    Has anyone got MMM-Remote-Control working on MM 2.11 ?
    31 Posts 8 Posters 19.2k Views 9 Watching
      RoadRunnr1469 @karsten13
      @karsten13 actually no I didn’t. I had backed up my entire MagicMirror folder and all sub folders before upgrading. I saw another post where they said they changed the socketclient back to before upgrade. so I did the same thing. after making a backup of the new socketclient.js file.
      StoffbeuteluweS 1 Reply Last reply
      • StoffbeuteluweS
        Stoffbeuteluwe Project Sponsor @RoadRunnr1469
        @RoadRunnr1469 so…After restart MM …Remote Control is not working anymore :worried_face:
          sdetweil @Stoffbeuteluwe
          @Stoffbeuteluwe put his fix on the js/socketclient.js
            snikolaidis
            what if cat ./js/socketclient.js says the file doesn’t exist? Would it be located somewhere else for the MagicMirrorOS?
            • karsten13K
              karsten13
              you are using this setup?
                snikolaidis @karsten13
                @karsten13 yes I am
                • karsten13K
                  karsten13
                  then you will not find the socketclient.js on your pi because this file is in the used docker image.
                  2 possibilities:
                  • you have to mount a fixed version of this file into the running container with a volume mount
                  • you can use the develop version of the docker image which contains the current develop branch of mm where this is already fixed (this is the current base of the upcoming MM v2.12)
                  Don’t know how experienced you are in docker, 2. option is easier to explain.
                    @karsten13 I am a complete novice to it, but I will figure out a way, thank you so much for pointing me in the correct path!
                    • karsten13K
                      karsten13
                      then goto ~/magicmirror/run and edit the docker-compose.yml with an editor (e.g. nano or vi).
                      In this file replace karsten13/magicmirror:latest with karsten13/magicmirror:develop, save the file.
                      You are still in ~/magicmirror/run, then run docker-compose up -d.
                      It will take a while because this will pull a new docker image.
                      After the app is up again, the problem should be fixed.
                      S MrCoffeeM 2 Replies Last reply
                        @karsten13 said in Has anyone got MMM-Remote-Control working on MM 2.11 ?:
                        ~/magicmirror/ru
                        THANK YOU!!!
                        • karsten13K
                          karsten13
                          what I told you in my last reply was the solution to use the develop image.
                          Now I tried to write down the other solution (how to patch a mm-file in a docker setup) here.
                          • Z
                            zeeboguy
                            @RoadRunnr1469
                            This fixed the issue I was having with Remote Control
                            issue I was having was when logging into remote control, it would display all modules as ‘unavailable’ and would be in a constant loading… loop when trying to turn on/off modules.
                            Now its running as expected.
                            Thank you!
                            • Q
                              qqqqqqqq
                              I did the fix in the socketclient.js file. but here are two issues that i am still facing. Anyone knows, how to fix them?
                              1. The icons aren’t still visible, like it was in earlier versions.
                              2. The top buttons just showing “All” and not “Show all” or “Hide All”.
                              • karsten13K
                                karsten13
                                There is a fix for this provided as PR here but still not merged. But you can apply the fix yourself.
                                • MrCoffeeM
                                  MrCoffee @karsten13
                                  @karsten13
                                  Sorry for asking, but I am pretty new to docker.
                                  I installed my MagicMirror using docker-MagicMirror.
                                  There I don´t have the ~/magicmirror/run folder.
                                  Could you please help me out, where I have to look?
                                  Thanks.
                                  Mr.Coffee
                                  karsten13K 1 Reply Last reply
                                  • karsten13K
                                    karsten13 @MrCoffee
                                    @MrCoffee
                                    sorry, don’t understand your question.
                                    This thread is about a problem with MMM-RemoteControl with MM v2.11.
                                    If you use the mentioned docker setup this should have MM v2.13 where the problem is solved.
                                    MrCoffeeM 1 Reply Last reply
                                    • MrCoffeeM
                                      MrCoffee @karsten13
                                      @karsten13
                                      Oh. Sorry for that.
                                      But thank you for your answer.
                                      However I thougt I had the same issues.
                                      Ok. I will give it another try and in case I can’t fix it, i will open a new thread.
                                      Thank you.
                                      • karsten13K
                                        karsten13
                                        may your image is to old. You can execute docker images and see how old your images are. You can get a new version with docker pull xy (replace xy with the image name).
                                        • MrCoffeeM
                                          MrCoffee @karsten13
                                          @karsten13
                                          Thank you. I did not know these commands.
                                          But unfortunately I have got the latest MM-Release.
                                          So I farther have to search for the error.
                                          • MrCoffeeM
                                            MrCoffee @karsten13
                                            @karsten13
                                            Looks like I have got it.
                                            I just had to remove the 8080 out of http://192.168.xxx.xxx:8080/remote.html
                                            Sorry for that.
                                            Thanks for helping me.
