    Has anyone got MMM-Remote-Control working on MM 2.11 ?
    31 Posts 8 Posters 18.9k Views 9 Watching
      snikolaidis @karsten13
      @karsten13 said in Has anyone got MMM-Remote-Control working on MM 2.11 ?:
      ~/magicmirror/ru
      THANK YOU!!!
      • karsten13K Online
        karsten13
        what I told you in my last reply was the solution to use the develop image.
        Now I tried to write down the other solution (how to patch a mm-file in a docker setup) here.
        • Z Offline
          zeeboguy
          @RoadRunnr1469
          This fixed the issue I was having with Remote Control
          issue I was having was when logging into remote control, it would display all modules as ‘unavailable’ and would be in a constant loading… loop when trying to turn on/off modules.
          Now its running as expected.
          Thank you!
          • Q Offline
            qqqqqqqq
            I did the fix in the socketclient.js file. but here are two issues that i am still facing. Anyone knows, how to fix them?
            1. The icons aren’t still visible, like it was in earlier versions.
            2. The top buttons just showing “All” and not “Show all” or “Hide All”.
            • karsten13K Online
              karsten13
              There is a fix for this provided as PR here but still not merged. But you can apply the fix yourself.
              • MrCoffeeM Offline
                MrCoffee @karsten13
                @karsten13
                Sorry for asking, but I am pretty new to docker.
                I installed my MagicMirror using docker-MagicMirror.
                There I don´t have the ~/magicmirror/run folder.
                Could you please help me out, where I have to look?
                Thanks.
                Mr.Coffee
                • karsten13K Online
                  karsten13 @MrCoffee
                  @MrCoffee
                  sorry, don’t understand your question.
                  This thread is about a problem with MMM-RemoteControl with MM v2.11.
                  If you use the mentioned docker setup this should have MM v2.13 where the problem is solved.
                  MrCoffeeM 1 Reply Last reply Reply Quote 0
                  • MrCoffeeM Offline
                    MrCoffee @karsten13
                    @karsten13
                    Oh. Sorry for that.
                    But thank you for your answer.
                    However I thougt I had the same issues.
                    Ok. I will give it another try and in case I can’t fix it, i will open a new thread.
                    Thank you.
                    • karsten13K Online
                      karsten13
                      may your image is to old. You can execute docker images and see how old your images are. You can get a new version with docker pull xy (replace xy with the image name).
                      MrCoffeeM 2 Replies Last reply Reply Quote 0
                      • MrCoffeeM Offline
                        MrCoffee @karsten13
                        @karsten13
                        Thank you. I did not know these commands.
                        But unfortunately I have got the latest MM-Release.
                        So I farther have to search for the error.
                        • MrCoffeeM Offline
                          MrCoffee @karsten13
                          @karsten13
                          Looks like I have got it.
                          I just had to remove the 8080 out of http://192.168.xxx.xxx:8080/remote.html
                          Sorry for that.
                          Thanks for helping me.
