    new tutorial pls
    20 Posts 5 Posters 7.2k Views 5 Watching
      raf
      @sdetweil thx
      i installed atom on my windows 10 and opened the manual but it stops halfway (the manual stops at this sentence and photo) (we also need the project ID for the plugin configuration above select the project name in the dropdown top left, and this panel will pop up copy/paste the project ID from the right hand column of this project)
      but I’m glad you wanted to help me
        sdetweil @raf
        @raf well u have the info needed for the rest of the tutorial which would be the same
          @raf this takes you thru step 5 of the current wiki, so u can continue from there
          R 1 Reply Last reply
            raf @sdetweil
            @sdetweil after installing the google assistant I get this message and magic mirror does not start anymore:
            [2020-10-10 19:54:42.380] [LOG] Starting MagicMirror: v2.12.0
            [2020-10-10 19:54:42.394] [LOG] Loading config …
            [2020-10-10 19:54:42.405] [LOG] Loading module helpers …
            [2020-10-10 19:54:44.378] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot
            find module ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node’
            Require stack:
            • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/index.js
            • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/index.js
            • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_helper.js
            [2020-10-10 19:54:44.380] [LOG] Loading module helpers …
            [2020-10-10 19:54:44.391] [ERROR] App threw an error during load
            [2020-10-10 19:54:44.392] [ERROR] Error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node’
            Require stack:
            do I also have to install snowboy?
            i just get black screen with no error message on the screen
              raf
              this is the same error as with me but I have google instead of alexa:
              https://forum.magicmirror.builders/topic/12798/mmm-awesome-alexa-warning-electron-v6-1-linux-arm-snowboy-node
                sdetweil @raf
                @raf i understand… I do not know the answer… his installer was one of the best, so I do not know what is the problem…
                he has been moving to a new location so has been/will be busy…
                  raf @sdetweil
                  @sdetweil now finally managed to do with the credentials and now i have another problem again but thanks again for the manual you made
                    raf
                    why is this crossed out:
                    MMM-GoogleAssistant bugsounet Google Assistant integration. Actually not working with Original MagicMirror
                    does it no longer work?
                      sdetweil @raf
                      @raf at one point he had removed all his modules. I do not know the status of individual modules
                        raf
                          raf
                          after days of searching and a completely new installation I finally managed to get everything working, I finally did a rebuild of electron and then it works (and then in Dutch although I thought that this language was not supported )
