        @akz_g yes, see the links in my signature for learning
                        • E Offline
                          eracerhead @andyc7687
                          @andyc7687 I know this is almost 2 years later, but this did not work on the pi zero w. I got to the point of on page 18 where it was supposed to say MagicMirror running. But it never did. It did say it was installed correctly, and to reboot, which I did, but it isn’t working.
                          $ pm2 show MagicMirror
                          [PM2][WARN] MagicMirror doesn’t exist
                          I don’t even know how to begin to troubleshoot this. (This was my second attempt at trying to install magic mirror.)
                            sdetweil @eracerhead
                            @eracerhead use my script
                            see here for instructions
                            remove the MagicMirror folder
                              camcooper151515
                              I can say as of November 6 2020 the script works for installing the MagicMirror and auto starts on raspberry pi 0w. But… I do have some questions. How do I go about stopping the mirror so I can install modules? I’m a complete newb at this
                                camcooper151515 @sdetweil
                                  sdetweil @camcooper151515
                                  @camcooper151515 minimize
                                  alt-spacebar, n
                                  then alt-ctrl-t to open a terminal window, them the pm2 command
                                  pm2 stop 0, or MagicMirror
                                    @sdetweil thanks I’ll try when I get home in the morning. Thanks so much for a working install I was at my wits end trying to get this to work until I found this thread. May I ask one more thing of you? Is there a command sequence I follow to stop the blanking of the screen after a few minutes for you install?
                                      @camcooper151515 it should have asked if you wanted to disable screensaver.
                                      anyhow, on the same site as the install script there is a command to turn it off now, down near the bottom of the page
                                        @sdetweil thanks that worked again. Is there a reason that my weather is not showing by default? Does it have to be setup first before it shows?
                                          @camcooper151515 yes, some setup. needs to.know where u are for sure. some providers need u to register to request data
                                            @sdetweil this thing is working great man I’ve been tinkering around with it over the weekend. Thanks so much again for the install but another question I know I know I apologize but your like king right now. How can I access the custom.css file?
                                            • 7 / 9
