    Netatmo - no connection
    15 Posts 8 Posters 5.9k Views 9 Watching
    • T
      texttoolong
      Hi there - I have a problem with the Netatmo modules from CFenner and AGP42. Both modules only show a swirly circle but no data. Any idea what I did wrong? Can I provide you with any additional info (sorry - I am a newvie in all of this)
      Thank you so much!!
      Thomas
        m-a-r-z-e-l
        I have the same problem as well. My question to the community: Is yours still working? Or am I just to get it work?
        Best,
        Marcel
          sdetweil @texttoolong
          @texttoolong open the developers window ctrl-shift-i and select the console tab and scroll up to see any errors, usually red text.
          also look at the messages in the console where u started mm.
          pm2 logs --lines=50
          or the window where u issued.
          npm start
          (to minimize mm, alt-spacebar, n. just like for windows)
            m-a-r-z-e-l
            Thanks for your help!
            I had a look in the logs which were inconspicuous. But when I had a look in the console I found the following:
            :8080/modules/netatmo/q.min.js:1 Uncaught TypeError: Cannot read property ‘dashboard_data’ of undefined
            at Class.renderAll (:8080/modules/netatmo//netatmo.js:106)
            at e (:8080/modules/netatmo/q.min.js:1)
            at :8080/modules/netatmo/q.min.js:1
            at o.d.promiseDispatch (:8080/modules/netatmo/q.min.js:1)
            at b (:8080/modules/netatmo/q.min.js:1)
            at a (:8080/modules/netatmo/q.min.js:1)
            at s (nunjucks.min.js:4)
            at o (nunjucks.min.js:4)
            at n (nunjucks.min.js:4)
            I have no idea what’s going on…
              sdetweil @m-a-r-z-e-l
              @m-a-r-z-e-l said in Netatmo - no connection:
              looks like the data either wasn’t received, or has changed format.
                PetterT
                Does anyone have any news on this? It seems as if the data structure in the Netatmo API has changed, making the current MM2-modules unusable? Or is it just problems on my end?
                Thanks.
                • FoziF
                  Fozi Project Sponsor @PetterT
                  @PetterT I had those connection issues, too. But recently I switched to a new fork, which works great and displays the information just as I always wanted. Here is the link
                    PetterT @Fozi
                    @Fozi I am using that exact same fork - but without luck unfortunately. Are you using the module, and can you confirm that it works for you currently?
                    • FoziF
                      @PetterT yes, it woks.
                        PetterT @Fozi
                        @Fozi Sorry for being late to follow up. My error is as follows:
                        When I start up MM2, it shows that the module is loading. A spinning cycle shows in the middle of the screen. However, no graphics are shown - just the spinning cycle icon. I have double and triple checked the config.js file, and all seems correct there. No errors show up in the logs on the npm or in my web browser.
                        Any idea what could be wrong?
                        • T
                          Tribun
                          @PetterT
                          If you only have a spinning circle in the middle, something is wrong with your login details. It may be that one of the values ​​is incorrect: clientId, clientSecret or refreshToken. No error is displayed in the logs if the login did not work. I changed the registration data and was able to reproduce your mistake. If the data is correct, the module works fine for me.
                          • E
                            edgeball
                            I’ve been having the same issue and it’s driving me n*ts. It works but only with 1 netatmo module. Only the base station. But whenever I try to add another one (moduleOrder: []) the spinning circle shows up.
                              sdetweil @edgeball
                              @edgeball i would look to see if there is any error
                              either in the console where u start MM (npm start, or using pm2)
                              if pm2, then
                              pm2 logs --lines=100 will give u output
                              or in the developers window of the browser
                              ctrl-shift-i, select the console tab
                              and put a unique part of the module name in the filter field neta
                              in this case
                              the circle typically means busy, but then the code crashed and didn’t handle the error and can’t clear the busy
                              • E
                                edgeball @sdetweil
                                thanks for the reply. The problem was the netatmo. I reset it and now it works fine. Weird. But I didn’t have to change anything else.
                                  MajorC Project Sponsor @edgeball
                                  I am using this one, and it is working nicely.
                                  https://github.com/RaymondMolenaar/MMM-Netatmo
