    MMM-awesome-alexa
    241 Posts 43 Posters 431.9k Views 47 Watching
      sdetweil @Ghost2000
      @Ghost2000 hm… I installed on pi4, pi3 and my ubuntu desktop with the script and it worked in each case.
      I am using english
      • G Offline
        Ghost2000
        Glaub es liegt an deutsch
          did u redo the node config_helper.js ??
          the refresh token only lasts an hour
          Hast du den Knoten config_helper.js wiederholt?
          Das Aktualisierungstoken dauert nur eine Stunde
          • G Offline
            Ghost2000 @sdetweil
            Yes i can i have time.
            Befehl ?
              sdetweil @Ghost2000
              @Ghost2000 from the awesome-alexa instructions, come on man
              • G Offline
                Ghost2000 @sdetweil
                pi@MagicMirror:~/MagicMirror/modules/MMM-awesome-alexa $ node config_helper.js
                internal/modules/cjs/loader.js:638
                    throw err;
                Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-awesome-alexa/config        _helper.js'
                    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                    at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                    at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                    at startup (internal/bootstrap/node.js:283:19)
                    at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                  sdetweil @Ghost2000
                  @Ghost2000
                  sheesh
                  node config-helper.js
                  • G Offline
                    Ghost2000
                    i have see :D
                    • G Offline
                      Ghost2000
                      Es kamm ein Weißer Punkt in der Mitte .
                      pi@MagicMirror:~ $ pm2 log MagicMirror
                      [TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
                      /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                      0|MagicMir | [2020-10-10 21:53:01.834] [LOG]    Connecting socket for: updatenotification
                      0|MagicMir | [2020-10-10 21:53:01.835] [LOG]    Connecting socket for: MMM-awesome-alexa
                      0|MagicMir | [2020-10-10 21:53:01.837] [LOG]    Connecting socket for: calendar
                      0|MagicMir | [2020-10-10 21:53:01.837] [LOG]    Starting node helper for: calendar
                      0|MagicMir | [2020-10-10 21:53:01.838] [LOG]    Connecting socket for: newsfeed
                      0|MagicMir | [2020-10-10 21:53:01.839] [LOG]    Starting node helper for: newsfeed
                      0|MagicMir | [2020-10-10 21:53:01.840] [LOG]    Sockets connected & modules started ...
                      0|MagicMir | [2020-10-10 21:53:01.923] [LOG]    Launching application.
                      0|MagicMir | [2020-10-10 21:53:04.573] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/fhemrittel%40gmail.com/public/basic.ics - Interval: 300000
                      0|MagicMir | [2020-10-10 21:53:04.587] [LOG]    Create new news fetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                      0|MagicMir | [2020-10-10 21:53:04.639] [INFO]   Checking git for module: MMM-awesome-alexa
                      0|MagicMir | [2020-10-10 21:53:05.080] [INFO]   Newsfeed-Fetcher: Broadcasting 49 items.
                      0|MagicMir | [2020-10-10 21:53:18.720] [LOG]    transiting to state: listening
                      0|MagicMir | [2020-10-10 21:53:24.107] [LOG]    transiting to state: busy
                      0|MagicMir | [2020-10-10 21:53:24.641] [LOG]    transiting to state: idle
                      /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                      0|MagicMir | [2020-10-10 21:47:03.578] [ERROR]  (node:955) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
                      0|MagicMir | [2020-10-10 21:47:03.579] [ERROR]  (node:955) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                      0|MagicMir | [2020-10-10 21:47:03.580] [ERROR]  (node:955) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                      0|MagicMir | [2020-10-10 21:53:05.121] [ERROR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/fhemrittel%40gmail.com/public/basic.ics 404: Not Found
                      0|MagicMir | [2020-10-10 21:53:05.401] [ERROR]  (node:2042) UnhandledPromiseRejectionWarning: Error: [object Object]
                      0|MagicMir |     at /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_helper.js:1:6073
                      0|MagicMir |     at processTicksAndRejections (internal/process/task_queues.js:89:5)
                      0|MagicMir | [2020-10-10 21:53:05.402] [ERROR]  (node:2042) UnhandledPromiseRejectionWarning: Error: [object Object]
                      0|MagicMir | [2020-10-10 21:53:05.403] [ERROR]  (node:2042) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
                      0|MagicMir | [2020-10-10 21:53:05.403] [ERROR]  (node:2042) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                      0|MagicMir | [2020-10-10 21:53:05.404] [ERROR]  (node:2042) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                      0|MagicMir | [2020-10-10 21:53:24.640] [ERROR]  {"error":{"code":"com.amazon.alexahttpproxy.exceptions.InvalidAccessTokenException","message":"AVS was not able to validate the provided access token."}}
                        aclertant
                        Hello guys @sdetweil @Ghost2000 ,
                        You are fighting hard :o) Thanks a lot this is usefull !
                        To distract you lol is there a way to command a blue led ribbon like seen in some videos ? Of course the best way for a noob like me would be a gpio pin to choose in the config… but as the git module is dead, looks impossible right ?
                        Thanks in advance
                          sdetweil @aclertant
                          @aclertant so it would seem. the code is very hard to work with. I am not the author, just trying to help
                            aclertant
                            Yes I know ;)
                              aclertant
                              BTW is this new alexa instance will appear in my alexa app ? as a dot or something very similar ?
                              The idea is to know if I could control this new alexa as usual with my homeAssistant and nodered :)
                              • G Offline
                                Ghost2000
                                0|MagicMir | [2020-10-19 14:17:29.092] [ERROR]  (node:1019) [DEP0005] Deprecatio        nWarning: Buffer() is deprecated due to security and usability issues. Please us        e the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                                0|MagicMir | [2020-10-19 14:17:29.093] [ERROR]  (node:1019) [DEP0005] Deprecatio        nWarning: Buffer() is deprecated due to security and usability issues. Please us        e the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                                0|MagicMir | [2020-10-19 14:17:29.939] [ERROR]  (node:1019) UnhandledPromiseReje        ctionWarning: Error: [object Object]
                                0|MagicMir |     at /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_helper.j        s:1:6073
                                0|MagicMir |     at processTicksAndRejections (internal/process/task_queues.js:8        9:5)
                                0|MagicMir | [2020-10-19 14:17:29.940] [ERROR]  (node:1019) UnhandledPromiseReje        ctionWarning: Error: [object Object]
                                0|MagicMir | [2020-10-19 14:17:29.941] [ERROR]  (node:1019) UnhandledPromiseReje        ctionWarning: Unhandled promise rejection. This error originated either by throw        ing inside of an async function without a catch block, or by rejecting a promise        which was not handled with .catch(). (rejection id: 1)
                                0|MagicMir | [2020-10-19 14:17:29.942] [ERROR]  (node:1019) UnhandledPromiseReje        ctionWarning: Unhandled promise rejection. This error originated either by throw        ing inside of an async function without a catch block, or by rejecting a promise        which was not handled with .catch(). (rejection id: 1)
                                0|MagicMir | [2020-10-19 14:17:29.942] [ERROR]  (node:1019) [DEP0018] Deprecatio        nWarning: Unhandled promise rejections are deprecated. In the future, promise re        jections that are not handled will terminate the Node.js process with a non-zero        exit code.
                                0|MagicMir | [2020-10-19 14:17:29.943] [ERROR]  (node:1019) [DEP0018] Deprecatio        nWarning: Unhandled promise rejections are deprecated. In the future, promise re        jections that are not handled will terminate the Node.js process with a non-zero        exit code.
                                0|MagicMir | [2020-10-19 23:45:02.464] [ERROR]  {"error":{"code":"com.amazon.ale        xahttpproxy.exceptions.InvalidAccessTokenException","message":"AVS was not able        to validate the provided access token."}}
                                0|MagicMir | [2020-10-19 23:45:10.761] [ERROR]  {"error":{"code":"com.amazon.ale        xahttpproxy.exceptions.InvalidAccessTokenException","message":"AVS was not able        to validate the provided access token."}}
                                0|MagicMir | [2020-10-19 23:45:18.513] [ERROR]  {"error":{"code":"com.amazon.ale        xahttpproxy.exceptions.InvalidAccessTokenException","message":"AVS was not able        to validate the provided access token."}}
                                  sdetweil @Ghost2000
                                  @Ghost2000 you will have to redo the code process as it as expired
                                  • G Offline
                                    Ghost2000
                                    O
                                    How can I prevent this?
                                    How long is the code valid?
                                      sdetweil @Ghost2000
                                      @Ghost2000 the code is valid for 24 hours… MM has to be running all the time so it can fresh the token
                                      • G Offline
                                        Ghost2000
                                          bsisco95
                                          For some reason the wake word “Jarvis” will not work for me. Both “Alexa” and “Smart Mirror” do work when changed in the config file. Anyone else had this problem and know how to fix it? Thanks!
                                            JonatanPN
                                            After many attempts, I managed to install MMM-awesome-alexa, but I have a problem, no device from my account appears. I have tried saying “Alexa, search devices” it says it will search but then it says nothing.
                                            If I try to run routines they don’t exist either, however from the Alexa application for my mobile, I can run routines, control devices and also, in the list of devices I see that “Jonatan’s Magic_Mirror_Alexa” appears although as offline.
                                            It is as if it were an account with another profile, since it does not show devices or routines. But it works fine for the rest like asking the time and other information.
                                            I tried creating a new amazon account but the same thing happens.
                                            Does anyone know what can I do? 😔
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 11 / 13
