    Netatmo - no connection
    15 Posts 8 Posters 5.0k Views 9 Watching
      m-a-r-z-e-l
      I have the same problem as well. My question to the community: Is yours still working? Or am I just to get it work?
      Best,
      Marcel
        sdetweil @texttoolong
        @texttoolong open the developers window ctrl-shift-i and select the console tab and scroll up to see any errors, usually red text.
        also look at the messages in the console where u started mm.
        pm2 logs --lines=50
        or the window where u issued.
        npm start
        (to minimize mm, alt-spacebar, n. just like for windows)
          m-a-r-z-e-l
          Thanks for your help!
          I had a look in the logs which were inconspicuous. But when I had a look in the console I found the following:
          :8080/modules/netatmo/q.min.js:1 Uncaught TypeError: Cannot read property ‘dashboard_data’ of undefined
          at Class.renderAll (:8080/modules/netatmo//netatmo.js:106)
          at e (:8080/modules/netatmo/q.min.js:1)
          at :8080/modules/netatmo/q.min.js:1
          at o.d.promiseDispatch (:8080/modules/netatmo/q.min.js:1)
          at b (:8080/modules/netatmo/q.min.js:1)
          at a (:8080/modules/netatmo/q.min.js:1)
          at s (nunjucks.min.js:4)
          at o (nunjucks.min.js:4)
          at n (nunjucks.min.js:4)
          I have no idea what’s going on…
            sdetweil @m-a-r-z-e-l
            @m-a-r-z-e-l said in Netatmo - no connection:
            looks like the data either wasn’t received, or has changed format.
              PetterT
              Does anyone have any news on this? It seems as if the data structure in the Netatmo API has changed, making the current MM2-modules unusable? Or is it just problems on my end?
              Thanks.
              • FoziF Offline
                Fozi Project Sponsor @PetterT
                @PetterT I had those connection issues, too. But recently I switched to a new fork, which works great and displays the information just as I always wanted. Here is the link
                  PetterT @Fozi
                  @Fozi I am using that exact same fork - but without luck unfortunately. Are you using the module, and can you confirm that it works for you currently?
                  • FoziF Offline
                    @PetterT yes, it woks.
                      PetterT @Fozi
                      @Fozi Sorry for being late to follow up. My error is as follows:
                      When I start up MM2, it shows that the module is loading. A spinning cycle shows in the middle of the screen. However, no graphics are shown - just the spinning cycle icon. I have double and triple checked the config.js file, and all seems correct there. No errors show up in the logs on the npm or in my web browser.
                      Any idea what could be wrong?
                      • T Offline
                        Tribun
                        @PetterT
                        If you only have a spinning circle in the middle, something is wrong with your login details. It may be that one of the values ​​is incorrect: clientId, clientSecret or refreshToken. No error is displayed in the logs if the login did not work. I changed the registration data and was able to reproduce your mistake. If the data is correct, the module works fine for me.
