    MMM-awesome-alexa
    241 Posts 43 Posters 452.9k Views 47 Watching
    • G
      Ghost2000 @sdetweil
      @sdetweil NO
      const chalk = require("chalk");
      const clear = require("clear");
      const figlet = require("figlet");
      const inquirer = require("inquirer");
      const request = require("request-promise");
      const CLI = require("clui");
      const spinner = new CLI.Spinner("Getting response from Amazon...");
      const questions = [
              type: "input",
              message: "Enter your Client ID from Alexa Voice Service (AVS):",
              validate: value => {
                  if (value.length) {
                      return true;
                  } else {
                      return "Please enter your Client ID.";
              type: "input",
              message: "Enter your Client Secret from Alexa Voice Service (AVS):",
              validate: function(value) {
                  if (value.length) {
                      return true;
                  } else {
                      return "Please enter your Client Secret.";
              type: "input",
              message: "Enter your Product ID from Alexa Voice Service (AVS):",
                  if (value.length) {
                      return true;
                  } else {
                      return "Please enter your Product ID.";
              type: "input",
              message: "Enter your Redirect URI (allowed return URL) from Alexa Voice Service (AVS):",
                  const pattern = new RegExp(
                      "^(https?:\\/\\/)?" + // protocol
                      "((([a-z\\d]([a-z\\d-]*[a-z\\d])*)\\.)+[a-z]{2,}|" + // domain name
                      "((\\d{1,3}\\.){3}\\d{1,3}))" + // OR ip (v4) address
                      "(\\:\\d+)?(\\/[-a-z\\d%_.~+]*)*" + // port and path
                      "(\\?[;&a-z\\d%_.~+=-]*)?" + // query string
                          "(\\#[-a-z\\d_]*)?$",
                      "i", // fragment locator
                  if (!!pattern.test(value)) {
                      return true;
                  } else {
                      return "Invalid. Please enter your Redirect URI.";
      const authCodeQuestion = [
              type: "input",
              message: "Enter your Authorization code (from previous step):",
                  if (value.length) {
                      return true;
                  } else {
                      return "Please enter your Authorization Code.";
      const continueQuestion = [
              type: "confirm",
              message: "Do you wish to continue to generate the MagicMirror config?",
              default: true,
      const configQuestions = [
              type: "list",
              message: "What do you want your Wake Word to be? (The phrase used to activate this module)",
              choices: ["Alexa", "Smart Mirror", "Snowboy"],
              type: "confirm",
              message: "Do you want to use lite mode?",
              default: false,
              type: "confirm",
              message: "Do you want to use visulization?",
              default: true,
      const generateQuery = params =>
          Object.keys(params)
              .map(key => key + "=" + params[key])
              .join("&");
      clear();
      console.log(chalk.yellow(figlet.textSync("Awesome Alexa", { horizontalLayout: "full" })));
      console.log(chalk.underline("Welcome to the Config Helper tool!"));
      console.log("This tool will help you get the Refresh Token needed to run MMM-awesome-alexa.");
      console.log(
          "It will optionally generate your config for you, if you wish. If not, you can still create it manually after.",
      console.log("Go to https://developer.amazon.com/alexa/console/avs/products to get the details.\n");
      const run = async () => {
          const output = await inquirer.prompt(questions);
          const scopeData = {
              "alexa:all": {
                  productID: output.productId,
                  productInstanceAttributes: {
                      deviceSerialNumber: 123, // Can be anything
          const queryParams = generateQuery({
              client_id: output.clientId,
              scope: "alexa:all",
              scope_data: JSON.stringify(scopeData),
              response_type: "code",
              redirect_uri: output.redirectUri,
          console.log(
              chalk.blue("Hooray! Link is generated. Part 1 is done. Please go on the link below.\n"),
          console.log(
              chalk.yellow("Please be aware that at the end,"),
              chalk.bgRed("THERE WILL BE AN ERROR!"),
              chalk.green("This is normal.\n"),
          console.log(`https://www.amazon.com/ap/oa?${queryParams}`);
          console.log("\n^^^ Copy and paste the above in your Browser ^^^, follow the instructions.");
          console.log(
              "The authorization code you want is in the address bar in the final screen: https://imgur.com/a/6DbYlKA",
          const authOutput = await inquirer.prompt(authCodeQuestion);
          spinner.start();
          const amazonTokenReponse = await request.post("https://api.amazon.com/auth/o2/token", {
              form: {
                  grant_type: "authorization_code",
                  code: authOutput.authCode,
                  client_secret: output.clientSecret,
              json: true,
          spinner.stop();
          console.log(
              chalk.bgGreen(
                  "\nComplete! Your refresh token should be in the Amazon response below. If not raise an issue:\n",
          console.dir(amazonTokenReponse, { colors: true });
          const continueOutput = await inquirer.prompt(continueQuestion);
          if (!continueOutput.continue) {
              process.exit();
          const configOutput = await inquirer.prompt(configQuestions);
          console.log(chalk.green("\nCongrats! Here is the full config:\n"));
          console.dir(
                  module: "MMM-awesome-alexa",
                  position: "bottom_bar",
                      wakeWord: configOutput.wakeWord,
                      clientId: output.clientId,
                      clientSecret: output.clientSecret,
                      deviceId: output.productId,
                      refreshToken: amazonTokenReponse.refresh_token,
                      lite: configOutput.liteMode,
                      isSpeechVisualizationEnabled: configOutput.useVisualization,
              { colors: true },
      run();
      Have You Teamview ? You can help :D
        sdetweil @Ghost2000
        @Ghost2000 said in MMM-awesome-alexa:
                    return true;
                } else {
                    return "Invalid. Please enter your Redirect URI.";  < <<<<<<<<<< change that line
        G 1 Reply Last reply
        • G
          Ghost2000 @sdetweil
          const questions = [
                  type: "input",
                      if (value.length) {
                          return true;
                      } else {
                  type: "input",
                      if (value.length) {
                          return true;
                      } else {
                  type: "input",
                      if (value.length) {
                          return true;
                      } else {
                  type: "input",
                          return true;
                      } else {
                          return true;
                  type: "input",
                      if (value.length) {
                          return true;
                      } else {
                  type: "confirm",
                  default: true,
                  type: "list",
                  type: "confirm",
                  default: false,
                  type: "confirm",
                  default: true,
              Object.keys(params)
                  .join("&");
          clear();
          console.log(
              const scopeData = {
                  "alexa:all": {
                  scope: "alexa:all",
              console.log(
              console.log(
              console.log(
              spinner.start();
                  form: {
                  json: true,
              spinner.stop();
              console.log(
                  chalk.bgGreen(
                  process.exit();
              console.dir(
                  { colors: true },
          run();
            sdetweil @Ghost2000
            @Ghost2000 yes, now execute the
            node config-helper.js
            again
              Sie haben einen Fehler bei der Suche nach einer gültigen URL-Zeichenfolge. Wir werden den Test überspringen
              • G
                Ghost2000
                pi@MagicMirror:~/MagicMirror/modules/MMM-awesome-alexa $ node config_helper.js
                internal/modules/cjs/loader.js:638
                    throw err;
                Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-awesome-alexa/config_helper.js'
                    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                    at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                    at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                    at startup (internal/bootstrap/node.js:283:19)
                    at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                  sdetweil @Ghost2000
                  @Ghost2000 sorry, config-helper.js
                  dash not underscore
                  you executed the command many times before, you should have known to fix my typo
                  • G
                    Ghost2000
                    http: // localhost: 3000 / oder http: // localhost: 3000 / authresponse
                    which one is correct?
                      sdetweil @Ghost2000
                      • G
                        Ghost2000
                        • G
                          Ghost2000
                            • G
                              Ghost2000
                              it works with your settings.
                              http: // localhost: 3000 /? code = ANMcPyM …
                              DANKE DANKE DANKE DANKE DANKE ! LOVE YOU!
                              • G
                                Ghost2000
                                > magicmirror@2.13.0 config:check /home/pi/MagicMirror
                                > node js/check_config.js
                                [2020-10-10 00:52:40.394] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
                                [2020-10-10 00:52:40.490] [INFO]   Your configuration file doesn't contain syntax errors :)
                                Screen black… no Error
                                • G
                                  Ghost2000 @Ghost2000
                                  pi@MagicMirror:~ $ cd ~/MagicMirror/
                                  pi@MagicMirror:~/MagicMirror $ pm2 log mm
                                  [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
                                  0|mm       |     at Module._compile (internal/modules/cjs/loader.js:786:30)
                                  0|mm       |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                                  0|mm       |     at Module.load (internal/modules/cjs/loader.js:645:32) {
                                  0|mm       |   code: 'MODULE_NOT_FOUND',
                                  0|mm       |   requireStack: [
                                  0|mm       |     '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/index.js',
                                  0|mm       |     '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_helper.js',
                                  0|mm       |     '/home/pi/MagicMirror/js/app.js',
                                  0|mm       |     '/home/pi/MagicMirror/js/electron.js',
                                  0|mm       |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                                  0|mm       |     undefined
                                  0|mm       |   ]
                                  0|mm       | }
                                  0|mm       | [2020-10-10 00:55:35.178] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                  0|mm       | [2020-10-10 00:55:35.178] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                  0|mm       | [2020-10-10 00:55:34.267] [LOG]    Initializing new module helper ...
                                  0|mm       | [2020-10-10 00:55:34.268] [LOG]    Module helper loaded: mmpm
                                  0|mm       | [2020-10-10 00:55:34.304] [LOG]    Initializing new module helper ...
                                  0|mm       | [2020-10-10 00:55:34.305] [LOG]    Module helper loaded: updatenotification
                                  0|mm       | [2020-10-10 00:55:34.306] [LOG]    No helper found for module: MMM-Carousel.
                                  0|mm       | [2020-10-10 00:55:34.306] [LOG]    No helper found for module: clock.
                                  0|mm       | [2020-10-10 00:55:35.154] [LOG]    Loading module helpers ...
                                  0|mm       | [2020-10-10 00:55:35.156] [LOG]    No helper found for module: alert.
                                  0|mm       | [2020-10-10 00:55:35.159] [LOG]    Initializing new module helper ...
                                  0|mm       | [2020-10-10 00:55:35.160] [LOG]    Module helper loaded: mmpm
                                  0|mm       | [2020-10-10 00:55:35.161] [LOG]    Initializing new module helper ...
                                  0|mm       | [2020-10-10 00:55:35.161] [LOG]    Module helper loaded: updatenotification
                                  0|mm       | [2020-10-10 00:55:35.162] [LOG]    No helper found for module: MMM-Carousel.
                                  0|mm       | [2020-10-10 00:55:35.163] [LOG]    No helper found for module: clock.
                                  0|mm       | [2020-10-10 00:55:35.253] [LOG]    Launching application.
                                    sdetweil @Ghost2000
                                    @Ghost2000 module not found, I am away for the rest of the evening
                                      I have a script that does the 14 install steps
                                      • G
                                        Ghost2000
                                        can you send me ?
                                          sdetweil @Ghost2000
                                          @Ghost2000 https://www.dropbox.com/s/omrx3vztjp738hf/do-install.sh?dl=0
                                          • G
                                            Ghost2000
                                            Thx Good night
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 9 / 13
