    [MMM-MieleAtHome] - Show the status of your Miele@Home Devices
    31 Posts 9 Posters 17.8k Views 9 Watching
      dirkie
      hey Victor,
      yes it is really strange. I have no clue why a different module uses your logo. I prepared the screenshot below. In the right screenshot you see that MIELE logo in the MMM-Fuel module. I just took a brief look into the custom.css from your module and the MMM-fuel module. The only Idea i have is that both objects are called “logo”.
      But no clue ;)
      One more thing which I noticed last week. We have 3 machines online now. TUmbler, dishwasher and washing machine. I noticed that there is no fixed order of display. In example the washing maching machine in the tumbler always changed position on the screen i believe every “updatefrequenzy ms”. Can you create a fixed order?
      Another one: you publish the time to finish. E.G. 1h50min. Is it possible to make a switch in config file for time finished? So Washing machine done at 13:00.
      Just my thoughts and feedback from a user side with a lack of programming skills. I hope you don’t feel angry about it ;)
      Thanks again for your work.
      DIrk
      Screenshot: (white areas are censored)
        djerik @ViDiBi
        @ViDiBi I have started the work on making a port of your module for Home Connect. I think the first version can be ready next weekend
          djerik @evroom
          @evroom
          Inspired by the good work of @ViDiBi, I have created a version for Home Connect: https://github.com/djerik/MMM-HomeConnect
          It’s my first try of this - please let me know if this is useful and if you have ideas for improvement
          ViDiBiV 1 Reply Last reply Reply Quote 1
          • ViDiBiV
            ViDiBi @djerik
            Hi @djerik !
            Thank you very much for the nice words :-) And I’m glad you’ve created the first Module for you :-)
            Have a great day! Oh and @dirkie : I hope I’ll soon have some time to look into the Logo issue :-) I haven’t forget about it!
            • evroomE
              evroom
              @djerik said in [MMM-MieleAtHome] - Show the status of your Miele@Home Devices:
              I am having difficulties in registering an application in order to get a client ID and a client_secret.
              In the Register Application form, what do I use for example for the Redirect URI ?
                djerik @evroom
                @evroom
                Sorry, that is missing from the documentation. The URI must be:
                http://localhost:3000/o2c
                Upon the first start of MagicMirror, it will start a browser and show the authorization screen using this URI. This is only necessary the first time, the access token will be refreshed automatically afterward.
                • evroomE
                  evroom
                  It will not take my password :-(
                  I have the same login name (email address) as the home-connect account, perhaps that is the reason.
                  I am trying to delete the account, but till now no luck.
                  Will keep trying and will report back.
                    djerik
                      requiemmg @dirkie
                      @dirkie said in [MMM-MieleAtHome] - Show the status of your Miele@Home Devices:
                      edit:
                      I found out there seems to be some (at least for me) not understandable interference between MMM-Miele and MMM-Fuel(https://github.com/fewieden/MMM-Fuel). In MMM-Fuel you have “car ICON” which can be enabled or disabled. it was enabled at first and then next to that little car there popped up. when using iconHeader=false in MMM-Fuel the car and the MIELE icon disappeared. Is this a problem with your module or with MMM-Fuel module? Would be great if you can have a look at it… ;)
                      Having the same issue. Thanks for the module, anyway :-)
                        djerik @evroom
                        @evroom
                        Strange. Have you set up the application as described here:
                        https://github.com/artcom/home-connect-js
                        Have you entered the ID and Secret in your MM config?
                        Any errors in the log?
                        Do you have a screenshot?
                        • evroomE
                          evroom @djerik
                          @djerik
                          The problem at this moment is not related to your module.
                          It is related to the home-connect accounts; the standard one and the developer one.
                          I cannot login into both accounts; I cannot login into the account using the app.
                          Password reset does not work; I do not get any mail.
                          Even setup a new account and here too no mail to activate the account.
                          I will need to contact the home-connect support, but could not find any time yet; hopefully this weekend.
                          • evroomE
                            evroom
                            • T
                              Tribun
                              Hi folks, I installed the module according to the instructions, when I restart the MM² I only see “Charging devices”. In the log I find the following error message:
                              [2020-10-31 11:34:19.387] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                              [2020-10-31 11:34:19.391] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                              [2020-10-31 11:34:21.485] [ERROR]  2020-10-31T11:34:21 <warn> 401 Login Error ! (/home/pi/MagicMirror/modules/MMM-MieleAtHome/utilities/mieleathome.js:308 Request._callback)
                              [2020-10-31 11:34:21.489] [ERROR]  2020-10-31T11:34:21 <warn> undefined (/home/pi/MagicMirror/modules/MMM-MieleAtHome/utilities/mieleathome.js:309 Request._callback)
                              I can log into my Miele account using the mobile app. Username and password are the same as with the Miele app? I have already created several client_ID and a client_Secret. However, I always get the same error message.
                              ViDiBiV 1 Reply Last reply Reply Quote 0
                              • ViDiBiV
                                ViDiBi @Tribun
                                Hi @Tribun,
                                Can you try here if you can log into your miele account and try to get any response and a token:
                                Miele 3rd Party APi
                                Have a great weekend
                                Victor
                                • T
                                  Tribun @ViDiBi
                                  @ViDiBi Hallo Victor, thanks for the link. Unfortunately, I am not familiar with programming on this page. Where should I log in or register?
                                  I can also no longer enter any data for the Api registration on the Miele home page. (https://www.miele.com/f/com/en/register_api.aspx)
                                  mfg
                                  • H
                                    hypertraxs
                                    hello,
                                    vorab super Modul. Hab jedoch ein paar Fehler gefunden bzw. es für mich (Österreich) adaptieren müssen.
                                    beispielsweise - vg auf de-AT umstellen, Sprache muss auf DE in meinem Fall gestellt werden.
                                    und nun zum Fehler: in der /utilities/mieleathome.js - Zeile 105 verursacht die Zeichenfolge / ein Kommentar und somit läuft der Code nicht mehr…
                                    letztendlich hats dann funktioniert
                                    gruß Hyper
                                    • ViDiBiV
                                      ViDiBi @Tribun
                                      Hi @tribun,
                                      sorry for the late reply but I had a lot to do in the last time :-)
                                      Are you now able to create for a miele account?
                                      Because you need one to have access to the miele API :-)
                                      Have a great day!
                                      Victor
                                      • ViDiBiV
                                        ViDiBi @hypertraxs
                                        Hi @hypertraxs,
                                        freut mich, dass dir das Modul gefällt :-)
                                        Hast du eine Lösung für das Problem mit dem Kommentar? Ich bin Java Skript leider nicht so richtig gewohnt, daher kann es gut sein, dass der Code nicht so der Hit ist :-S
                                        Wenn du also Verbesserungsvorschläge hast, baue ich sie gern ein :-)
                                        BG
                                        Victor
                                        O 2 Replies Last reply Reply Quote 0
                                          BravoOscar
                                          I just tested this module and have found it working, if you use the following:
                                          Test your Miele@Home acount:
                                          https://www.miele.com/developer/swagger-ui/index.html
                                          Get your client_ID and client_Secret here:
                                          Your UserName and password are the same you use to login to Miele@Home app
                                          vg: ‘da-DK’, // default = ‘de-DE’, Choose the app Country
                                          language: ‘en’, // default = ‘de’, Miele only support ‘de’ or ‘en’
                                          showAlwaysAllDevices: true, // default = false , True show component even if it’s off
                                          Language supported:
                                          de - Deutsch
                                          en - English
                                          VG supported:
                                          ‘en-AU’ - Miele Australia
                                          ‘nl-BE’ - Miele België
                                          ‘en-CA’ - Miele Canada
                                          ‘es-CL’ - Miele Chile
                                          ‘hr-HR’ - Miele Croatia
                                          ‘cs-CZ’ - Miele Czechia
                                          ‘da-DK’ - Miele Danmark
                                          ‘de-DE’ - Miele Deutschland
                                          ‘et-EE’ - Miele Eesti
                                          ‘es-ES’ - Miele España
                                          ‘fr-FR’ - Miele France
                                          ‘ko-KR’ - Miele Hanguk
                                          ‘en-HK’ - Miele Hong Kong, China
                                          ‘en-IE’ - Miele Ireland
                                          ‘en-IL’ - Miele Israel
                                          ‘it-IT’ - Miele Italia
                                          ‘el-CY’ - Miele Kypros
                                          ‘lv-LV’ - Miele Latvija
                                          ‘lt-LT’ - Miele Lietuva
                                          ‘de-LU’ - Miele Luxemburg
                                          ‘hu-HU’ - Miele Magyarország
                                          ‘en-MY’ - Miele Malaysia
                                          ‘es-MX’ - Miele México
                                          ‘nl-NL’ - Miele Nederland
                                          ‘en-NZ’ - Miele New Zealand
                                          ‘ja-JP’ - Miele Nihon
                                          ‘no-NO’ - Miele Norge
                                          ‘pl-PL’ - Miele Polska
                                          ‘pt-PT’ - Miele Portugual
                                          ‘ro-RO’ - Miele România
                                          ‘de-CH’ - Miele Schweiz
                                          ‘en-SG’ - Miele Singapore
                                          ‘sl-SI’ - Miele Slovenia
                                          ‘sk-SK’ - Miele Slovensko
                                          ‘en-ZA’ - Miele South Africa
                                          ‘fi-FI’ - Miele Suomi
                                          ‘sv-SE’ - Miele Sverige
                                          ‘en-TH’ - Miele Thailand
                                          ‘tr-TR’ - Miele Türkiye
                                          ‘en-GB’ - Miele UK
                                          ‘en-US’ - Miele USA
                                          ‘en-AE’ - Miele United Arab Emirates
                                          ‘zh-CN’ - Miele Zhōngguó, dàlù
                                          ‘de-AT’ - Miele Österreich
                                          ‘el-GR’ - Miele Ελλάδα
                                          ‘ru-BY’ - Miele Беларуси
                                          ‘bg-BG’ - Miele България
                                          ‘ru-KZ’ - Miele Казахстан
                                          ‘ru-RU’ - Miele Россия
                                          ‘sr-RS’ - Miele Србија
                                          ‘uk-UA’ - Miele Україна
                                          Working config:
                                                      disabled: false,
                                                      module: "MMM-MieleAtHome",
                                                      classes: 'medium bright',
                                                          userName: "??@??.??", // Your email to Miele@Home app
                                                          password: "??????", // Your password to Miele@Home app
                                                          client_ID: "????", // Your client_ID you get from the link above
                                                          client_Secret: "????", // Your client_Secret you get from the link above
                                                          vg: 'da-DK', // Your country code from the list above
                                                          language: 'en', // Language supported from list above
                                                          showAlwaysAllDevices: true //always display component
                                          • O
                                            OberfragGER @ViDiBi
                                            @vidibi Hi, ich schreibe das auch nochmal in Github.
                                            In MM Version 2.17 ist das request-Modul rausgeflogen. Deshalb muss dieses bei der Installation berücksichtigt werden.
                                            Also- in den Modules Folder wechseln und dann:
                                            npm install request
                                            Nun läuft. Danke für das Modul und das aufgreifen der Icons…sieht ja aus wie in der App. Nice.
                                            Klappt wie erwartet auch mit dem Geschirrspüler.
