    Different calendars result in different layouts!?
    6 Posts 2 Posters 945 Views 2 Watching
      sdetweil @wmx
      @wmx remember that top bar is all the way across the screen, while left and right are not
        @wmx so you have two stacked, all the way across, title centered, content left/right aligned (in area)
        .region.bar {
          width: 100%;
          text-align: center;
        two stacked, title left text aligned , content left/right aligned (in area)
        top-center is not used
        and two stacked, title right text aligned, content left/right aligned (in area)
        each calendar creates an HTML table
        • W Offline
          wmx @sdetweil
          @sdetweil said in Different calendars result in different layouts!?:
          .region.bar {
          width: 100%;
          text-align: center;
          If I add this css snippet to custom.css nothing changes!?
          Is there a way to format each column in each calendar (table) with css?
          How do I address one single calendar with css?
            sdetweil @wmx
            @wmx I was showing that top bar goes all the way across 100%
            that is the existing css
              sdetweil @wmx
              @wmx I do not know how to target one calendar.
              yes there are ways to target specific elements in specific spot in the dom tree. I have to search for it every time.
